Question about Canon CanoScan N1220U Flatbed Scanner
How do you tell if the unit it turned on since there's no light?
  • 11,896 Answers
You will hear the laser run across top and back to orgional position
Posted on Jun 22, 2009
I have just fitted a ceiling light, as instructed, but the light will not switch off by the light switch
Most ceiling fans are factory wired so that the light is independently controlled from the fan, therefore when you turn on/off the wall switch it has no control over turning the light on or off.
However, the light can be wired, inside the fan unit, so that it works in conjunction with the fan, so that when you turn the wall switch on or off, it will turn both the fan and light on or off together.
To do so would require the specific wiring diagram of how the fan unit is presently wired. It's a simple modification, but without knowing or seeing how it's wired (internally) it's impossible to tell you which wires need to be modified and reconnected.
Nov 02, 2014 | Home
Maytag Epic Dryer Model MED9700SQ0, everything lights up, power is on, but drum will not turn and no heat.
Can you tell if the motor comes on? If it does, then it could be a broken belt.
Sep 01, 2012 | Dryers
This is new now it is blowing cool air
Please tell us more about the history of this problem--
How does the Air conditioner sound, when it first turns on?
and then do you hear any clicking, -- and do you hear the compressor start up inside the unit?
Any other clues-- Like lights dimming briefly, and then getting bright again?
and maybe the compressor trying to start-- but not being able to run?
Any indicator light on the unit-- what do they report?
Tell us more--
Mack B
Jan 10, 2011 | Heating & Cooling
How to turn off oil light after oil change
I hate to be the bearer of bad news, but I very seriously doubt simply changing the oil will solve your problem. Your oil light is signifying a potential problem which your vehicle is trying to tell you about. I would check into the oil sending unit, oil pump, or if equipped possibly even the oil temperature sending unit.
Mar 08, 2010 | 2006 Toyota Tacoma
Indoor unit does not function -outdoor unit works
These units have circuit boards inside that have lights on them. These lights come on and tell you what the problem is. I have had 4 units do the same thing that yours is doing. The result has been that the compressor has gone bad. You have to get access to the control board to see the lights. There will either be one inside the inside unit or one inside the outside unit depending on exact manufacturer date.
Good luck and hope this helps.
Aug 22, 2009 | Heating & Cooling
DynaGlo Heater S05-010271
check the thermacoupler on the unit its that small(looks solid)tube next to the pilot light it tell unit to turn on when pilot is lite
Jan 14, 2009 | Dyna-Glo RMC-8001SS Heater
Operation light and timer light blink 5 times?
I don't know if this is the proper technical solution or not but my unit was having the same issue. I cleaned it checked fuses made sure the cover was properly in place and nothing worked. As a final thought I went to the home fuse panel and tripped the breaker for the unit, waited about 30 seconds and turned it back on. I did this with the unit set to off. When I came back and turned it on, it is working properly with the operation light solid red.
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
How do I light the pilot light on my older Goodman heating and air unit?
depending on how old the unit is , you turn the gas valve to pilot setting, hold down the button, light and hold for 1 min.
Oct 27, 2008 | Goodman GMS90703BXA Heater
Flase red light when turn on
Looks like the fall damaged the unit. Try turning it in for warranty. Off course don't mention the falling. Just tell them the yellow light appeared out of nowhere.
It's still risky though, if Sony suspects something happened to it before this problem they will probably not trade the unit or let you pay for a new one.
Greetings,
DarkNeogen
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Canon CanoScan N1220U Flatbed Scanner Logo
78 people viewed this question
old marine
old marine
