Question about Bissell Ready Clean Power Brush
What could be causing this would cause my bissel ready clean to pour the water out the bottom when I put the tank back on?
  • 48 Answers
SOURCE: how to use bissell carpet cleaner
On the 1698 modle thier is a large clean water tank and a smaller shampoo bottle which seats on the side of the machine.
the shampoo goes in the smaller bottle fo the two.
Posted on Jan 06, 2008
  • 3422 Answers
SOURCE: bissell carpet shampooer
HI,
Please check these:
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Posted on Jul 20, 2008
SOURCE: my bissell powerbrush won't **** up the water
had same problem - carpet soaked with dirty water and very little, if any, cleaning fluid used. Easily remedied. Removed water resevoir and found that the rectangular shaped washer at the top of the front cover (the bit you had unscrewed to give a good clean) had become dislodged. It has small lugs on either size which lock on to the plastic opening when pushed down firmly. Resevoir then sits on top and makes full connection, also ensure that grey locking handle is fully pushed down.
Seemed to me that the water wasn't being sucked up as there was air getting in and this has down the trick. Sorry if this is difficult to follow but all will become clear when you look for the black washer! Good luck
Posted on May 04, 2009
SOURCE: How do I fix Bissell Quicksteamer leaking from
I have the same problem... seems to be because of a bad, or worn, rubber gasket.
Posted on Jan 02, 2010
Vac Belts
  • 701 Answers
SOURCE: Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Posted on Mar 02, 2010
Testimonial: "just what I was looking for thank you"
My shampoor will not pick up the dirty water?
If your ProHeat 2X machine is not suctioning properly, first check the motor duct gasket. To check this, first remove the tank and place your hand over the rubber square opening. If there is no suction there, please take your machine to a BISSELL Authorized Service Center for inspection. If your machine does have suction at the duct, continue to check the following:
- Ensure the Ready Tools Dial is set to the appropriate setting (Floor Cleaning or Hose Attachments).
- Remove the tank from the machine and ensure the tank lid is attached properly. The front window must first hook onto the lip of the bottom of the tank and then drape over the tank. Latch the bottom tank to the top tank lid. THIS LID CANNOT BE ATTACHED PROPERLY IF THE TANK IS NOT REMOVED FROM THE MACHINE.
- Make sure the Water Tank is not full on the outside of the bladder. If it is, empty the tank.
- Ensure the hose is firmly attached to the back of the machine. If not, re-insert as necessary by twisting into place.
- The machine must be in an upright, locked position and set to the Hose Attachment setting. If the handle is slightly tilted back while using, it will create a small gap at the suction inlet (where handle meets gasket, above the Bottom Tank) which will cause little or no suction.
- Check the red Tank Lint Screen for debris. If the Lint Screen is dirty, the unit will have poor suction. Clean the Lint Screen if necessary.
- If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced.
- Check the Tank Lid and Tank for damage.
If you continue to experience low suction, please take your machine to a BISSELL Authorized Service Center. The warranty on your machine is one year. To locate your nearest BISSELL Authorized Service Center, click here.
To contact Consumer Services by phone, please call us at 1-800-237-7691, Monday - Friday 8 a.m. to 10 p.m., or Saturday 9 a.m. to 8 p.m., ET. A representative will assist you.
Apr 19, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
Need directions to fill , and how to use
Hi
I have one just like it. Lay the machine back by pressing the pedal on the left side of the machine with your foot. Now you can get to the handle for the clean/dirty water tank. Lift this off. There's a clip in the back to separate the top sweep section from the tank. Take off the top. You'll see an open hole on the top for filling the bladder inside. This is for clean, hot water only. Fill the bladder, around the bladder is where the dirty water goes back in. you can drain the dirty water by pouring out the corner. There is also a plug on the bottom for draining the bladder when you're done.
When you put the sweep section back on the tank be sure to catch the front part over the edge of the tank or it won't stay on. Then fasten the clasp and put it back in place.
To fill the soap dispenser... find it at the back of the machine at the bottom. It just lifts out of the machine. Fill to line and reinsert.
Hope this helps.
Handy Andie
Mar 20, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
MY BISSELL SEEMS TO HAVE THE SAME PROBLEM AS EVERYONE ELSE - NONE WHICH TO MY KNOWLEDGE HAVE BEEN RESOLVED. MY MACHINE WILL DESPENSE BUT NOT SUCTION - WHAT GIVES WITH BISSELL -IT THIS AN ONGOING PROBLEM
Please check the following:
First check the motor duct gasket. The motor duct gasket is visible once the tank is removed. It is located underneath the handle on the top of the base of the machine. It has a black rubber coating around it. If there is no suction there please let us know. If your machine does have suction at the duct, continue to check the following:
- If the float flap door in the tank lid is activating prematurely when you turn the machine on, this flap door should be replaced. This tank may need to be emptied.
If you continue to experience low suction contact BISSELL Consumer Services at ...
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Aug 16, 2010 | Bissell 9200 Upright Vacuum
My bissell pro heat 2x does not **** up the water from either the upholstery cleaner or carpet cleaner. Any thoughts as to why? The water and heat functions work it just does not pick up
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell will not suction water from the carpet
If you continue to experience low suction, please contact BISSELL Consumer Services at...
1-800-237-7691
Sat: 9am to 8pm ET
Apr 09, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell ready dry doesn't clean my carpet.
my bissel ready dry is not sucking the water up
Mar 30, 2009 | Vacuums
Bissell Pump Weak?
Often times I see the pumps clogged with soap when acting like you described. This can cause a pump to be weak. Pressure builds up whe you stop squirting water but tapers off quickly. A few times I've been able to get water flowing good but most times have to replace the pump.
Mar 02, 2017 | Bissell 1699 ProHeat Clear View Upright...
I have a bissell quickwash 1950-e. I bought it Jan. 2006, and have only used it 8-10 times, I live in a very hard water area, so I though if I put some vinegar in with the cleaning solution it would get...
Hard to say what is causing your problem, replacing the cap and insert on the water tank may help, part #2041111, even tho it may trickle out water when depressed, they can still be bad. The other thing would be the rod not relesing the water like it should. The big draw back to this model is Bissell has obsoleted all of its parts and most are no longer available. Might be wiser to buy new.
Apr 13, 2008 | Vacuums
BISSELL QUICKSREAMER MODEL 2070
Here is a link, don't know if it will work for you or not:http://bissell.com/images/UserGuides/1960.pdf
But you put you cleaning solution along with hot water in the upper tank, the bottom tank sucks up the water as you clean. Pull the trigger to dispense clean while pulling it back towards you, push it forward and repeat until done. If that link doesn't work, you can call Bissell and order a operator manual.
1-800-237-7691
Mar 17, 2008 | Bissell 1770 Quicksteamer II Upright...
Bissell Ready Clean Power Brush Logo
53 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
