Question about Copystar - CS-3035 Printer
Image cycle Copier keeps running and says image cycle
    An expert who has answered 20 or more questions within one hour.
  • Copystar Expert
  • 181 Answers
If you use toner that says for use in instead of Kyocera brand toner this can happen you have to remove all the toner in the dv unit and install only Kyocera toner when you do that enter 1087 1087 then 130 and let it run until its done this will refill the dv unit with toner even though you have a copystar machine its made by Kyocera when it stops enter 01 then print to return to normal operating mode
Posted on Jul 12, 2017
I move a new imaging unit to another copier but they show as full
there is a chip on the image unit they keep track of the drum turns and info
Apr 10, 2014 | Konica Minolta Bizhub c203 Copier
Ar m55on Keeps resetting will not stay on
If the copier is on the network and setup as a printer. Disconnect the network cable then turn the copier. Data from Mac computers would cause to do that. Delete the data from the queue.
Dec 03, 2013 | Sharp AR-M355N Grayscale Copier
Error c2652 in konica minolta c250
C - 2651 Cyan imaging unit EEPROM acces error
C - 2652 Magenta imaging unit EEPROM acces error
C - 2653 Yellow imaging unit EEPROM acces error
C - 2654 Black imaging unit EEPROM acces error.
Clean the connection between the imaging unit and the machine if dirty.Reinstall imaging unit or change imaging unit.
Try reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON the copier.
Keep pressed the Utility key when the Trouble resest message is displayed.
Release the Utility key and touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Apr 16, 2013 | Konica Minolta bizhub C250 All-In-One...
My canon image runner 3235i will not power "on"
on back side of the copier are small black switch, it is protective fuse. Try to put him back ON.
If these doesn't helps you have power supply problem....
Keep me posted!
Hope that helps!
Apr 19, 2011 | Canon Image Runner 3320I Copier
How to remove service man from copier sharp ar5320
hi the service man means yours copier have complet the pm cycle if u dont want to replace drum and devolper u can clear the pm counter with sim 24-4
May 12, 2010 | Sharp AR-5316 Advanced Digital Imager...
How do I install developer into my Minolta CS Pro 1083 copier?
Sir for developer will require you to remove the image unit then clean out the old developer and add new. Then run the service mode F8. Be careful of the drum keep it dark /covered. Recommened a technician for this
Apr 24, 2010 | Minolta EP1083 CS/PRO Copier
The copier is saying please wait image cycling
pls do following steps
1,take one cross over cable
2,download latest firmware from the website
3,upload the firmware using your pc
Oct 27, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
It will not copy after I emptied the waste container.
There really isn't enough information given to give a proper solution. This copier has the drum light come on steady or flashing to indicate the waste toner needs to be removed. I don't know if you're a technician or not but lay people have emptied the toner cartridge instead of removing the drum, removing the cap on top of the drum, emptying the waste toner , replacing the cap on the drum, then putting the drum back into the copier. I've never had a copier keep the drum light on after doing this.
Let me know if you need more help.
Nov 18, 2008 | Canon NP 7130 Black and White Copier
Code cof37
C0F37: Abnormally high toner density detected by Black ATDC Sensor
Toner density that is 4 % or more higher than the target level is detected ten consecutive times during a print cycle, ATVC, or image stabilization sequence.
Check Item
Imaging Unit Bk is installed correctly.
Check and correct ATDC
drawer CN of imaging unit Bk.
Each of Imaging Unit Bk contacts makes
Clean or correct.
good contact.
ATDC Sensor harness is open-circuited.
Change Imaging Unit Bk.
Dec 19, 2007 | Minolta CF2001 Copier
its self adding toner, besure your cartridge is not empty, take it out and shake it side to side. youll feel if its got toner, Remember kids, when you shake up toner, it gathers air and will leak or pour just like water. you may have to turn off & on so it completes its stir cycle a couple times. By they way, i,m not an apprentice or rookie. long time service co owner.
Dec 07, 2007 | Kyocera CS-2050 Black and White Copier
Copystar - CS-3035 Printer Logo
118 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
