Question about Danze Home
How danze shower lever which changes the water flow from the permanent shower head to the removeable freehand shower has fallen out. How can it be repaired?
It looks as though it is missing a washer
    Novelist:
    Champion:
  • 227 Answers
Don't try to repair it. Replace it. All hand held showers use 1/2" hose fittings so any brand divertor should fit. Bring the part with you as there are different styles.
Posted on Aug 11, 2014
  • 37 Answers
SOURCE: flow restrictor
Hi, all the shower heads that I replaced, the flow restrictor was always in the nut that you screw onto the pipe that comes out of the wall.it's a plastic disc, with a little hole in middle.you can use a coat hanger to pull it out.
Posted on Nov 12, 2008
  • 659 Answers
SOURCE: Want to increase water flow rate through Danze shower assembly
There is a flow regulator in the shower head. You have to remove the shower head and inside just down below the pipe threads, you will see the water saver. It can either be a white disk that can be screwed out or a black piece of plastic that just sits down in ther or a very small rubber washer. If it's the small rubber washer, you will need something pointy to remove it. I use a dental pic for them.
Posted on Mar 22, 2009
KMusselmann
  • 247 Answers
SOURCE: vibration from my shower panel
Sounds like the pipe going to the shower head is vibrating. Not secured tightly indige the wall. That is about the only thing it could be in my opinion. Hope this helps you out .
Kurt
Posted on Mar 26, 2009
  • 18 Answers
SOURCE: Danze shower kit
SORRY, ITS SO.... BUT GOOD FOR YOU THIS ISN'T MY FIRST RODEO... TELL YOUR HUSBAND TO ADD THIS TO HIS NEVER ENDING TO-DO LIST: YOU CAN ADD A SHOWER HEAD VALVE WHICH DEPENDING ON YOUR FINISH ONLY COSTS ABOUT 15 DOLLARS AND TAKES 2 MINUTES TO INSTALL. I ACTUALLY HAVE ONE ON MY DANZE VENETIAN BRONZE TUB AND SHOWER FAUCET FOR THE EXACT SAME REASON. YOU SIMPLY REMOVE THE SHOWER HEAD, THEN ADD THE VALVE, THEN ATTACH THE SHOWER HEAD TO THE VALVE. ADJUST FOR THE DESIRED PRESSURE. SORRY HUBBIE
Posted on Dec 29, 2009
  • 81 Answers
SOURCE: The water comes out of both the shower head and
I will have to assume this issue developed and was not present at first use after the initial installation.
There are generally only two reasons for your problem. The first is that the diverter mechanism is simply wearing out and/or broken. The second it that there is a foreign object preventing it from doing its job correctly. Either way the diverter must come out. I have provided a couple of links below that should help get it out.
Once out, put a wadded up towel over the end of the tub spout opening so as to prevent any water from coming out of it. Then, for just a moment, turn your shower on full and adjust your temperature from full cold to full hot. This process should dislodge any foreign matter and send it out the opening the diverter came out of and also will probably get you wet. I usually plug the tub so I can catch what, if anything, comes out. Having a second person holding a bowl over the diverter opening helps reduce the water splash.
Rinse off the diverter and reinstall it. Turn the shower on and see if there is any difference in how much water comes out the spout while in the shower mode. If nothing has changed then the next step is to replace the diverter.
The diverter assembly part number is A603819
http://www.danze.com/products/pdfs/D113000_ip.pdf
http://www.danze.com/products/pdfs/D500058T_ip.pdf
Posted on Jun 02, 2010
I can't get shower head pressure from the outer head of my new grohe freehander.
Everything you installed new. Please chack if not one of the gaskets came in a pipe or a line. I once had a rubber ring almost complete blocking the water flow.
Nov 01, 2014 | Grohe Shower Freehander 27 007 Chrome...
Danze sunflower shower head only works with cold water
Hi, same problem i had faced and that time i didn't have much knowledge about pipe setting or plumbing stuffs.Please check the shower setting connections and make sure the hot water is in active mode or check the internal connection for pipes with faucets.i have given link for more information for showers .
http://www.a-general.com
Jun 10, 2014 | Danze & Sunflower Showerhead
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
Installed new Danze shower valve the water is on but will not come out why?
shut off your water and pull the cartridge out off unit...make sure you have no trash in cartridge...turn water on without cartridge in but only part way to see if you have water flow to value...then make sure no damage to cartridge or some of these have plugs that need removed on install of cartridge....you may need to remove test plug that is in there ....try this...good luck
I do not have enough hot water from my shower head. I have plenty of hot water in my bathroom and kitchen sink. What can I do to remedy the problem?
the problem is the hot/cold mix is set wrong ---
remove the water control handle to expose the mix valve -- you should see a small set screw that will either increase or decrease the travel of the hot water valve. --- sometimes instead of a set screw there is a little pop off plastic set ring,, pop off and set to a more advanced travel.
this will increase the amount of hot water that flows to the shower head and the bath tap.
c...
Jan 20, 2011 | Grohe Freehander Adjustable Shower Head...
Water Flowing to Shower Head and the Spout Simultaneously
a solution is with the other different but same question.
Jun 02, 2010 | Danze D500558T Parma Shower w/ 4"...
The water comes out of both the shower head and the tab simultaneously. If the knob controlling the water flow is turned to the side that control the water to shower head then about 75% of the water flows...
Jun 02, 2010 | Danze D500058BNT Parma Shower Trim Kit w/...
Mar 22, 2009 | Home
Danze shower kit
your husband is 100% correct unless you change the shower head or take the one off that is there and take out the little plastic filter thats right inside where it screw on to the shower arm,, easy fix
Nov 09, 2008 | Danze D500558T Parma Shower w/ 4"...
Home Logo
76 people viewed this question
Top Danze Home Experts
Mike
Rabbit Brains
Rabbit Brains
Mike Herrington
Mike Herrington
Level 1 Expert
Are you a Danze Home Expert? Answer questions, earn points and help others
