Question about HP Photosmart C6180 All-In-One InkJet Printer
My HP C6180 senses when paper is put in, but I hear a short grinding but will NOT feed the document. I get a reload document and start over every time! I have only faxed about 25 items. I see no broken teeth either. The little black toothed wheel on the side in the back does not turn if I try to manually turn it, the ones on the top do.
  • socksbuckaro Jun 22, 2009
    No paper jam, not teeth missing. However I just found two loose spring coils inside after lifing up cover and do not know whewre they belong.
    Thank you, but which roller or rail ends and how do I locate them?
    I found the springs on top of the glass under the second part I flip up after the top lid that is attached to a ribbon of some sort to the main base of the printer.
    That grey part that encases the wheel, which only turns a quarter turn and that's why the paper won't feed through. That part seems to be all sealed up accept a thin white plastic rim underneath it
    that can be pulled down.
  • 11,896 Answers
Sounds like you have a little paper jam. Check feed gears and the slide rails. Check for any broken teeth. If gear is not moving, the motor may be faulty.
Posted on Jun 22, 2009
  • Nate Stansfield
    Nate Stansfield Jun 22, 2009
    The springs will either go to the rail or ends of roller. Kind of funny, the springs where my next solution.
  • Nate Stansfield
    I am refering to the wheel that is under the case. It is a pain to get to. As far as I am aware, there are only springs on the laser wand on glass top, and the wheel.
HP C6180 stopped loading paper
its due to the fact that paper you have loaded is being crashed inside the printer if you once again rotate the paper feeder stick and try it will work
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer does not pick up paper. grinding sound on
Please perform the steps given in the below document and check for results.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=us&lc=en&dlc=en&product=72881
Wish
Aug 01, 2009 | HP PhotoSmart 7150 InkJet Printer
Top feeder not feeding paper through
I have had this problem before and found that certain types of papers cause this. Can you try some different paper you may have lying around and try that? Post back with the results.
May 30, 2009 | HP Photosmart C7280 Laser Printer
Paper won't feed
No guarantee on this just an idea. Can you put a piece of sticky tape(the matt one not hi gloss) just across the feed in edge. Or some other thin tape that would have a "grip" to it? Good Luck!
Apr 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
Quiken 2009 will not print on HP C6180
Objects or paper blocking printhead or paper feed path.
Feb 11, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Deskjet 3845 will print the web page, but wehn I try to print a short word document it feeds a sheet through, but prints nothing
plz try by reloading the printer driver and check if you have correct paper size selected in the printer.
Dec 05, 2008 | HP Deskjet 3845 InkJet Printer
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
243 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
