Question about ASUS Eee 4G Notebook
No wireless network - ASUS Eee 4G Notebook
  • MrObvious
    MrObvious May 11, 2010
    More information, please
    Problem Solver:
  • 5 Answers
You will have to find the latest appropriate drivers from the manufactures website or from a disk with t
Posted on Jun 22, 2009
Hi i am using the pc sony vaio i have the problem on wireless adabter it was in desable mode and difficutl to active it ,while i am useing the bottom in front of pc on and off of wirless adabtor but i i on...
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
Dec 12, 2010 | HP Broadcom NetXtreme Network Adapter
My computer died we redid widows xp disk and it came back now i dont have wireless how do i get it back
Hi, you will need to reinstall the wireless card drivers, if this came with wireless as standard you should be able to download the drivers from the manufacturers support website, if it was added later on then it should have came with an install disc with the drivers on it.
Hope this helps
John
Dec 02, 2010 | Computers & Internet
Virgin has installed. D link wireless router (home address) I have 2 laptop xp window vista and pc upstair they detect the vg 50Mb broadband but can not connect ! When I go with my 2 lap top elsewhere I...
1.
2.
3.
• To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
• To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
4.
• To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
Important
• If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 30, 2010 | D-Link DIR-300 Wireless Router
I have a new toshiba laptop that I can't get to connect w/o wires to my lynksys...how do I get my laptop to be wireless??
In order for the wireless computer to connect to the router wirelessly, the router and the computer's wireless settings should be the same. Before trying to connect your wireless adapter to a Linksys wireless router, please know the following: SSID or Network Name, Wireless Security and/or Network Key.
Connecting to Wireless Networks Using XP's Wireless Zero Configuration
To connect to the wireless network using Windows Vista, click here.
Follow these steps to connect to your wireless network using XP's Wireless Zero Configuration.
Step 1: Right-click the Wireless Network Connection icon at the bottom-right of the screen and select View Available Wireless Networks.
NOTE: If Wireless Zero Configuration (WZC) is disabled or other wireless network monitor is running, the Wireless Network Connection will not appear at the bottom-right corner. To enable WZC on the computer, contact Microsoft or consult the computer manufacturer.
Step 2:
Select your wireless network
Nov 05, 2010 | Computers & Internet
Can not connect to network
Connecting to a Wireless Network Using Linksys Wireless Manager Article ID: 17673
Follow these instructions to connect to a wireless network using the Linksys Wireless Manager.
Step 1:
Launch the Linksys Wireless Manager. To learn how to access the Linksys Wireless Manager, click here.
Step 2:
In the Connect to a Wireless Network screen, locate the name of your wireless network in the list.
NOTE: If your wireless network is not in the list, click here to learn How to Connect to a Hidden Wireless Network. If your wireless network supports Wi-Fi Protected Setup kb17673-005_en.png, click here to learn How to Connect Using Wi-Fi Protected Setup.
Step 3:
Select your network. Then click Connect.
Step 4:
If the wireless network uses wireless security, enter the security key or network. Then click Next.
Step 5:
The Checking Connection screen appears while the Wireless Manager establishes the wireless connection. When it is finished, click Next to continue.
Step 6:
The Connected to Your Network screen appears. If you want the Wireless Manager to remember your network settings select Remember this network. Click Finish to exit the Wireless Manager.
NOTE: Saving a network's settings will make it easier to reconnect to the network.
Nov 04, 2010 | Linksys WRT160N Wireless Router
Having trouble with initial connection to an existing wireless network wireless router is a cisco wireless-n broadband router and we have 2 laptops and a printer on a wirelss network already
Step 1:
Step 2:
Step 3:
Nov 01, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
I need help to get my sons xbox working with a wireless adapter
Hi Joanne,
If the wireless adaptor is the one shown in your picture, you simply plug it in the back in the USB slot.
Configure your wireless settings loadTOCNode(2, 'whattotry');
  1. Go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. Select Configure Network.
  4. On the Basic Settings tab, select Wireless Mode.
  5. Select Scan for Networks.
  6. Select your wireless network name. If your wireless network is not listed, select Specify Unlisted Network and enter your wireless network name.
  7. Enter your wireless network password, and then select Done.
  8. Press B on your controller to retest your connection.
Kind regards
m-press.biz
Jun 15, 2010 | Microsoft Wireless Network Adapter Xbox...
Cant get wireless router to work on laptop
First, try to connect your laptop hardwired to the router, if it works fine, its just the wireless configuration. Make sure you are using the correct wireless network key to connect to your wireless network. Go to the Control Panel > Network Connections > Right-click Wireless Network Connection > Properties > Wireless Networks Tab and delete all the names listed under Preferred Networks box. Click Ok. Right-click on Wireless Network Connection again > View Available Wireless Network > Choose your own network and click Connect. If it asks you to type the network key, type in your WEP or Wireless Network Key and press connect. That should do it.
Oct 06, 2009 | Computers & Internet
I can't get it to work.
To view the wireless network connection dialog box, follow these steps:
  1. Click Start, Run, and type ncpa.cpl, and then click Ok.
  2. Right-click the Wireless Network Connection icon, and then choose Properties. (Or you can right click the Wireless Network Connection icon and choose View Available Wireless Networks from the shortcut menu.)
  3. Click the Wireless Networks tab.
  4. Under Available networks, click the View Wireless Networks button.
From the wireless network dialog box, you can refresh the network list. This performs another scan of wireless networks within range. The wireless network connection dialog displays the following for each detected network. The following shows the new connection box.
When the wireless network adapter displays the detected networks, you'll able to select a wireless network name and attempt to connect to it. The antenna icon indicates an infrastructure mode wireless network. The icon that shows two wireless client computers indicates an ad hoc wireless connection.
The lock icon and the "Security-enabled wireless network" label indicate that the wireless network has security enabled. The gold lock means you need a network key in order for you to connect to a wireless network. If it's not security enabled, you'll be able to connect to the network without a network key.
Apr 28, 2009 | Airlink AWLH3026T 802.11g/b Wireless...
Connecting copier machine wireless
Configuration using a wireless computer.
  1. If your computer has wireless capability, you will need to change the wireless settings of your computer to Ad-hoc mode so you can directly connect and configure the printer.
  2. Wireless network terms and concepts
    When you configure the wireless network printer, you must ensure that your wireless network printer is
    configured to match the settings of the existing wireless network. This section provides some of the main
    terms and concepts of these settings, which may be helpful when you configure the wireless network printer.
    SSID (Service Set Identifier) and channels
    You need to configure the SSID and a channel to specify the wireless network you want to connect to.
    SSID
    Each wireless network has its own unique network name and it is technically referred to as SSID or ESSID
    (Extended Service Set Identifier). The SSID is a 32-byte or less value and is assigned to the access point.
    The wireless network devices you want to associate to the wireless network should match the access point.
    The access point and wireless network devices regularly send wireless packets (referred to as a beacon)
    which has the SSID information. When your wireless network device receives a beacon, you can identify the
    wireless network that is close enough for the radio waves to reach your device.
    Channels
    Wireless networks use channels. Each wireless channel is on a different frequency. There are up to 14 different channels that can be used when using a wireless network. However, in many countries the number of channels available are restricted. For further information, see Ethernet wireless network on page 165.
    Authentication and encryption Most wireless networks use some kind of security settings. These security settings define the authentication (how the device identifies itself to the network) and encryption (how the data is encrypted as it is sent on the
    network). If you do not correctly specify these options when you are configuring your Brother wireless device, it will not be able to connect to the wireless network. Therefore care must be taken when configuring these options. Please refer to the information below to see which authentication and encryption methods your Brother wireless device supports.
    Authentication methods
    The Brother printer supports the following methods:
    • Open system
    Wireless devices are allowed access the network without any authentication.
    • Shared key
    A secret pre-determined key is shared by all devices that will access the wireless network.
    The Brother printer uses the WEP keys as the pre-determined key.
  3. I will advise you download this network manual and follow the instructions on chapters 3 and 4.
  4. Network Users Manual - English
Apr 15, 2009 | Brother HL-4070CDW Printer
ASUS Eee 4G Notebook Logo
43 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
