Question about Electrolux Epic 6500 Vacuum
Power nozzle motor will not turn on
I have an electrolux 6500 seriers canister vacuum. Vacuum works fine but now when I use the power nozzle portion for the rug the brush underneath doesn't turn and the motor for the nozzle doesn't turn on. Any ideas as to why would be greatly appreciated. Thanks
  • mp519rovin May 11, 2010
    I am also having the same problem, except in a different scenario. The power nozzle used to work fine, then when the basic tube sucked up a ping-pong ball, it got stuck at the first separation point on the extender. After removing the ping-pong ball, I reattached the power nozzle, but when I turn the vacuum cleaner on, the power nozzle will only spin when upside-down or in a certain position upside-right. The problem seems to be with the power nozzle. What could this be, and how would I fix this?
  • 73 Answers
Try hitting the reset button,It is a small button on the top of the brush and make sure the switch is turned on on the handle.
Posted on Aug 28, 2009
Power head does not work canister does . There is voltage at the power head.
Although it could be a multitude of things that keep the power nozzle from operating properly, the most likely is, since it's an Epic series, Is that the power nozzle elbow assembly needs replaced as the fine wires and top of the elbow tend to break/short after 5-10 yrs. of use.
It's also very well possible that the power nozzle reset switch or hose switch at top of handle is defective. Try plugging the power nozzle directly into the hose handle assembly and turn machine on. If the power nozzle still doesn't work, it's definitely a problem directly with the power nozzle.
Hope that helps!
Mick
Mar 14, 2015 | Electrolux Epic 6500 Vacuum
Electrolux 6500 sr what do the symbols on top of the canister mean when they are red?
the red symbol probably is the temperature light.This means you motor is over heated.Check hose,wand and power head for a block...Chris
Jun 06, 2014 | Electrolux Epic 6500 Vacuum
How do i replace the hose on electrolux epic series 6500 canister vacuum
Cheap fix: DuckTape around the connections will work great
May 10, 2014 | Electrolux Vacuums
Electrolux epic 6500 power nozzle works when the wand is held turned to the left and then shuts off.
The wiring is defective, more than likely the copper conductor is broken inside the insulated outer covering. This should be a very inexpensive repair at any Vacuum cleaner repair shop.
Nov 28, 2011 | Electrolux Epic 6500 Vacuum
There is a light on the top that looks like a cord that is on. the vacuum hose attachment does not work. I just changed a bag did i do something wrong
The light with a cord "plug" on it indicates that there is power coming to the vacuum. This is normal.
Assuming that the vacuum works, but not the power nozzle, turn the PN over to view the brush. Clear all hair, thread, fibers, etc., that may be wrapped aroung the brush. Use a sharp knife or scissors to cut through them for ease of removal. Make sure the ends of the brush are cleared as well. Try the vacuum and press the reset switch on the PN. Does it work?
Is the PN motor running, but the brush isn't spinning. Turn PN over and try to spin the brush. If it turns freely, the belt is broken and needs replaced. This should be done by an authorized Aerus Electrolux service tech to avoid incorrect reassembly and resulting damage to vacuum and owner.
If the brush doesn't freely spin, but turns with resistance, this is normal.
If it still doesn't work, try the Sidekick mini power nozzle that should have come with it. If it works, but the full size PN doesn't, there's a problem with the PN. It needs to be taken to an authorized Aerus Electrolux store for diagnosis (free) and repair.
If the Sidekick doesn't work, the problem is in the hose, wands, or canister. It could be due to bad switches, wiring, and other electrical problems. In this case, the entire vacuum needs to be taken to an authorized Aerus Electrolux dealer for diagnosis and needed repairs.
http://www.aerushome.com/storelocator/
Mar 06, 2011 | Electrolux Epic 6500 Vacuum
My electrolux Epic 6500 power nozzle Model N109J will not work. It had an intermittent short which I thought I fixed (some of the insulation on the wires were pinched). I fixed the wires and it worked...
The switch is definitely a possibility, but other problems can also cause this.
Bad switch, needs replaced.
Broken wiring in power nozzle, wands, hose, or canister.
Bad PN motor.
I strongly recommend taking it to the nearest authorized Aerus Electrolux store for a diagnosis (should be free). Allowing them to do any repairs necessary is recommended, as well. This will ensure it's done correctly.
Feb 23, 2011 | Electrolux Epic 6500 Vacuum
My Epic 6500 power head will not turn on. Had to push the reset many times the last time it ran, and now it will not turn on. Help!
Does the power nozzle motor come on? Is it just that the brush won't turn? If it's just the brush not rotating, the belt probably broke and needs replaced.
Is the brush clean? If not, clean all threads, etc. off.
Check all wire connections for breaks, cracks, and discoloration. Power nozzle to wand, wand to wand, wand to hose. If any of those are found, that part, and probably the one it connects to. will need replaced.
Ensure all connections are snug.
Internal wiring, including connections, could be bad. This would include wiring in the power nozzle, wands, hose, or canister.
Reset or hose switch could be bad. These would need replaced.
Power nozzle motor could be bad. Generally the belt will break before the motor burns out, but it's possible it's didn't.
For any internal repairs, including belt replacement, the entire vacuum should be taken to an authorized Aerus Electrolux dealer. The service technician can also troubleshoot and find the problem. This is generally done at no charge.
You've got a great machine, and with proper care and maintenance it should last for years to come.
Dec 22, 2010 | Electrolux Epic 6500 Vacuum
The motor running the beater bar on ny Electrolux canister vacuum cleaner runs intermittently. It runs about 2 minutes and then cuts off and automatically starts again after a 1 to 2 minute interval. I...
Check all the wiring connections to make sure they're tight.
1/2. Wiring to power nozzle motor or reset switch is loose.
1. Cord from power nozzle to upper wand. If the plastic portion of the wand is cracked near the cord connection, or the connections are blackened, they need replaced.
2. Wiring connection from hose handle to upper wand. Check for cracks and discoloration as in 1 above. Replace if necessary.
3. Hose connection to vacuum. Not likely, but possible.
4. There could very well be a break in the hose wiring.
You may need to take your vacuum, with hose and power nozzle, to an authorized Aerus Electrux service shop. They can try a new hoze to see if that's the problem. If there is a break in the wiring, the hose is probably worn in other areas as well, and should be replaced.
Oct 16, 2010 | Electrolux UltraLux 2000 Bagged Canister...
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
Vacuums Logo
391 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
