Question about Honda Garden
Digagram throttle linkage murray 17.5 hp model 42509x92b
bargainbin2
  • 123 Answers
SOURCE: my murray 17 hp 42 inch cut hydrostat mower will
Hydrostat transaxles are very picky like the trans in your car. It must have clean fluid and be full of fluid. I am not saying to fill that transaxle to the top but make sure it is to the top of the fill line. Also it needs to be changed every few years and keep it clean to help it stay cool. If it has a filter make sure to change it when you change the fluid in the transaxle. That fluid is nothing more than 20-50W motor oil.
Posted on Sep 01, 2009
  • 2418 Answers
SOURCE: murray 17 hp briggs and stratton will run on
You need to take the fuel system down, to see whats is going on. The fuel line from the tank to the carb is it clear? will gas pour out if disconnected? If yes now you will have to take the carb off and take it a part to clean it. That should fixit.
Posted on Oct 31, 2009
SOURCE: need to know the model number for a murray 17 hp
I think that would be a 16 hp with a 46" cut. If thats what you have then the model number would be something like this...402707.
I am looking for a belt diagram for that very same model.
Posted on May 23, 2010
  • 6468 Answers
SOURCE: murray 42 in 17 hp doesnt start
i would look at the safety switches that being the most common cause
Posted on Jun 17, 2012
SOURCE: murray 17 hp 42in cut no fire on plugs????
Dirty flywheel. Gap between flywheel and magneto too wide. Pull flywheel cover check for excessive rust on outside edge of fly, then check magneto for same. Check gap, then examine all wiring.
Posted on Aug 09, 2013
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
How to put spring back on carburetor on murray 5 hp push mower?
Hard say exactly without model of engine, but on most small briggs engines is as follows. One end of the spring will hook into the loop of the linkage wire that connects the governor to the carburetor butterfly and the other end will hook into to O of the throttle plate. Thus as you move your throttle plate to increase your engine rpm it applies more tension on the spring opening the governors up and vise versa when moved to lower your rpm's. Hope this helps.
Aug 27, 2014 | Garden
Briggs Stratton Murray ridding lawnmower won'stay running
Check the throttle linkage at the engine/carb is OK. Next thing is likely to be a bit of dirt in the carb. If you know what to do, strip it and blow out with an airline. Make sure the mixture and throttle screws are reset and tune the engine for smooth running when started. If you get the model and serial no off the engine there's loads of info online on these engines.
Aug 08, 2014 | Garden
Murray 17 hp 42in cut no fire on plugs????
Aug 09, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray 42 in 17 hp doesnt start
Jun 16, 2012 | Garden
SEARS 5.5 HORSE POWER BRIGGS&STRATTON ENGINENE NEED THROTTLE CABLE PART NO 9215R
please mention sears craftsman 5.5 HP model numbers.
is the part no. 9215R correct?
Jul 14, 2011 | Craftsman Throttle Cable Murray 319306...
My Murray 20" 3.5 hp classic throttle free design
it possible snap its main rod if it freely spins no compression buy new motor
Jun 08, 2011 | Briggs & Stratton Garden
Need to know the model number for a murray 17 hp 46 inch cut autodirve wide body lawnmover ???
Apr 27, 2010 | Garden
Poulan Lawntractor 13.5HP throttle linkage missing
The easiest thing for you to do is look at another mower that has a single cylinder Briggs at how the linkage is set up. They will all be the same linkage from 12 hp- 20 hp.
Jul 03, 2009 | Oregon Scientific Oregon Fusion Blade For...
The kohler engine on my poulan pro 42 inch 17 hp is reving way too high the throttle cable does not apear to be stuck
YOUR THROOTLE LINKAGE IS BINDIND WITH THE ENGINE OFF MOVE THROTTLE BACK AND FORTH WATCHING THE LINKAGE ON THE CARB, SPRAY LINKAGE WITH PENETRATING OIL SO IT LOOSENS UP
Jun 26, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
23 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
