Question about West Bend Dol-fyn ARS 2000 Water Distiller
Dolfyn water distiller System II
Water was running slow so i cleaned the pot and put back together. Since then the motor will not shut off, any suggestions??
I received some color photos via email...when i tried to print them, they all came out like a water color all running together.
clean your print head. Pull the ink cartridge/print head out and dab a Q tip in distilled water and run it over the very small piece of foil that is the ink jet head in one direction, like your painting it. you will use about 15 to get it clean as it will constantly bleed ink onto the Qtip. When its clean, you should put it back in and run a printer head cleaning cycle through the printers tool section. It will print each color a few times on a line and that should clean the head internally.
Jan 31, 2018 | Office Equipment & Supplies
White stuff coming out of my iron
Spring water has minerals in it.If you want to be sure the water is pure,distilled water is best.(My city water is full of minerals,which means a cleaning with CLR is necessary quite often for my coffee pot and shower head).Distilled water was recommended for topping off car batteries back in the day before they were maintainence free.
Jun 02, 2012 | Rowenta Effective Iron
How do I clean the washer to eliminate the dark spots of lint and dirt on laundry?
Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle.
To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again. Add 1 cup white distilled vinegar to a large pot of water, bring it to a rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing, as well as those left by deodorants, by spraying full-strength white distilled vinegar on underarm and collar areas before tossing them into the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy? Pour a few cups of white distilled vinegar in the machine and wash the clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes by filling the bathtub with very hot water and 1 cup white distilled vinegar. Hang the garments above the steaming water and shut the door so the steam can penetrate the fibers.Keep the steam iron clean and in good working order by getting rid of mineral deposits in steam vents and spray nozzles. Fill the water chamber with a solution of equal parts white distilled vinegar and distilled water. Set it in an upright position and let it steam for about 5 minutes. When the iron is cool, rinse the tank with water, refill and shake water through the vents onto an old cloth. Test before using.Remove scorch marks from an iron by rubbing it with a warmed-up solution of equal parts white distilled vinegar and salt. If that doesn't work, use a cloth dampened with full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry! Add about 1/4 cup white distilled vinegar to the last rinse. The acid in white distilled vinegar is too mild to harm fabrics, yet strong enough to dissolve the alkalies in soaps and detergents. Besides removing soap, white distilled vinegar prevents yellowing, acts as a fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine with white distilled vinegar. Periodically run the machine with only a cup of white distilled vinegar in it-nothing else added to the wash cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water.
Get rid of the tiny holes left along the hemline when you take out the hem of any garment by moistening a cloth with white distilled vinegar, placing it under the fabric and ironing.
Oct 31, 2011 | Whirlpool Washing Machines
I washed my engine the other day 97 Jetta gl 2.0l, and I must have gotten water in the motor somehow because there's coffee cream colored chunks of oil in my motor i must have a blown head gasket how do...
If you have a blown head gasket the only option you have is to replace the head gasket.Also take your oil pan off and clean as much of the gunk as you can out of it.When you take the motor apart you want to make sure that you clean the parts so there free of any grime on both the top end and the bottom end.When you put it back together iI recommend that you run engine flush through the motor to clean any residual sludge.Hopefully this will help clean the oil ports in the bearings of any sludge.I would flush it at least 2 times and then put oil in it.Change the oil after 2000 miles and then change it every 3000 miles.Just remember you must make sure that you clean the motor real good before putting it back together.You could save yourself any future problems by also replacing the connecting rod bearings.
Mar 07, 2011 | 1997 Volkswagen Jetta
Clean iron?
Hello tcant....
  • 1 Fill the iron's steam receptacle with white vinegar or CLR, a product used to clean coffee pots. CLR is available in department stores.
  • 2 Plug in and set the iron to its steam setting.
  • 3 Operate as usual. When the vinegar or CLR begins to steam, operate the iron as you would normally. Press it over an old, clean towel as the vinegar or CLR loosens sediment and dirt from the appliance.
  • 4 Continue ironing until all of the cleaning solution has steamed out. Repeat the cleaning process if necessary until the iron no longer oozes discolored liquid and the ironing surface is clean.
  • 5 Fill the iron steamer receptacle with distilled water and set the appliance to steam.
  • 6 Continue steaming until the smell of vinegar or CLR is gone.
  • 7 Prevent future mineral buildup by using distilled water for steam in your iron, rather than tap water. Joe. Thanks for choosing Fixya!
  • Jan 12, 2011 | Black & Decker ICR250 Iron with Auto...
    Nebulizer is not providing mist..checked tubes and cleaned air filter..what could reason be?
    There could be some dried fluid inside the tubes or medication chamber. Try cleaning the tubes really well even if they look clean and try cleaning the medication chamber with distilled water (better then tap water because it has been cleaned of all impurities), raise it out with warm distilled water (warm is better then cold to try to dislodge any dried medication), microwave the water to warm it up.
    If that does not clean the medication chamber try boiling the medication chamber in a pot for 3 to 5 minutes in distilled water.
    PS for the tubes use the warm distilled water.
    I hope this helps you out!
    Jan 01, 2011 | Health & Beauty
    My keurig coffee maker is going really slow all of a sudden .. why would that normally happen
    sometimes they become partially blocked and the best thing to do is run a quarter cup of vinegar mixed with a full pot of water through it empty and repeat if necessary. This will help to clean the tubes out of any residue and help to put it back to normal,
    Be sure to run a pot or two of just water through it after the vinegar to rinse it clean of vinegar.
    Oct 07, 2010 | Vacuums
    Coffee doesn't brew full pot
    Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
    -Tha Mp3 Doctor
    Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
    Whirlpool Washer Model LSL9244EQO
    shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
    Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Err2 message
    Suggestion was Descaling the Coffee Maker from KitchenAid Phoebe (I'm guessing customer support)
    http://kitchenaidconversations.com/forums/topic.asp?TOPIC_ID=14441&SearchTerms=err+2
    Cleaning scale from coffee maker DO NOT USE THAT MUCH VINEGAR! Put a tiny bit of vinegar in the carafe and fill carafe the rest of the way with water. Run that vinegar/water through machine. Using another container, fill machine with plain water and run that through. Repeat until the vinegar taste is gone. If you do not run lots of plain water through the machine after, your coffee will taste like...um...disgusting!
    To clean hard water deposits from a coffeemaker use distilled white vinegar. You may need to use as much as a gallon if the scale buildup is really bad. Fill clean coffee pot one half full of vinegar and run through machine as if making coffee. Repeat this process several times using fresh vinager until it comes out clear. Do this once a week and your maker will work much better.
    Jun 20, 2008 | KitchenAid KCM511 Coffee Maker
    West Bend Dol-fyn ARS 2000 Water Distiller Logo
    363 people viewed this question
    Top West Bend Water Dispensing & Filtration Experts
    ray gallant
    Dwain Schmidt
    Dwain Schmidt
    Level 1 Expert
    Tom Chichester
    Are you a West Bend Water Dispensing and Filtration Expert? Answer questions, earn points and help others
