Question about Yamaha RX-V995 Receiver
The Volume knob on the receiver will not move when we try to turn up the volume from the remote control. We have changed the batteries in the remote several times.
This has been occurring for over a year. Tired of getting up and having to change the volume from the receiver.
5 Suggested Answers
  • 336 Answers
SOURCE: Volume Knob does not adjust volume, but remote does.
Check your owners manual for "factory reset" this will reset the main micro-processor. Otherwise the encoder (volume pot) needs cleaning, soldering or replacement. It could also be a cracked circuit board (if it has recently been hit)
Posted on Jan 29, 2009
smarthome2
  • 1114 Answers
SOURCE: remote does not move volume knob
Unplug the receiver for a minute then plug it back in. This resets the controls. If you still have a problem, post a comment and I will help you troubleshoot further. Hope this helps
Posted on Jun 25, 2009
smarthome2
  • 1114 Answers
SOURCE: volume control
Unfortunately no, some of the newest "High End" Yamaha's have it. Are you using Cable TV or Verizon FIOS. Cable is the worst, FIOS has corrected this issue for the most part. It only seems to happen now when ABC news (Local) has a promo. If you have cable... COMPLAIN!! They will get the message! DSS has corrected this issue as well. Hope this is at least helpful...
Posted on Aug 17, 2009
SOURCE: Yamaha RX-V1000 volume control erratic, remote
Hi.
The volume knob issue alone sounds like it's hardware-related and therefore not easily fixed. Also, since the remote appears to be working (the LED's are lighting up), but the unit is not controlled anymore, the IR sensor is probably faulty as well. I would seriously consider sending this AV receiver in for repair. If it's still within warranty, you shouldn't need to pay anything for the repair.
Manual for your receiver: http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V1000.pdf
It's not much but I hope this helps.
D
Posted on Aug 21, 2011
The volume knob on my JVC receiver is loose and the volume cant be turned up or down by the knob. Can i use a remote to turn it up or donw or do i have to look for a new receiver?
Assuming your receiver came with the ability to be remotely controlled, then yes, a universal remote such as the Logitech Harmony etc, will be able to control the volume.
Dec 10, 2014 | JVC Audio Players & Recorders
Pioneer vsx1021k volume drops by itself at 3db increments until there is no volume. M volume is displayed when this happens as if someone was manually turning the volume knob.
Dirty rotary encoder (volume control ). If you are confident with opening the unit yourself, a spray of contact cleaner into the encoder might help. Ideally u should replace it.
OR
The volume minus button on your remote is dirty/shorted. Try removing remote control batteries and see if the issue disappears.
Aug 14, 2014 | Pioneer Audio Players & Recorders
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
My remote has a long delay on the up and down volume.it just started a few weeks ago and im getting annoyed..Common problem?
Manually turn the volume knob on the receiver several times as to loosen it up. Change the batteries.
Feb 25, 2011 | Onkyo RC-375DV Remote Control
Volume control does not turn volume down. Lost remote control CD Receiver LT-1
I have opened the same unit up. The volume control knob moves a plastic paddle against a right & left micro switches. The paddle is connected to the knob by a very thin piece of plastic which breaks very easily. I tried to glue a different piece of plastic on , but it only worked for a little while. It was a pain to assemble & reassemble the unit. I do not recommend trying it. Just buy another remote (about $35.00)!
Good Luck
Dec 07, 2009 | Teac LT-1 Clock Radio
Remote does not move volume knob
Jun 25, 2009 | Yamaha RX-V800 Receiver
Kenwood VR-6070: Broken volume knob; will IR sensor still work?
Looks like you have several faults?
First try to fix the remote:
http://www.instructables.com/id/Repair-your-remote-controls/
May 28, 2009 | Kenwood VR-6070 Receiver
It has lost partially the mechanical connection between the volume control knob and the volume control pot.
The knob could be "stripped". A drop of a slightly resilient glue should do the trick. Do not use rigid adhesives, as this will prevent future service to this area of your receiver....accordianman
Oct 31, 2007 | Yamaha RX-V630 Receiver
Yamaha RX-V995 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
