Question about Pioneer Audio Players & Recorders
Connect speakers to Pioneer VSX-502 - Pioneer Audio Players & Recorders
SOURCE: Pioneer turntable Pl-560 and Pioneer Receiver VSX-D409
Magnetic phono cartridges like the one on your pioneer has an output of about .005 Volts, the standard inputs are looking for 1 to 2 volts for fulol out put, the phono preamp will step up the output voltage to 1 volt so you can play it thru a non phono input like Aux, tape or tuner.
Radio shack sells cheap ones and you will hear what you pay for.
I sell turntables and audio gear, check out www.soundsciencecat.com
Good Luck,
Neal Van Berg
Posted on Sep 16, 2008
robotek
  • 1512 Answers
SOURCE: Pioneer vsx-d902s
Hi Tracey
Most of these older machine had speaker switches on the front panel. Can you check what they are set to. It may be that both switches(A and B) are set in, or set out. this could present the problem you are having with no sound. turn on just one switch that corresponds the connections you have made on the rear (use speaker A) Another thing to check, is when you first turn on the amp, do you hear a relay click shortly after you switch on. If you don't hear this delayed click, then there may well be a problem in the output stages of the amp. If this is the case, then you will need to take it to a tech to have a look and see what has failed in the amp. Hope this info helps, if you have any questions, I am happy to try and help you further.
regards
robotek
Posted on Nov 08, 2008
SOURCE: Pioneer VSX-D608 Optical connection
The manual states that the default association of each digital input in as follows:
  • Optical 1: CD
  • Optical 2: MD
  • Optical 3: TV
  • Coax: DVD
Use the "Signal select" button to set the receiver to use a digital input, and the Dolby/DTS button (above "Signal select") to enable decoding.
As samz11 stated above, a remote is required to alter the digital input mapping.
Posted on Feb 18, 2009
SOURCE: Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Posted on Apr 19, 2009
SOURCE: problem with pioneer vsx-916 av receiver
i have been using this with two speakers and was working perfectly fine . recently i bought two floor standing speakers and worked fine when connected . When i tried connecting all four speakers it showed overload kindly tell me how this could be solved
Posted on May 02, 2009
Pioneer vsx-d510
Disconnect all the speakers, and then check. Connect the speakers, one by one, and find which one makes it overload. That speaker is faulty. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Pioneer Audio/Video Home Theater Remote...
I want to connect kenwood woofer sw-07 to pioneer amplifier vsx-d859tx. i am unable to connect please guide me.
I don't recall correctly if your Pioneer has a sub out RCA connector, and if the Kenwood SW-07 has a low level input. So the usual way is to connect it using the speaker wires.
You connect either the FL or the FR to the sub and it should work.
Good luck
Jan 11, 2015 | Pioneer Audio Players & Recorders
Pioneer VSX-818V-K Receiver
wondering if input levels are too high on some channels causing safety limits to shut it out..check level outputs on eguipment.
Jan 08, 2014 | Pioneer VSX-818V-K Receiver
How to connect my subwoofer to my vsx-405 receiver
Hello
Try to download the user manual to Pioneer VSX & THX user manual. click here to down load the same. You will get details of it connections from the manual.
http://www.dataentryjobs.us/67948.html
Feb 24, 2012 | Pioneer VSX-405 Receiver
Have a Pioneer VSX-1018 receiver. When I connect
You speakers are out of phase. Check to see if the polarity is correct on the receiver and the speaker. Positive (red) with positive, negative with negative (black). Also check the impedance of the speaker, it should be located on the back of the speaker measured in ohms. Make sure that your receiver matches the impedance of your speaker. You can find this in the settings of the receiver.
Dec 08, 2009 | Pioneer VSX-1018AH-K Receiver
Looking to connect 4 speakers to the surround back
Series the speakers, they may not get as much power as you would like, but your receiver will last longer.
Aug 16, 2009 | Pioneer VSX-518-K Receiver
Sibilant output from Pioneer VSX 1018 AH-S
Suspect a DTS board capacitor failures the ESR characteristics.
To troubleshoot connected any available device to RCA stereo connections at input to multi channel in. Test input to the corresponding speaker output confirming audio quality. This circuit bi-passes the DTS function and connects to the power amplifier for the speaker.
Connect any audio amplifier from the preamp out and confirm the quality of the audio.
I suspect that the pre-amp out will contain the distortedf noise. If the distrotion appears in all the channels it is most likely the DTS.
These are repairable.
Hope this helps?
May 09, 2017 | Pioneer VSX-1015TXK Receiver
Pioneer VSX-815 speaker wiring
You can hook them up either way, the banana jacks are good for hooking two speakers to one terminal (ie one through the botton, one banana) but the electrical connection is the same either way. Sometimes the banana capable jacks are on speakers A and speakers B, and the surround don't accept banana plugs, your stuck with how your reciever is wired.
Dec 08, 2008 | Pioneer VSX-815-K Receiver
Bose 901 connection to Pioneer VSX-917v Receiver
any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
mark
Dec 28, 2007 | Bose 901 VI Main / Stereo Speaker
Nov 08, 2007 | Pioneer VSX-453 Receiver
51 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
