Question about Lindhaus Vacuums
Why does my Lindhaus Cannister vacuum shut off after I got thicker carpet and I adjusted the thickness?
I adjust carpet depth but if you stop and don't move the rug beater the sweeper shuts off.
  • 9 Answers
SOURCE: Oreck XL21
You can also set the brush to the middle setting of the special/ normal brush settings. Also, your micro-sweep blade might have popped off making it very hard to push in that direction. The micro-sweep is the plate held by two screws right below the intake with the little blade that sticks up.
Posted on Dec 07, 2007
reddevil6
  • 1673 Answers
SOURCE: beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Posted on Jan 15, 2008
  • 6 Answers
SOURCE: Hoover Windtunnel carpet level adjustment
The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
Posted on Nov 12, 2008
SOURCE: Powerhead woes
I've had my Hoover S3755 for about 2 years and loved it, at least until the last couple of months when the "belt slipping off" problem started. I changed the belt and the vacuum would work for a little while then the belt would come off again. I put on a new belt again and within minutes the belt had slipped off. I took it to my local vacuum repair about 4:00 in the afternoon. By 4:45 I got a call from the repairman that he'd fixed my vacuum! What did he do? He put a different belt on it. He put a Rainbow belt on my Hoover that's thicker and doesn't have as much "give" as the Hoover belt. It's also a little bit wider than the Hoover belt. Now when the brush slows or stops at a carpet edge the belt doesn't slide off.
Posted on Jan 31, 2009
Vac Belts
  • 701 Answers
SOURCE: Bissell Pet Hair Erase does not vacuum.
It is because the belt is worn or stretched and needs to be replaced. Here are the belts you need and the manual which has instructions:
Bissell Pet Hair Eraser Belts and Manual
Posted on Dec 30, 2009
Mt dyson has too much suction
Hi there, it's Jack at Dyson.
I'm sorry to hear you feel your DC40 has too much suction. This sounds unusual, and in order to help you resolve things we would need to take some further details about your machine, and the particular flooring type you're having difficulty with.
When you have your machine to hand, please call us directly so we can talk you through some simple troubleshooting checks to make sure everything is correct with your DC40. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Sep 27, 2014 | Dyson DC40 Animal Upright Vacuum -...
Why does The beater bar on my hoover continue to run in the upright position?
Hi there! Some vacuums do not come with the feature that automatically shuts the brushes off when in the upright position.. If your unit is like this, be sure to put the vacuum on the highest setting when using the hose. Also, because the brush-roll continues to spin, avoid tipping cleaner or setting it on furniture, fringed area rugs, or carpeted stairs during tool use. Hope this was helpful!
Jul 21, 2014 | Hoover Vacuums
Need belt 38528- brush belt
belts will stretch when they slip. There no adjustments on beater-bars. The way to prevent this is to have a height adjustment to be high on high pile and low for low pile rugs.
Oct 28, 2013 | Hoover U5780-900 Windtunnel Cyclonic...
I have a Hoover Windtunnel vacuum cleaner and new high pile carpet. The vacuum cleaner will not move forward without extreme effort. I have been told that I need a vacuum without a beater bar and that...
you can adjust the height on some vacumes like for bare floors and medium nap it will adjust how far the beater bar is from the carpet see if your is adjustable
Apr 11, 2011 | Vacuums
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
Is the Dyson pulling carpet fibers, not dirt ?
You need to shut the brush roll off. It is ruining your rugs, the dyson has a very aggressive roller and can hurt some types of rugs and carpets.
Aug 17, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
Jun 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Chatter
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11557&thid=576381
Chatter
Posted by CANRN on May 06, 2008
We have a Kirby Ultimate G. Since we purchased it bounces across the floor and the level of the sweeper has nothing to do with it. To get it to stop, it has to be at the highest level. The place we bought it, has done nothing to help us. We tried a new beater brush, no help. If I have to use it at it's highest level to sweep my carpet, I might as well not waste my time. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Kirby Ultimate G Bagged Upright Vacuum
The only thing I can suggest is that the brushroll could be in backwards, as you look @ the bottom of the brushroll from the bottom plate, the head of the screws should be facing the floor on each side of the brushroll, so check the brushroll because I thing that is what is happening, what you can do is adjust the brushroll down using the screws doing a ¼ or ½ turn
Until the brushroll stops bouncing across the floor, once you get it adjusted correctly then raise the height adjustment to the highest level and adjust downward to listen for the tone to change and then try it, it should work and if not go down one more adjustment – also change the belt every 4 to 6 months as recommended by the manufacturer. Feel free to contact a local vac dealer in your area for the brushroll height adjustment if you have problems. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
For a owner manual contact the Kirby Factory Dealer.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Don – The Vac Man
Go Ahead. Use Us.
May 06, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Agitator stops when sweeper is pulled backward
If you have made no changes to the vacuum's setup and are using it on same carpet you have previously used it on with no problem, then the most likely cause is the agitator/beater bar's drive belt is worn or on some models may have a tension adjustment which is set too loosely. This can also be caused by having the vacuums height adjustment set to low for the carpet or flooring you are using it on, causing to much drag when the vacuum is pulled backwards for the agitator to overcome.
The vast majority of agitators turn in a forward direction, as if it would pull the vacuum forward, when you pull the vacuum backwards the drag is increased.
So...First check height adjustment (a no cost fix), then check out the tension adjustment (if present on you model, some engage when top of vacuum is tilted back after stepping on the release pedal) Lastly, consider changing belt especially if you have had the vacuum awhile or if it gets a fair amount of use or it you seem to need to use it on a low height setting all the time to vacuum up debris.
Hope this helps!
Dec 19, 2007 | Kenmore 34923 / 34925 Progressive Bagged...
Vacuums Logo
Top Lindhaus Vacuums Experts
vince
ray gallant
Are you a Lindhaus Vacuum Expert? Answer questions, earn points and help others
