Question about Samsung Computers & Internet
How do I set a ts-524 motorola switch back to factory default?
3 Suggested Answers
  • 903 Answers
SOURCE: PocketPC e570, Is there an opportunity to set it back to factory default?
you could set back the e570 factory default very easily. On the left side of the pda you could find a small button, called RESET button. You have to do these following steps: The pda have to be turned off, then press the power button while pressing and holding the reset switch with the stylus, release the power button and when a screen appears, release the reset switch. But be careful, when you reset your pda all data will be lost and make sure that all storage cards are removed!!!
Posted on Sep 11, 2005
zohail
  • 1223 Answers
SOURCE: Back to factory default. How can I fix?
here is ur manual for Ming just see the 126 page for Master reset
http://www.scribd.com/doc/2623841/Motorola-Ming-A1200
Pls rate me FIXYA fo rhelp
Posted on Apr 15, 2009
What is the password to reset the di 524 router
From D-Link
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password (blank by default), and then click Ok or Log In .
If that doesn't work you will need to reset the router to factory default settings.
Sep 24, 2014 | D-Link AirPlus DI-524 Wireless Router
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
How do i forgot my password for my Dlink Dl-524
to reset the password for your router hold the reset button on the back with a paperclip in for 30 seconds while powered on. This will reset the router back to factory defaults.
the default password is password or 1234 for older devices.
Feb 23, 2012 | D-Link AirPlus DI-524 Wireless Router
Ho to reset D-Link DES-1228P 24-Port Ethernet Switch to factory default setting?
This article teach you how to D-Link router to restore factory settings,di-524 as an example.
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release. (Note: Do not repower unit during this procedure.)
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
I hope this information will be helpful. Thank you for using FixYa!
Jun 08, 2011 | D-Link DES-1228P 24-Port Ethernet Switch
I forgot my parent controls pin
As far as I am aware, the only way to reset the pin, is to reset the router to factory defaults. You will then have to reconfigure your wireless settings. To reset to factory defaults:
Plug in the router.
1. Locate the small reset button. It is next to the power jack.
2. Use something to push the button, a paper clip works well.
3.Hold the reset switch down for 10 seconds.
4. Wait for the WLAN light to stop blinking. The router is now reset.
To reconfigure the settings on the router, enter 192.168.0.1 into your browser address bar.
Mar 14, 2011 | D-Link AirPlus DI-524 Wireless Router
How to connect to 192.168.1.1 for dlink Airplus, User ? password ? I did try "admin" and " admin " or " password " for password but didn't work....thank's
Sounds like you know what your doing. I would reset to factory defaults and try again. You can do this with a paper clip and hit the reset switch (its a very small hole). Then try getting back in using the default settings.
Jan 12, 2011 | D-Link AirPlus DI-524 Wireless Router
Where can I find my DI-524 Username and Password?
If you have not changed it, the default username and password can be:
Username: can be left blank or use "admin"
(without the quotes)
Password: can be left blank or you can use either "password", "1234", "admin"
Jan 03, 2011 | D-Link AirPlus DI-524 Wireless Router
Need passphrase from D-Link router DI-524
1. if the default login never been modified b4, u can hook a network cable to the router, type "192.168.0.1" to enter the router config. Once inside, u can edit the password or disable it.
*U may prompt for username (admin) and passsword(empty).
2. If the default login has been modified and u r not able to enter the router config, u can just reset the router by inserting a pin to the small hole to get back the factory default settings. Then u can perform above step again to reconfigure your wireless router.
Mar 13, 2009 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
Setting up an old router
To perform a reset, please follow steps below:
Note: The factory defaults username is admin, and there is no password.
Mar 30, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 URL no longer responding
yes if you are having problems getting into the router via your browser you may have changed the IP address of the router, so holding in the reset buton for 10 seconds should reset back to factory defaults.
Jun 24, 2007 | D-Link AirPlus DI-524 Wireless Router
Computers & Internet Logo
482 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
