Question about GE GTUP240EMWW Washer
Can the front panel be unscrewed to access the water shut off
Kenmore washer front load 3.5 super capacity clogged pump.
Remove the lower front panel and unscrew the LARGE 3" round plastic access cover. Have a drain pan handy as it will pour out water! Dump the coins, lint and whatever is collected in there, reinstall, tighten securely and replace the lower panel.
Jan 17, 2015 | Kenmore Washing Machines
Spin cycle doesnt finish
Suggestion: Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Mar 24, 2013 | Frigidaire Affinity ATF7000E Front Load...
Front loader has stopped mid wash and red light has come on saying clean my pump. How do I do this?
Not knowing which model you have makes it a bit difficult. Most front loaders have a little trap door down on the front panel somewhere. Behind this door is access to the pump filter. Usually, it just unscrews, and you pull it out. If your machine is full of water, expect a mess. remove any buildup of fluff, foreign objects etc. If your machine has no trap or access. Unplug the machine and drag it away from the wall. Lean the machine back against the wall to gain access underneath. You should be able to see a large hose from the tub to the front ( or side) of the pump. They are usually held on by a spring clip. Slide the clip back or unscrew the clip to enable you to pull the hose off the pump. Clean out any foreign objects you find. As before, if the machine is full of water, expect a mess. Front loader drain hoses usually exit out the top of the machine so lying the end of the drain hose on the ground wont drain the water.
Jul 26, 2011 | Whirlpool Washing Machines
My ge front load washer model#wcvh6260hww keeps repeating the cycle
Hi you need to clean out the drain pump assembly, sometimes there is an access panel on the front right of the washer you just pull it down and unscrew it, if this model doesnt have that, then you need to take off the front kick panel at the bottom there is 3 screws and then you will see the pump on the right where you can unscrew a canisher looking lid this is the filter for the drain pump, there will be water left in it you will several big towels. clean thoroughly should fix your problem.
Sean
Mar 28, 2011 | Washing Machines
How do you clean out the filter on a whirlpool duet sport washer?
Prop up the lower front edge of the washer or cushion the rear top edge with cloth and lean the washer against the wall for easy access to the three screws securing the lower front access panel to the cabinet. Remove the screws and pull down the lower front access panel to remove it from the cabinet.
Place a shallow pan or lay a towel under the filter to catch the water from the pump. Unscrew the filter from the pump assembly and drain the water. Clean the filter and screw it back into the pump assembly. Slide the lower front access panel up back into the cabinet and secure it with the three mounting screws.
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
From time to time the mashine is not evacuate the water and the mashine will not start for a new load .I have to unscrew the filter,drain the water and then will wash. Is a problem with the pump? thank you...
a front loader huh, usually there is an access panel at the bottom front held on with 2 screws. remove this panel and trhere should be a trap filter that is plugged up. remove filter and clean it out, than put it back. or the water pump is going bad try the filter first.
Nov 07, 2009 | Whirlpool LHW0050PQ Front Load Washer
GE WSSH300G0WW will drain the water, but not strt the spinning. Is there a filter that might need cleaning?
Yes, the filter can be accessed by removing lower front panel. Unscrew pump cover filter. Have a shallow pan and towels to catch water when servicing
Oct 11, 2009 | General Electric WSSH300G Front Load...
My ge model wbvh5200j2ww washer wont't start. it has power on the panel but doorwon't latch or start filling.
If the pump filter is clogged, the washer won't even turn on. This filter is located behind the small access panel at the bottom on the front of the washer. Remove access panel, flip down scoop, and unscrew filter. You will need a bowl to catch water that comes out(may smell bad). Pull out filter, clean, and replace. Washer should work normally afterwards.
May 01, 2009 | GE Energy Star WCVH6260F Front Load Washer
Problem with whirlpool duet
you can access the drain pump assy by removing the 3 screws across the bottom of front panel, after that youll see the drain pump directly in front of you, youll need to unscrew t he filter cap form the "button trap"assmebly, this is what catches all the junk left in pockets, or the baby socks, so they dont make itr into the puppmp itself. be warned there will be water wanting to come out after unscrewing the cap. ALOT depending on amount of water in machine!!!!!!
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code FO9
F09 is listed as 'Waterflow Problem' and means there is a problem with the water pump. Either something clogging the pump, or a pump malfunction.
Check for something clogging the water pump first. To do that open the lower access panel by unscrewing the 3 torx screws at the very bottom of that panel, then you will see the plastic water pump in the middle front, just unscrew the handle.
You may wish to have some dry towels on hand as some water will come out.
Jan 08, 2008 | Kenmore Elite 45986 Front Load Washer
GE GTUP240EMWW Washer Logo
24 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
