Introdusing a old cat to a new cat - Washing Machines
    New Friend:
  • 39 Answers
Make sure you separate the newbie in a separate space/room for at least 14 days to make sure new kitty isn't sick and doesn't get your current kitty sick. Make sure new goes to the vet to get the right vaccines. See link for details. After 14 day separation I would switch cats from one room to the other so they can smell each other and return. Then let them sniff under door. Then I would be two baby gates so they can't climb over until they get to know each other. Hope you adopted/rescued and not bought the new kitty
http://www.icatcare.org:8080/advice/how-guides/how-introduce-new-kitten-your-resident-cat
Posted on Jan 04, 2015
I am trying to work out how old my cat is in human years,she's 19?
A cat reaches the approximate human age of 15 during its first year, then 24 at age 2. Each year thereafter, it ages approximately 4 "cat years" for every calendar year. So a 5-year-old feline would be approximately 36 in cat years. Your kitty is very old, if measured by these figures. I found this info on the Internet. Google "how can I tell how old my cat is in human years" and you'll get a lot of information. Good luck.
Mar 10, 2017 | Cats
2008 CTS Cadillac 3.6 stick ,have 2 po430 code 02S and EVA, put a new cat on old one was empty checked every thing was told cat,out on new now has 2-430
Sounds like you need a reputable mechanic with a good code reader to check it out. It could be an O2Sensor, I would almost bet on that one, but could be many other sensors as well. O2 sensors emit low voltage signals and if one is weak or bad it will act like the Cat is bad. make sure the wires are plugged in all the way, possibly one is loose from when they installed the new cat. Hope this helps. Hard to diagnose with out the vehicle here to hook up my code reader to.
Oct 31, 2014 | 2008 Cadillac Cts
CATALYLIC CONVERTER ON A 2001 BUICK LESABRE REPLACING
Buy a "direct fit" cat converter for far less hassle. Spray some ligth oil on ol dnuts and bolts at front of converter and reove them. Saw off the aft part leaving enough of the old tail pie to firt neatly ontot he new cat. Boltl on the new one and use a muffler clamp to secure tail pie to back of new cat.
The O2 sensor cabling may require you to drillout the rivets that secure the heat shield above the cat. Have new rivets available to reattach that sheield if removal is necessary. ((Of course, a cheap rivet gun is needed to install the new aluminum "pop" rivets. Those items are availabe at Home Depot.
Feb 04, 2014 | 2002 Buick LeSabre
2004 nissan xterra run great for 12 miles then misfiring,cnt get over 45 miles an hour. codes p 0733,p0420,p0430,p0328 comes up. new wires,new cap,rotor spark plugs 6 months old timming belt 6 months...
code p0733 refers to gear 3 -incorrect ration===causes---wiring---TR sensor/switch--shift solenoids---transmission mechanical fault
code p0420 refers to catalytic converter system -bank 1---efficiency below threshold===causes--cat converter--wiring--HO2s 2
code po430 refers to cat converter system bank 2--efficiency below threshold===causes--cat converter--wiring ---HO2s 2
code p0328 refers to knock sensor (KS) 1 bank 1--high input===causes--wiring short to positive--KS incorrectly tightened--KS---ECM
basically replace the cat converters as they are blocking the exhaust system and preventing your over 45mph problem
replace the TR sensor/ switch as you have not mentioned a transmission problem
Rectify the problem with the KS as it controls the air/fuel mixture setting which contributes to the car getting hot.
Jan 12, 2014 | Nissan Cars & Trucks
My cat is 2 years old, she had a litter of 4 kittens they all do have new homes they are 7 weeks old. Sokkies is still very swolen and hard all around her nipples what should i do?
If they swells and becomes red and painful take her to the vet to check for Mastitis which is a bacterial infection in the milk ducts of female cats and can get very sick and die.
Also make sure cats are with mother for 10 weeks to properly learn things.
Also please spay your cat, approximately 7.6 million companion animals enter animal shelters nationwide every year and millions of cats are euthanized.
Mar 29, 2013 | Cats
Din greseala am introdus invers usb-ul in computer si hardul nu mai functioneaza.nu i-l mai vede in computer.in sistem i-l vede ca usb device.*** sa procedez ca sa-l computerul?cel putin sa pot sa-l...
regret dar nu prea mai ai ce face - cind ai introdus usb-ul invers s-a inversat si alimentarea lui asa ca aproape totul a fost prajit. daca ai noroc s-a prajit doar interfata carcasei - scoate hard discul din ea si pune-l intr-una noua
http://www.pcgarage.ro/rack-uri/filtre/general-tip-rack-extern-hdd-25-quot/general-interfata-hdd-sata/
si o sa fie ca nou.
Jan 21, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My 92 Honda won't pass emissions at the higher RPM
Sell the car to somebody in FL, no inspection. The state realized it was a total waste of money. Anyway, it probably is the cat, you have 3 or 4 O2 sensors, maybe more. The cat is shot, Just take out the cat, park the car in the street, Call the police in the morning and tell them somebody stole your cat. happens all the time, they go right down the road and cut out 100 cats a night, for $50 each, I don't blame them. The insurance co will buy you a new one if you have the right coverage. If not, you will have to buy a new one, because you can't use an old one. But you can sell the old one on ebay for $50. They are expensive to buy. Hope this helps.
Jun 26, 2010 | 1992 Honda Accord
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
