Question about Deni 9735 4.2-quart Easy View Electric Pressure Cooker
How can i control its temperature?
I mean to ask if it comes with a feature to control the temperature of the pressure cooker however i prefer by myself or i can only choose from a list of specific stews
Can I adjust the weight on a tower 2824h pressure cooker.I need to have 5lbs pressure and the weight is 15lbs and I do not have any instructions
Not sure I can help. Found this:
Tower 2824 12 Family Pressure Cooker (in the description: "The Family Pressure Cooker features three pressure setting controls")
The manual should have some instructions if your cooker regulator weight is adjustable. If not, try contacting manufacturer support.
Product Manuals
http://missvickie.com/workshop/table.html
Jun 08, 2016 | Crock Pots & Slow Cookers
Do the low and high settings mean 10 and 20 pounds pressure
It depends on your pressure cooker brand - each one has a different setting. For pressure cookers that reach 15psi (pounds per square inch) the high setting would be 15 and the low setting would be 8 pounds of pressure. For electric pressure cookers the high pressure is generally 12psi the low pressure setting is generally 6 psi.
FYI: No domestic pressure cooker reaches 20 pounds of pressure.
More info about pressure here:
http://www.hippressurecooking.com/pressure-cooker-psi-faq-the-stuff-you-didnt-think-to-ask/
Oct 14, 2015 | Home
I need a manual for miu france pressure cooker model 95080
MIU France produced a video to explain how the pressure cooker works. You can view it here:
http://www.youtube.com/watch?v=qJhVqdx7f9M&feature=c4-overview&list=UUk09IwTBUtsp_BCGLXF6QYw
You might want to check the Free Pressure Cooker Manual library occasionally - if the manual you're looking for isn't there they'll likely add it soon!
http://www.hippressurecooking.com/pressure-cooker-manual-library/
Apr 11, 2013 | Wolfgang Puck Electric Pressure Cooker...
Can you use pressure cookers on glass/ ceramic cooking ranges?
It's not advisable but it also depends what type of pressure cooker you have. Many of them have a concave bottom and that means the bottom is mostly not in contact with the heat source, so the heat doesn't transfer properly and the cooker wont come up to pressure.
Feb 14, 2013 | Home
I am interested in buying a pressure cooker as I have heard they are really healthy good ways of cooking, but I remember my grandma had a pressure cooker and it was so noisy and huge. Are they still like...
I know what you mean. My grandma also had a pressure cooker that hissed and rattled like that, but I bought one last year and I can promise you that they have changed so much since then. Mine is much more sleek than hers was and it's completely silent. Also I just think it's much safer as the opening valves are better and the features much more civilized.
Feb 14, 2013 | Home
What is an electric pressure cooker?
Pressure Cookers are cookers where you can cook food with air coming in or out or liquid coming in or out. you are able to control the pressure in the cooker so you can cook the food the exact amount that you desire.
Feb 13, 2013 | Kitchen Appliances - Others
Bought a new pressure cooker from Williams-Sonoma and it had a DVD to explain it's features. The DVD does not work. When I put it in my computer, the graphics come up, but it won't play. ...
Not sure which pressure cooker model you have.
HOwever, if you visit this website it has YouTube videos that explain the features of the pressure cooker.
Otherwise you could drop a note to Williams-Sonoma requesting replacement DVD at this site.
Jul 06, 2011 | Microwave Ovens
Pressure cooker controls. what do the 3 symbols on top mean on the fagor pressure cooker
The circle with a slash through it means that you can remove the valve, the little cloud spraying means pressure release and the next symbol, or numbers, indicated pressure.
You can get a more detailed description in the manual for your pressure cooker, which you can find here:
http://www.hippressurecooking.com/category/fagor/
Mar 11, 2011 | Vacuums
Cuisinart cpc600. What is causing erratic operation?
The recipe in it does not contain enough liquid, or the liquid is too thick, for it to reach and maintain pressure. Since the heat-up time to pressure is taking too long the cooker is shutting off.
Use tested, reliable recipes without condensed soups, flavor packets or jarred sauces. Don't worry, there are plenty!
http://www.hippressurecooking.com/pressure-cooker-recipes/
Dec 13, 2010 | Home
How do i use the pressure cooker? After adding water and beans, I let it come to boil and the steam noise is steady....then I turn down the heat? At the end I let out the steam manually, turn off and open...
Add the water and beans. Put the lid on the cooker and tighten down. Turn on the heat and let the steam make a full plume before closing the valve. Lower the temperature to medium. Watch the gauge and when it reaches the correct pressure keep adjusting the heat to maintain the pressure for however many minutes the beans need to cook. When the time is up turn off the heat and let the cooker cool for a while. Ten minutes or so. Then slowly open the pressure valve when the pressure has reduced to a low level. If the pressure is still to high when you open the valve the water will be pulled out of the beans and the jars will only be half full of liquid. Once the pressure is down to zero, open the lid carefully because the jars are still hot and break easily. As the jars cool you will hear them pop. This means that they are sealed. Good luck.
Jun 15, 2009 | Kitchen Appliances - Others
Deni 9735 4.2-quart Easy View Electric Pressure Cooker Logo
29 people viewed this question
Top Deni Kitchen Appliances - Others Experts
Tom Chichester
Tim Rickards
Tim Rickards
Are you a Deni Kitchen Appliances - Other Expert? Answer questions, earn points and help others
