Question about NorStar T7316E Corded Phone
How do I move where the red message lights up?
I need to move the location of where the red message light currently lights up on within the network. How do I change which phone lights up when there is a voicemail?
4 Suggested Answers
  • 537 Answers
SOURCE: Changing MAIN voicemail announcement
I am not a phone installer and we have another vendors' phone system here at our work.
It can be *extremely* difficult setting up these phone systems, even with a manual.
Here is one such link that might help:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
Here is another forum that has lots of friendly folks that might be able to help
http://www.sundance-communications.com/forum/ultimatebb.php?/ubb/forum/f/8.html
You will get an answer much sooner on there than here probably.
Mike
Posted on Nov 09, 2007
futureloginn
  • 734 Answers
SOURCE: Message Light Remains on
reset your system--Try the following steps--1) Feature 983, Log 120000, mBox, Change, enter mBox #(i.e.-24), hold Reset....
this changes current password to default password 0000 for mBox #(i.e.-24).
Next....
2)Feature 981, Other (do not enter password, instead go to "Log"), now enter the mBox # (i.e.-24) plus default password 0000 (i.e.-240000).
Next....
3) Follow voice prompt to change password (cannot start with #0), Re-enter new password (i.e.-246810), Say name clearly, Play name back, if satisfied then OK.
Next....
4)When accessing mBox, Feature 981, Other (shows "Log"), enter mBox # plus new password (i.e.-24246810), this is how you will now access your mBox.
Thanks
Posted on Nov 26, 2008
consultel1
  • 860 Answers
SOURCE: The voicemail light stays on
More than likely a co-worker used the "send message" feature on thier set. Under where it says "message for you" one of the soft keys should say MSG. Press the MSG soft key then the ERASE soft key. That will return your screen to normal.
Posted on Jan 20, 2011
Red light
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Aug 05, 2014 | Uniden DECT 6.0 2 Line Corded/Cordless...
What does a red light and a flashing yeallow light mean on a honeywell gsm radio
RED FAULT ON - No contact with network.
OFF- Normal.
SLOW BLINK - Loss of communication with the panel (ECP fault).
FAST BLINK - No network contact AND loss of communication with the panel.
YELLOW MESSAGE ON - Message transmission pending.
QUICK PERIODIC BLINK - Normal
FAST BLINK - Message waiting for network ACK.
SLOW BLINK - In unison with green LED - Registration in progress.
Hope this helps, all of this was found in the manual :P
http://site.geoarm.com/pdfs/Honeywell/gsmvlp-install-guide.pdf
Jul 21, 2014 | Honeywell Ademco / GSMVLP-KT - GSM Radio...
Battery light on my message center
Hello...A red battery light or image usually means there is a problem with your charging system..either your alterator is either not operating or emitting low voltage usually because of diode failure...alternators generate Alternator Current(AC) which is the same of household current...but the vehicle can not use this...It doesn't even register...The alternator has diodes which convert AC current to DC(Direct Current) which the vehicle can use....If the alternator is not doing it's job...The vehicle will pull current from the battery while the vehicle is operating..which is not good.The alternator should be able to run the vehicle...all the accessories...and charge the battery all at the same time...Drive it into an auto parts store and have them test your charging system before you get stranded...and most of the time...the car will die at night because of the headlights.....Let me know what happens...I hope this was helpful.....PEACE.....
Feb 01, 2012 | 2002 Oldsmobile Silhouette
Need to set the timer properly. No instructions to follow. Want lights to come on at 6PM and off at 6AM. the timer has red and black pegs on the timer, HEL:P
Experiment with the timer.
Hook up the lights and timer. And read resource link below.
Put the trippers on the dial. Put red at 6pm and black at 6am.
Then manually rotate the dial two revolutions.
Turn the override knob to different setting, and then manually rotate the dial two revolutions.
Watch what the lights do as you rotate timer dial.
Then rotate dial two revolutions until current time lines up with stationary arrowhead located on inner dial.
The clock motor located inside timer rotates the dial, and trippers move small switch that turns lights on-and-off.
More resources with important tips for power pack:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/How-to-set-timers.html
Sep 27, 2011 | Malibu ML88TL 88Watt Low Voltage Power...
WANT TO REMOVE COUNTRY LOCK 5800 NOKIA MUSIC EXPRESS
You basically can't do it yourself, what they always do with such kind of complications is you visit any Nokia store that is at your current location(country) and ask them to configure your phone to currently accept the new location that you are in.
Because most of the countries they always have their forms of networks that could either work within the different countries or just within the specific country region. It is simple, it will not take a while,they will change it to suit your current location.
Dec 11, 2010 | Nokia 5800 XpressMusic Smartphone
I have a 32PFL5332D and when power turned on red light flashes 6 times then stops blinking for 3 seconds and starts again over and over. TV never powers up
Im afraid the set is probably in an over current protection mode wherebye it shuts down to protect itself as one aaea of the tv is drawing excess current, the pattern of flashes will have a code which would guide a techie to problem area, im afraid you will need an engineer visit,sorry George
Nov 03, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
I need a manual for UTILITECH #0148373.. and i need it now! PLease help me..i need to know how to use this product. HELP PLZ!
Open following link to correctly identify product:
http://cgi.ebay.it/UTILITECH-2-OUTLET-TIMER-0148373-15-AMP-LOT-OF-4-/290468257053
Utilitec 0148373 timer is plug-in type timer.
Set on-off times by moving pins.
Pins are located on dial and stick up. They can be moved back and forth like stick-shift on car.
See example of pins at following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Instructions:
Turn ON lamp.
Light bulb is good.
Plug lamp into timer.
Plug timer into outlet.
Move some pins outward.
Then manually rotate dial clockwise to watch how lights turn on-off.
That will tell you if lights turn on or off when pins are set outward.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial turns as time passes.
Lever on top of timer is moved to 'Timer'
Dec 30, 2009 | Kitchen Appliances - Others
I am needing an instruction manual for rinnai energysaver 556/FTR as have purchased and moved into property recently and am having trouble operating the heater and am concerned with a red filter light that...
www.rinnai.co.nz
navigate to tradesmart, space heating, energysavers.
Red filter light means the filter is blocked.
its located directly on the back of the heater and the wall spacer, from the control panel, its about 4 inches back.
Pull it up, clean reinstall
Apr 27, 2009 | Heating & Cooling
Flashing Lights
The flashing lights meen there is a configureation problem with your snapgear. Check your settings to make sure thay are current for your new location. Just because you own an IP/DNS from one service does not mean that it will be valid from another service. Some services use a system where you set your router to DHCP and they assign you your static IP/DNS. Also Snapgear routers have configurable ports so they are going to be picky about what is plugged into what port. Hope this helps
Jun 26, 2008 | SnapGear SME 550 (990065) Firewall
Constant Red Light on Control Panel Circuit Board
The red light under the cover of the humidistat is fault light. This light typically indicates that there is an issue with your connection at the two wiring terminals labeled ODT on the humidistat. I would recommend checking to confirm that there is something currently connected to the two terminals. As a side note these two terminals can not be jumped out with a jumper, and must utilize either the outdoor temperature sensor (part 8052) or the manual mode resistor (part 4336).
Dec 08, 2007 | Aprilaire 400 Humidifier
NorStar T7316E Corded Phone Logo
12 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
