Question about ASUS Eee 4G Notebook
Wireless network adapter - ASUS Eee 4G Notebook
  • MrObvious
    MrObvious May 11, 2010
    What about it?
  • Troy Anderson May 11, 2010
    please stop posting this issue multiple times. The reason you are not getting an answer is you have 0 information about the problem in the ticket.
  • 130 Answers
Need more info to be able to help please tell me what you need in the acer.
Posted on Jun 22, 2009
How to install an wirless adapter to mi desktop
Install a wireless network adapterIn areas that are served by a wireless network, you can connect to a computer network without using a cable, and surf the Internet or connect with other computers. To connect to a wireless network, your computer needs a wireless network adapter.
Many new computers-especially laptops-come with wireless adapters. Before using your computer, check to see if it already has a wireless network adapter.
If your computer doesn't have a wireless network adapter, you can install one.
Install a wireless USB network adapter. Most people prefer this type of adapter for any type of computer, because it's easy to install.
Install a wireless CardBus or CF network adapter. For portable computers, this type of adapter (also called a PCMCIA or PC Card) is easier to travel with than a USB adapter, because it is often smaller and fits securely in the PC Card slot on the side of the computer.
Install a wireless internal network adapter. If you have a desktop computer, you may prefer an internal adapter so that you can use the USB port to connect another accessory.
The type of adapter you install depends on your computer and your level of expertise.
How to determine if you already have a wireless network adapterMany portable computers manufactured after 2000 have wireless networking built in. However, because the antenna is hidden inside the computer, it's not easy to see.
To see which network adapters are currently installed in your computer
1.
Click Start, and then click Control Panel.
69010-click-control-panel.gif 2.
Click Network and Internet Connections.
69010-click-network-and-internet-connections.gif 3.
Under or pick a Control Panel icon, click Network Connections.
69010-click-network-connections.gif 4.
Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
Nov 12, 2010 | Computers & Internet
How do you install the wirleless router?
1. Click Start, and then click Control Panel.
2. Click Network and Internet Connections.
3 Under or pick a Control Panel icon, click Network Connections.
4. Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
And Thanks.
Mar 18, 2010 | Linksys (WMP54GS) 802.11g/b Wireless...
Do I need two wireless network adapters? I looked in the device manager folder in network adapters and there are 2... Intel (R) Pro/1000 PL Network Connection #2 and Intel (R) Pro/wireless 3945ABG...
You should have only 1 wireless adapter, the other 1 is the ethernet adapter. If you experience low signal strength even after updating the drivers, you need to customize wireless settings on the router.
You need to change the wireless mode to "802.11b and 802.11g" or "802.11g", whatever you have in your router. If this is the same with all wireless networks, wherever you go, then its an issue with the adapter, you should get a replacement.
Feb 05, 2010 | Intel PRO/Wireless 3945ABG Network...
No power
The light on the adapter indicates if there is network activity.
Check in device manager if the adapter is properly installed. Right click my computer, then select properties. Go to the Hardware tab and click Device manager.
If there is a yellow exclamation point on the USB adapter then you may need to reinstall the Linksys adapter.
If the Linksys adapter is installed properly, then check the wireless network connections if it is connected.
To ensure that you are connected to your wireless network, you will need to know the settings on your wireless router or access-point. Take note of the wireless network name (SSID) and the wireless security and network key.
If you are using the Linksys Wireless Utility, go to Site survey, select your SSID then click connect. Type the network key if wireless security is enabled.
If you are using the default wireless connection on your computer, just right click the wireless network connection icon on the system tray (lower right conner of your screen, near the clock), then select view available wireless networks. Select your SSID, then click connect and type the network key (if wireless security is enabled).
Hope this helps! Good luck!
Jan 03, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
It does not connect
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
WIN XP
Right click on MY COMPUTER ==> properties ==> Device Manager ==>
you will see Network adapter ==> under network adapter you will see the wireless adapter ==> Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ?If it says working properly then that's great !
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Dec 09, 2009 | Dell 1450 (D1450U) Wireless Adapter
How do you connect WIndows Vista to Windows 7 through ADHOC?
Dec 04, 2009 | Computers & Internet
How does the pc wireless adapter work for laptops with embarq equipment. currently using dsl with embarq.
pc wireless adapter will work then if you have also another network like wireless router or another PC or Laptop with wireless adapter, if your going to use this wireless adapter network in pc to pc is you are going to setup by adhoc to adhoc connection, itself detect for sharing a network without any router needed, but if you do such simple network connection use wireless router, its definitely work easily. Aumatomaticall detect wireless router on your wireless adapter network.. Good luck!
Jul 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
Xbox 360 Does not recongize my wireless adapter
My adapter light is a solid red. When I plug in an ethernet cord, that'll connect.. but when I take the ethernet cable out, the 360 always reports Disconnected under Network Adapter even though the wireless adapter is plugged in.
Apr 03, 2009 | Microsoft Wireless Network Adapter Xbox...
Wireless internet
1. Go into the Network Connections (Start->Control Panel, Network Connections)
2. Locate your Wireless Adapter and make a RIGHT click on the icon.
3. Click on "View Wireless Networks"
If that does not work, it may mean that your wireless adapter is using a customized software to manage wireless networks. This is the case for my Intel Wireless adapter. In this case, look in Start->All programs for a program from your wireless adapter or laptop manufacturer (if the card is embeded). If you tell me the exact name of your wireless adapter, I should be able to help you a little further.
Apr 20, 2008 | Computers & Internet
Can't set up wireless connection
  1. Check in your system: Click Control Panel, then double click System. On the Hardware tab click Device Manager. Click the (+) sign besides the Network Adapter. See if the Packard bell wireless adaptor is there. If its is not there, right click the Network Adapter and click Scan for hardware changes, and reinstall the network adapter.
  2. If the Packard bell network adapter is already there, click Start and click My Network Places. On the left side of the Network Connection, click View Network Adapter. The wireless network adapter should be there. Right click the wireless network adapter and choose properties. Give check mark on Show icon in notification area when connected (to show you if there is wireless notification), and give check mark to Notify me when this connection has limited or no connectivity (to show if the wireless network is disconnected). and click OK
  3. Turn on the orange broadband livebox. And right click the the wireless network connection (on Network Connection) and choose View Available Wireless Networks. And the click the Orange broadband Livebox to use this wireless Network connection.
I hope this solution is helpful to solve your problems
Best Regards
Blackrobin
Nov 16, 2007 | Computers & Internet
ASUS Eee 4G Notebook Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
