Question about Canon C3380i Color Copier
Ps4 location irc3080 - Canon C3380i Color Copier
Having issues setting up the PS4 can't find the hdmi slot same size as the hdmi wire that comes with the console. Hdmi wire and tv shown in pic
  • Connect the included HDMI cable to your TV and the PS4's HDMI Out port Connect your console to your cable or satellite box Unplug the existing HDMI cable connecting your cable or satellite box to the TV and plug it into the PS4's HDMI In port Plug the PS4 into a power source Power on the PS4 Plug the controller into the PS4 using the included Micro USB cable Press the PS button on the controller to pair it with your PS4
Jan 10, 2017 | The Video Game Consoles & Games
How do you get a stuck disc out of a ps4
  1. Step 1: Remove The Glossy Section of the Cover. Turn off the PS4. ...
  2. Step 2: Locate the Manual Eject Screw & Remove the Disc. With the glossy panel removed, you will see two sets of vents lining the outer left edge. ...
  3. Step 3: Put Everything Back Together.
Here How to Manually Eject Disc Stuck in Your PS4 PlayStation LifeStyle How to Manually Eject Disc On PS4
Jul 16, 2016 | PS4 Video Game Consoles & Games
Can i run through PS4
34 PS4 tips and tricks for getting the most out of your console
www.techradar.com/.../25-ps4-tips-and-tricks-for-getting-the-...
TechRadarJan 13, 2016 - PS4 tips and tricks. ps4. PlayStation 4 has just celebrated its second birthday but whether that lovely parallelogram has been snug under your ...
Is it useful to connect PS4 through the Xbox One? - Xbox ...
www.gamefaqs.com/boards/691088-xbox-one/70244880
GameFAQs
So being a PS4 owner I'll be getting an Xbox One and was wondering if its useful at all to hook my PS4 to the Xbox One via HDMI... What can you use this for?
Running PS4 via Xbox One's HDMI input - YouTube
? 3:07
https://www.youtube.com/watch?v=bWxVPsyMs_0
Nov 19, 2013 - Uploaded by DigitalFoundry
Ever wondered what happens when you run PlayStation 4through the Xbox One's HDMI input? ... Xbox ...
PS4 Tips and Tricks Guide - Trusted Reviews
Jan 20, 2016 | Televison & Video
Can I upgrade the PS4 Harddrive?
The PS4 will allow you to use an external drive to store data other than games. If you put a game on an external drive, it wont work. The drive in the unit is 500Gb
Jun 28, 2015 | Sony PlayStation Video Game Consoles &...
Two problems, PS4 ejected discs and now wont turn on
To stop your PS4 from ejectin disks, remove the glossy HDD panel, and locate the PS4 eject screw its small at the top of the PS4 (by top I mean the way you would see it if you had the PS4 stood up vertically), and tighten it.
Feb 20, 2014 | Sony PlayStation 4
Ce-34335-8
Open up your PS4 and reseat the Drive
*make* sure it is *UNPLUGGED* and not powered on
http://community.us.playstation.com/t5/PlayStation-4-Support/INFO-Proper-Seating-of-PS4-Hard-Drive/m-p/42138109#U42138109
Open up your PS4 and Open up your PS4 and reseat the Drive
Nov 16, 2013 | Video Game Consoles & Games
What is better product ? the ps4 or the new xbox
According to me, PS4 are better than Xbox. You can get various powerful accessories in PS4.
Also, if you want guidelines about various external and internal hard drives o your PS4, you can easily get IT professionals suggestions and guidance at PS4 External Hard Drive.
You can also get here various different kits to make up gradation on your storage hard disk of PS4.
Oct 30, 2013 | Video Game Consoles & Games
How do i print setting for a canon irc3080
Hi
For the print setting have a lot's of option so please download the manual and read the proper setting.
and fix your problem.
Jun 07, 2011 | Canon iRC3100 Printer
Canon iRC 3380i error code E00025-002...help please?
Service Bulletin
Issued by Canon Europa N.V. Copier Color
HARDWARE
Revised:
Addition of the Affected Machines
Hopper Assembly
Subject:
Measures against E025 error due to toner leak
Detail:
<Symptom>
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Model:
iRC2380i
iRC2880
iRC2880i
iRC3080
iRC3080i
iRC3380
iRC3380i
iRC3580
iRC3580i
Ref No.:
iRC3380-023 Rev. 2
(F2-T01-NO1-10097-03)
Date:
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
P-2 GUIDE, UNIT CABLE, FRONT
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
620
New FC6-9380-010 GUIDE, UNIT CABLE,
FRONT 0->
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Jun 15, 2010 | Canon C3380i Color Copier
Canon C3380i Color Copier Logo
old marine
old marine
