Question about Canon imageFORMULA DR-C130 Document Scanner
Reset counter dr-c130 - Canon imageFORMULA DR-C130 Document Scanner
Canon c130 copier stuck in middle of copy
Hi Ben,
Please Watch This video and fix your issues.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Mar 04, 2014 | Canon C130F Black and White Copier
Drum error dr-420
Sir/Madam
he following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter,
Or Visit official Brother Printer website For Brother Printer Troubleshooting Page Url Below:http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002800/000037/faq002837_000.html?reg=us&prod=mfc7340_us_as&c=us_ot&lang=en
Or
Still Having Problem then follow Us On For
Brother Printer Support
Jan 14, 2014 | Brother Office Equipment & Supplies
How to reset counter on canon dr 7580
You need to run Qumatool to reset the counter
S. Mohan
Oct 14, 2011 | Canon DR-7580
Reset drum counter for Brother mfc-7225N all in one laser printer?
Brother Drum Reset Instructions:
This works on the Brother DR-510 and many others.
Brother Laser Printers:
After replacing the drum unit, keep the front cover open (make sure the power is on). Press and hold the "GO" button until all four LED's are lit. Once the four LED's light up, close the front cover. Make sure the drum LED is off. The counter is reset!
Aug 24, 2010 | Brother MFC-7225N All-In-One Laser Printer
Reset the drum count on a brother intellifax 2800.
Drum counter is reset by installing a new drum which contains a specifically designed "starter sheet" that is passed through the machine when it is installed, and triggers the paper sensors in a specific pattern, resetting the electronic counter.
If you have installed a new drum and the message remains......I suspect that it was a remanufactured unit that did not include the "starter sheet" Is that the case?
May 03, 2009 | Brother IntelliFAX 2800 Laser Fax
Dr 360 reset procedure
1. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until
you have a print quality problem, then replace the drum unit with a new one.
2. The Drum LED continues to blink if the drum counter was not reset when you replaced
the drum.
To reset the drum follow the instructions below:
a. Open the front cover of the printer.
b. Press and hold down the white button (shown as blue in the image below) for
about 4 seconds until all the LEDs light up. Once all 4 LEDs are lit, release the
button.
c. Close front cover
Feb 02, 2009 | Brother HL-2040 Laser Printer
I can't focus, i don't see nothing!!
are you putting the eracting system on first?
Nov 25, 2008 | Celestron C130 Mak (63x130 mm)
Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
Resetting ink counters on epson c42ux
You can try the other software you can use to reset the counter.
http://www.coldreset.com/modules.php?name=News&file=article&sid=95
Also make sure that on the ssc software, you have selected the correct printer model.
http://www.ianwillis.co.uk/c42/
Mar 24, 2008 | Epson Stylus C42UX InkJet Printer
Canon imageFORMULA DR-C130 Document Scanner Logo
48 people viewed this question
old marine
old marine
