Question about Sanyo DP50747 50 in. Plasma TV
Sanyo vizon dp50747 screen replacement
Where can i buy a screen?
shivam4529
  • 150 Answers
SOURCE: sanyo vizon tv black screen
hiiiiiii here shivam
i want to tell you that that same problem is occuring my computer but now it is fixed
but your problem is of tv don't worry is this is help full to you--
this problem is common on this model. your vertical output circuit has gone bad. but i am sorry to say that a repair cost is to much for a tv this age. a cost would range 100-150. i say invest this into a newer tv. this model was good for 10-12 years and you have got better than that.
good luck :)
let me know if you need more info?
Posted on May 24, 2008
SOURCE: sanyo lcd tv flat
I have researched this problem and it is so common we that own this piece of junk ought to form a class action suit and sue. It is caused by a bad part or bad connections to a part called a backlight inverter. It seems the LCD needs a higher voltage than supplied by the 12vdc power pack so this part re-chops the DC voltage to generate the LCD requirement.
The date of manufacture is on the back of these TVs and all the problems seem to be from those made in 2006 to 2008
Posted on May 05, 2009
  • 222 Answers
SOURCE: 20 SANYO VIZON DOES NOT HAVE MENU BUTTON IN THE TV
The menu button is on your remote control, it is located at the bottom of the input button
Posted on Jun 05, 2010
SOURCE: ysus board number for a sanyo 50'' plasma model dp50747
I just bought a Sanyo DP50747 50 inch plasma. When I pause the tv, then push play (even 1 minute or less) the sound does not start as soon as the picture starts back. I have picture first and no sound for 4 or 5 seconds then the sound continues from that point.
Posted on Mar 21, 2011
SD Tech
  • 14553 Answers
SOURCE: my sanyo vizon dp42647 wont turn on
Some food for thought here the power supply and part of the set:
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
If the set is opened look on the power supply board for caps puffed up like these--dead giveaway.
If you have questions feel free to comment here--I am not the number one rated expert here for the last six weeks for nothing and I do this here for free.
SD TECH
Posted on Apr 18, 2012
Dark cloud on screen of lcd tv sanyo vizon 42''
sanyo is a junk tv, and I will NEVER purchase another....less than 5 years old black clouds on the screen, repairs are cost more than the cost of a new tv.....
May 06, 2010 | Sanyo Vizon LCD-15A2 Television
27' vizon tv black screen
It seems to be a PSU (Power Supply Unit) problem. When you unplug it and replug, the screen comes on for a moment. That means that the capacitor does not hold charge for long. Open the back and look for bulged or burst capacitors on the module where the power cord meets inside. Replace the whole module if you can not replace the capacitor with exactly the same specs.
Nov 07, 2009 | Sanyo Vizon LCD-15A2 Television
My friend T.V. it blinks when you turn it on he has a sanyo vizon it's a L.C.D. flat screen
Probably overheated. Inadequate air circulation. Nothing you can do now. If it's less than 1 year old Sanyo might replace it w/ a refurb. I'd contact them. http://us.sanyo.com/
Oct 01, 2009 | Sanyo Vizon LCD-15A2 Television
50 inch Sanyo Vizon Plasma TV. Has sound but no picture for last few days. 2 years old
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Sep 06, 2009 | Sanyo Televison & Video
Clicks on but screen stays black and then it shuts off
With fair certainty, this is a problem with the main power supply. If no longer under warranty, pull the AC plug overnight to allow stored voltages to discharge before opening the set.
The power supply board is normally separate, visibly related to the AC coming in and has larger parts such as capacitors (cylindrical cases) and block-shaped parts (chokes and transformers). You can probably replace this board yourself but you need to call Sanyo/Vizon to learn whether you can get yours repaired or if you must buy a new one. If you have to buy one, don't toss the failed board since there are independent companies that can repair them for a few dollars less than the cost of a new one. It doesn't hurt to have a spare, these aren't your dad's TVs and are not lasting as long as our previous sets.
Jul 15, 2009 | Sanyo Vizon LCD-15A2 Television
Converting from analog to digital
if you have cable it is digital, if not buy a converter box
Mar 28, 2009 | Sanyo Vizon LCD-15A2 Television
Ysus board number for a sanyo 50'' plasma model dp50747
This is a Sanyo Vizon 50" plasma the model number is DP50747 .. hope this helps the website for this product is www.sanyoctv.com and the phone number is 1-800-877-5032
Mar 16, 2009 | Sanyo DP50747 50 in. Plasma TV
Sanyo vizon tv black screen
Replace 12v ac adapter ( if you can find one ).
Nov 30, 2007 | Sanyo Vizon LCD-15A2 Television
Sanyo DP50747 50 in. Plasma TV Logo
21 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
