Question about Thermador SMW272 Electric Double Oven
How to remove coffee grinder blade? - Thermador SMW272 Electric Double Oven
Neff circo therm need to replace cooling fan
Isolate mains.Remove oven cavity back panel (4/6 phillips or 4/6 Torx 20 screws)Remove fan blade (reverse thread nut)....this is sometimes where you come unstuck, because the blade just won't budge.If that happens I normally then remove the back panel of the unit itself (doesn't need to come all the way off, I will usually leave the mains connections on and let it fall back as far as it will go safely...may have to loosen the cable clamp to get some slack on the mains)You will now see the other side if the fan motor.Remove the L and N (not pole sensitive so they can go on the new one either way).Remove the 3 Torx20 screws holding the fan in position. (some models have an extra spacer ring so be careful you don't lose them)Go back to the cavity and use something to give the motor shaft a whack to release the fan blade, bearing in mind that if it does budge the motor itself is going to fall out the back (stick an old towel etc to cushion the fall and protect the terminal block etc).The new fan usually comes with the blade attached, separate the parts, install the motor, attached electrical connection and then the fan blade, make sure its tight. At this point I would close up the back and just hold in place with one screw and test that the fan works. (don't forget that the oven will not operate when the clock is flashing, so set any time on the clock before selecting circotherm)If everything looks ok, get it back together and in housing and run upto 150 or 200 degrees as a last test.Good luck, let me know how you get on or if you need any further clarification. Please post the outcome as this will assist other users of the site looking for solutions to similar problems.All the Best.
Nov 23, 2011 | Neff U1721 Double circotherm Electric Oven
How hard is it to change the fan? thanks
reasonablly easy allow yourself some time remove oven from housing remove back panel to expose fan motor remove internal back panel to gain access to fan blade undo nut,{it will be tight and is left hand thread e,g tighten to undo} pull of blade turn to back of oven undo three fixing screws that hold motor to back panel detach 2 wires pull off motor reverse to refit.
May 17, 2010 | Neff B1421 Electric Single Oven
How do I remove the fan from an electrolux EGC652 oven
The model no. does not seem correct.but it seems as if the hole in the fan blade which is normally D shaped has worn round.The thread on the shaft is Left handed and you will need to undo by turning clockwise. If you can get a vice grips at the back of the blade to hold the shaft then try again,or you will need to get into the back casing and try jamming the shaft at the motor housing you may need some help.Then if that works you will need to undo the 3 bolts holding the Motor body to the rear casing.The new fan would normally come with new bolts,blade and nut.To tighten fan blade nut use a 10mm socket hold the fan blade and tighten anticlockwise.Hope this is helpful.
Good luck.
May 04, 2010 | Electrolux Ovens
The fan catches as it turns and grinds loudly
Yes, Find out what it is "catching" on and adjust.
Sometimes it is nothing more than a wire pushed too close and begins to ping on the fan blades. If the fan blades are catching on the face plate. See if you can loosen the screws and pull then tighten to allow more space. You do not need much! Drastic solution would be lightly file the edge of the fan blades to provide more clearance.
Caution! You have to file evenly on all blades to keep the balance.
Of course the amount of metal you would remove would be relatively tiny.
It may be nothing more than insulation or paper which can be removed easily.
Hope this Helps!
Dec 19, 2009 | Neff B1641 Single circotherm super...
Aslight metal rubbing noise in the top lincoln impringer 1450 natural gas coming from themotor or fan side.openad with screwdriver the 13 screws etc to removed gaurd copver so that maybe i could see...
most likly the fault is the fan blades touching the side of the circular hole,to test.1.switch of all power.2.when power is switched of try switching your oven to on position.if oven will not work then proceed3.if you can turn the fan blades by useing a thin piece of wood or simler.4 if when you turn the blades you hear a rubbing noise you might take a closer look if you have torch point it in if you see the blades touching or one of the blades touching it might be possable to to push the offending blade back very slightley useing the same piece of wood you yoused at 3.if this fails to solve your problem the fan moter might be ready to give up. I hope this can solve your problem.yours adrian.
Sep 14, 2009 | Ovens
Why does my Jenn Air convection oven make such a LOUD clattery/ticking noise whenever I use it? I think it must be the fan...can you help?
If you can get at the fan blades without taking anything apart, try to turn the fan blade by using a small screwdriver or even a small wooden skewer. Listen to see if the blades are making contact with either fan cover or the back of the oven or the edges of the convection opening.
Once you determine which blade(s) are making contact, use a sharpie marker to mark those blades you need to correct. That way if the blades are hitting the fan cover, you'll know which ones need to be bent back into shape once the cover is removed.
With the oven turned off, you should be able to remove the circulating fan cover and correctly bend the fan blades back into shape and stop the noise.
Hope you found this very helpful and best regards!
Aug 07, 2009 | Ovens
Removing a Fan
It should not be neccessery to remove fan to fit new element, I have never had to do so, but if you need to remove the fan blade, then unscrew the nut clockwise, as though you were tightening it, holding the fan blade as you are undoing the nut
Plz rate my solution.
Thanks.
Jan 25, 2009 | Neff U1421 Double circotherm Electric Oven
Unable to remove the fan blade on the neff u1721 oven (too tight)
The nut is a left hand thread, so unscrew it clockwise to release it, hold fan blade as you are doing this. Tighten anti- clockwise.
Thanks.
Jan 11, 2009 | Neff U1721 Double circotherm Electric Oven
Changing Smeg SA280X/1 fan motor, shaft nut stuck?
Most fan blades are held on by a single nut, which is usualy a left hand thread, so to unscrew it you turn it clockwise as though you are tightening it up.and to tighten it,anticlockwise..
If the spindle turns, then you will have to hold it with a pair of grips or similar.
Thabks.
Jan 10, 2009 | Smeg SE280X Stainless Steel Electric...
Hotpoint fan oven motor removal
hi if you have a small blow lamp warm up the shaft and the blade it should after about 5 mins come off also tap it gently with a small hammer try that good luck
Mar 14, 2008 | Ovens
Thermador SMW272 Electric Double Oven Logo
18 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
