Same issue as another user - brand new batteries, plenty of space on memory card. A/F beam working. If flash is needed when shutter button pressed, the lightning bolt icon flashes as if it is waiting for the flash to recharge, though it hasn't been used - picture is not taken.
Camera was not dropped (to my knowlege - there are children in the house though, so you never know... :) ).
Try a mode other than auto, and turn off the flash. Then try taking a picture. Did it work? If so, then your flash is either shorted or burned out, or the flash safety circuit thinks that the camera is open. If the flash is burned out, then professional repair is required, as a flash change-out is not trivial (Call 1-800-OK-CANON).
However, it's more likely to be only a break in the safety circuit. Many Canon cameras use some of the screws in the camera case to serve as a means of detecting if the case is open (and thus disables the flash to prevent shock). Examine all the screws around the perimeter of your case. Are they all there and tight? If not, tighten loose screws and try moving and replacing any missing screws with one of the others that are still there.
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot A610 Digital
