Question about Bosch Kitchen Ranges
Key pad locked - Bosch Kitchen Ranges
Safe won't stay locked, key missing but have key pad.
You might need to have the key set to lock in order to use the keypad or check the battery in side the door
Mar 08, 2013 | Locks & Locksmithing
How do i lock and un lock my hp compaq 6220 lap top my cat keeps jumping on the key pad
There is no lock for the key pad, all you need is another USB key pad to deactivate the on board keypad.
The cheapest way is a "rolled newspaper", use that to bash that annoying cat!
Hope that helps you out!
Aug 08, 2011 | Computers & Internet
2005 Chevrolet Silverado Automatic door locks
I assume you mean that the central locking system will not lock the doors but you can do so manually.
Get inside the vehicle and close all doors.
On each rear door, lock and unlock the mechanism manually a couple of times. In other words do not use the key pad.
Then leave both rear doors in the locked position (manual locking) and operate the lock button on you key pad to operate the central locking system. Wait a few seconds then hit unlock on your key pad and a few seconds later hit lock on your key pad.
If the system fails to lock your rear doors you will need to get the vehicle to an auto electrician to check out the issue and rectify it for you. There are a number of possible causes which cannot be identified without physically checking the system. So you will need to have this rectified by a professional.
Dec 04, 2009 | 2005 Chevrolet Silverado
Rear doors unlock but will not lock
Automatic door locks will not lock rear doors, they open fine when manually locked but will not lock with switch key fob or when put in gear.
You mean that the central locking system will not lock the rear doors but you can do so manually.
Dec 01, 2009 | 2005 Chevrolet Silverado
Number keys on think pad lock using openoffice.org
On Thinkpads laptops the keys on the right hand side double up as the number keypad. To switch on the Number lock key pad on - press and hold the Shift key and press the NumLk/ScrLk key, it is above the F11 key, the Num lock LED will also light up. Press these keys again to turn off the Numer Lock.
Nov 10, 2009 | IBM ThinkPad T42 Notebook
KEY PAD LOCKED ON SO LETTERS COME UP WITH NUMBERS UNLESS YOU HOLD FN BUTTON DOWN CAT WALKED ACROSS COMPUTER WHAT DO I DO
It seems the cat activated the Num Lock key.
To deactivate it press simultaneously Fn +
Num Lock key.
The num lock key will be marked with 'Num Lk 'or with a a key pad icon the same colour of you Fn key.
Sep 06, 2009 | Computers & Internet
Ice and water won't come out dispenser
here is link to your owners manual subzero.com
and here are instructions for using the lock feature..
LOCK For Models 685 and 695, the lock feature is used to prevent unintended ice and water dispensing. When the dispenser is locked, all key pads on the glasswell are deactivated to allow cleaning or to prevent small children from using the dispenser. To activate the lock feature, hold down the LIGHT key pad on the glasswell until the key pad lights flash once and the red LOCK icon is illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was activated. To deactivate the lock feature, hold down the LIGHT key pad until the key pad lights flash once and the red LOCK icon is no longer illuminated (approximately five seconds). The lights will remain in the state they were in before the lock feature was deactivated.
Thanks Peyton
Mar 02, 2009 | Sub-Zero 695/S Side by Side Refrigerator
Nokia Phones
boss ....go to menu... and > settings.. >..phone settings..>.. there uou will find the option to lock ur key pad. cheers!!
Aug 03, 2008 | Nokia 3110 Cellular Phone
Kitchen Ranges Logo
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
