Question about PfaFF Sewing Machines
Wont run 1471 powers up and lights up but no action when foot switch is pressed, replaced foot switch but still won't run.
3 Suggested Answers
SOURCE: pfaff 1471 foot problem. Foot wont go down all
Try lubricating the pressure foot shaft where it slides up and down (2 Places). To do this you need to remove the left side cover - the flat black screw in the slot under the left side of the carrying handle. Back the screw off slightly and pull off the left side plate. This should allow you to oil the shaft. I use Mobile 1 Synthetic 0W-20 oil. I find it works extremely well, as good or better than sewing machine oil. The problem is caused by the original grease they used when these machines were manufactured. The grease hardens over time (especially if the machine hasn't been used for awhile) and causes the shaft to stick. You might need to use a little penetrating oil initially, especially if the shaft is really stuck. This is a fine machine - good luck... LS.
Posted on Jan 20, 2012
SOURCE: why isn't my husqvarna foot press not connecting giving power for my needle to move. Machine does have power but does not run when pressing foot press.
have you checked to make sure the foot pedal is connected correctly to the machine?
if the foot pedal is connected correctly, then the machine needs to be checked to see why it's not responding
Posted on Mar 27, 2012
I have a Pfaff creative 1471. When I turn it on the light flashes across like normal, but the computer display is blank. The normal little reset of the machine does not occur and the machine will not run....
The 1471 is getting on in years. It is not uncommon for the PC board to develop a fault. It can be replaced, however, cost is prohibitive unless you can find a repairer with a 'good' used board.
Good luck
Oct 19, 2013 | Kenmore 15218 Mechanical Sewing Machine
Sewing machine has mind of it's own
Do you have the right foot for the stitch you are trying to do?
Aug 29, 2012 | PfaFF Sewing Machines
My Shark 7133 slowed down while sewing and stopped. The handwheel won't turn at all. I cleaned the bobbin area but it still won't work. The light switches on and the machine motor reves up but...
Slacken the stop motion as if to wind a bobbin and press on the foot control, if the motor runs really fast then you have either thread stuck in the bobbin case area or you may need to oil the machine
Sep 01, 2011 | Euro-Pro Shark 80 - 7133
I have a pfaff creative 1471 and it seems like the pressure foot, when raised, then lowered, doesn't have the proper down pressure. It sticks in the up position, then when I pull it down, it sorta snaps...
Can't believe no one answered you. I would highly suggest you take it in. From my searching around learning about the Pfaff 1471 I was just given. I found it is a very good machine and well worth spending well up to 500 to keep it in good shape. I just had to cut back on the extra I pay on my car payment just to pay the 150.00 tune up on her (ouch). But she runs like a dream now. The machine is so good I didn't even notice she needed it. What you seem to be saying wrong seem to be the most common thing I have read goes wrong with the 1471. I get there is a spring that gets gummed up. It should be replaced/cleaned and regressed by a pro. If its as common as it sounds shouldn't cost more than what I paid.
Mar 29, 2010 | PfaFF Sewing Machines
Pfaff 1471 foot problem. Foot wont go down all the way, I have to press on it manually and hold with a finger for the foot to stay down for enough pressure to run over the fabric. feed dogs are up. Not...
Dec 10, 2009 | PfaFF Sewing Machines
Powers up, then "all" lights are on and does nothing.
The machine that only lights up has a circuit board problem and should be seen by a technician. The machine that has a tension problem can probably be repaired by removing a piece of thread which is inside the tension discs.First do a tension test and then follow these instructions.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} (To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Apr 15, 2009 | Sewing Machines
Presser foot 7 lever on Pfaff 1471
You may not be using the correct presser foot for your machine.
Sewing Machine Feet
You may be using a low shank when your machine needs a high shank.
May 12, 2017 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
59 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
