Question about Packard Bell Winfast Mcp61dm2ma-8ers2h Am2
MB Winfast MCP61DM2MA-8ERS2H manual pdf - Packard Bell Winfast Mcp61dm2ma-8ers2h Am2
I have a packard bell winfast mcp61dm2ma-8ers2h mother board, with a gigabyte ge-c3209-a2 power box that is in a gigabyte 24zm1-bpd715-32r chassi. I recently took the whole thing apart to clear all the...
The first thing I would do after I copied off all personal info, is to smash that computer into little tiny pieces, pack it in a box, and ship it to Peckerd Bell. "Here.........this is whqat I think of your computers, and your 'support'." (Support = $$$$$$)
OH, did I say that out loud? My bad. lol!
Rant off.
I love the nomenclature you used Jan. You are definitely my kind of people! (Power box)
1) Let's go back to the beginning Jan, and look at the 3 power cables to motherboard;
http://www.ebay.co.uk/itm/PACKARD-BELL-Winfast-MCP61DM2MA-8ERS2H-AM2-/130457057251?nma=true&si=BtiiltyOkHpDiIr8VnpbUWON7BQ%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
I see that a 24-pin ATX main power cable, plugs into the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
[NOTE* Color of connectors does NOT matter]
,and a 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Yours plugs into the white square 4-socket hole connector, that is by the Top/Left corner of the motherboard.
That's it for power cables from Power Supply, TO motherboard.
The SATA harddrive also requires a power cable. A SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Note that a SATA power cable's connector has 15 contact pins.
Between it, and a SATA data cable, it has the longer connector.
A SATA data cable's connector has 7-pins,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
The SATA data cable example is at top.
A SATA motherboard connector example is at bottom.
YOUR SATA connectors look different. They are the two Blue connectors below the Ram Memory slots, and to the left of the black round piezo buzzer.
Note the L-shaped opening of the SATA data cable connector.
The SATA power cable connector also has this L-shaped opening.
Lines up with the L-shape on the motherboard connector, or Harddrive, or Optical Drive, connector.
The SATA data cable connector, and the SATA power cable connector; may also have a Lock on them.
Usually a small bulb type of affair, that you depress with your thumb.
Depress the Lock to install, or remove.
The SATA cable connector, power or data; that goes to the Harddrive, or Optical Drive; is usually a 90 degree bent elbow.
The connector end of the SATA data cable to motherboard; is a Straight connector.
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
Sometimes abbreviated as FP_PANEL, or FP, or FP1, or PANEL; just to name a few abbreviations.
Does it look like this Jan?
http://www.intel.com/support/motherboards/desktop/sb/CS-009016.htm
Wiring from the Front Panel.
No easy guessing game here. Color code you have MAY be right, may be not.
Remove the Front Panel. See where the wires lead up to.
Wires that go to the Power On switch, and Power On LED, may be in the same area; but the HDD LED is away from them, and should be easy to spot.
Now you are down to the Power On switch, and Power On LED wires.
Suggest process of elimination.
It's usually pretty easy to see where the Power On LED wires go.
Right TO the Power On LED.
Now you know the other wires are for the Power On switch.
Still no?
Then remove all wires from the Front Panel header.
According to the info I posted in the link, the Red area's 2 pins are for the Power On switch.
BRIEFLY touch a small flat tipped Jewelers screwdriver, to those 2 pins.
(I state Briefly because the Power On switch is a Momentary Contact Switch. No more than 2 seconds)
Power Supply still doesn't come on?
Then post back in a Comment, and I will state out the simple procedure for testing if the problem is the Power Supply.
For additional questions please post in a Comment.
Regards,
joecoolvette
(It also may be that the 'power box' you are trying to use, doesn't have enough Wattage for that Motherboard/Processor/Ram Memory)
Jan 14, 2013 | Packard Bell Winfast Mcp61dm2ma-8ers2h Am2
I have a winfast A6200 TD 128 mb 128 bits, i inserted the video card in the socket, i turned on the pc and when i reach the welcome screen my pc restarts. what should i do to work.
Boot in Safe Mode and uninstall all video drivers. Reboot at least twice normally then download and install the latest driver from
http://www.nvidia.com/Download/index.aspx?lang=en-us
Feb 17, 2011 | Leadtek WinFast A6200 TD GeForce 6200 (128...
Where can I find an online manual for this, as I have one but no manual, and the leadtek site gives wrong motherboard for same code.
The PRO has the same manual of this one:
WinFast K7NCR18DM/GM/DLM user's manual
Total size::[1458 KB]
ftp://ftp.leadtek.com/mb/K7NCR18G/manual/K7NCR18-m_manual(E).pdf
http://www.leadtek.com/downloads/?lang=eng&filepath=/mb/K7NCR18G/manual/&filename=K7NCR18-m_manual%28E%29.pdf
Regards,
PDG
May 11, 2010 | Leadtek WinFast K7NCR18G-Pro Motherboard
Hy.i have WINFAST A6600 TD 128 MB.here i can find the drivers for that?please help me!
select your operating system from this list download and install driver
http://www.drivers.mrjuan.com/driver-3868-winfast-a6600-td-256mo.html
Tom
Jan 16, 2010 | Leadtek WinFast A6600 TD GeForce 6600,...
I have a Winfast K7S, 741M01C, series motherboard
Hello Friend,
The max RAM that you can use with this motherboard which has 2 RAM slots is 2GB.
Best Regards,
Oct 30, 2009 | Foxconn WinFast K7S741MG Motherboard for...
I NEED THE SOFTWARE FOR the graphics card winfast A6600 TD
The drivers are available from the Leadtek website, see link http://www.leadtek.com.tw/eng/3d_graphic/download.asp?downlineid=157&pronameid=172&lineid=1&act=3
Oct 28, 2009 | Leadtek WinFast A6600 GT TDH GeForce 6600...
Quero upgrate de memoria da winfast k7s741mg qual
Esta placa es compatible con memoria Ram DDR 266/333/400 , y los modulos no pueden ser mas de 512Mb cada, en cuanto la placa no suprota doble densidad.
Aqui el manual en Ingles: Easy Installation Guide
May 06, 2009 | Foxconn WinFast K7S741MG Motherboard for...
A250 WinFast Leadtek card I need driver for it
http://www.filehippo.com/download_nvidia_forceware_xp/download/add02280204cc888658222a96a66fd6a/
alone_rose12@yahoo.com
Apr 18, 2009 | Leadtek WinFast A250 TD (128 MB) Graphic...
Packard Bell Winfast Mcp61dm2ma-8ers2h Am2 Logo
506 people viewed this question
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tony
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
