Wich is the service code for lg 42ln51 - Televison & Video
Where do I find the code on LGE DTV BCM20702A1
You will find those repair codes in the service manual book wich is available on the net sometimes or you can contact the dealer to get the book or maybe a repair shop. Best regards,
Serge.
Feb 18, 2015 | LG 32LG30 32 in. LCD HDTV
Please help me a reset key for the copier machine IR2270 wich read error code E000000-0001
The abnormal rise of temperature.May be main thermistor or dc controller pcb.You have to reset the machine in service mode COPIER FUNCTION CLEAR ERROR.
Oct 30, 2014 | Canon iR2270
LG GD510 GPRS SETTINGS
i downloding grps setting for hedsat model LG GD510
Jul 01, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Circular grey rubber part ..
firstly u have to take the wire off it with a screwdriver unscrew it take it off then watch how the old on pulls off as there is a lip all around this rubber and it as to bed into the metal drum just see how the old one comes off once you have put the new one on put the wire back around it or it could be a metal strat wich tightens up with a screwdriver,rgds,paul
Jul 07, 2009 | LG WM-1832C Front Load Washer
Lg plasma after storm doesnt want to turn on
Mainboard damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
May 14, 2009 | LG 50PC1DRA 50 in. Plasma Television
Machine overfilling
You need to check the pressure switch and tube wich you can access from the top of the machine with the top removed. the tube is a rubber pipe which may have fallen of the switch or pressure chamber connection. cheers
Mar 25, 2009 | LG WM1812C Front Load Washer
LG DHINE KE970 security codes
the default security code for many LG phones is the last 4 digits of your phone number. I think it is called the PIN sometimes too.
Apr 30, 2008 | LG Shine KE970 Cellular Phone
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
