Question about Linksys Computers & Internet
Error sys 00089 - Linksys Computers & Internet
Toshiba 3500c cA90 error code
[CA90] indicates Image data transmission error of sys board.
Check the harness between the PLG board and SYS board open-circuited or the connector dis-
connected?
If the harness is ok, then probably is the PLG board & SYS board issue.
Feb 24, 2013 | Toshiba Office Equipment & Supplies
How to fix error 651 on windows 7
Error 651 is a well-known bug in Windows 7 which happen when you try to connect to the Internet using PPPoE connection. If you're one of the victims who met this bug, you should see the following error message: Error 651: The Modem (or other connecting device) has reported an error. These connections, however, would work just fine in Windows XP or Windows Vista PCs. Below are a few solutions that can perhaps fix the problem:
Windows 7 Fix: Error 651 Modem PPPoE Broadband Internet Connection
Fix 1: - Error 651 Modem PPPoE Broadband Internet Connection
Click here to download Registry Easy to automatically fix your PC errors and speed up your system.
Fix 2: - Error 651 Modem PPPoE Broadband Internet Connection
The root of the problem is believed to be caused by the RAS PPPoE file raspppoe.sys found in the folder C:\Windows\System32\Drivers. To fix this problem, we will have to replace the file raspppoe.sys with a new one. Try to copy the file from your friend's computer which has Windows 7 installed. Alternatively, you can download the raspppoe.sys file from this site (thanks to the author). After you get the file, before pasting it into C:\Windows\System32\Drivers, be sure that you rename the original file to something like raspppoe_ori.sys, so that if something weird happen you have a backup of your original file. Paste the new raspppoe.sys into the directory after you've renamed the original file. Try to connect your modem and it should work fine now.
Feb 21, 2013 | Computers & Internet
F10 error after getting moved
the error is communication error between system cpu and scanner cpu
check the following
(1)check the harness connecting the sys board and the slg board is disconnected or open circuited
(2)check the version of the system rom on the sys board
(3)check the version of the scanner rom version on the slg board
(4)replace the sys board
(5)replace the slg board
but first try doing the latest version of firmware
Mar 14, 2011 | Toshiba e-Studio 35 Copier
Fix error 651 on windows 7
In windows 7, when you try to connect using your PPPoE connections, you may be faced with the following error: Error 651: The Modem (or other connecting device) has reported an error.
These connections would work just fine with Windows XP or Windows Vista PCs.
Again, you are not alone, this seems to be a known bug in Windows 7 that is being worked at. However, you can workaround this problem.
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system. If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip). This should help!
Jan 01, 2011 | Computers & Internet
Wireless not working pc told me error 651
The RAS PPPoE driver file "raspppoe.sys" found under c:windowssystem32drivers folder seems to be the root cause of the problem. Fortunately, we can workaround the problem simply by renaming the original raspppoe.sys file to something like "raspppoe_orig.sys" copying a working file from a Windows Vista system . If you do not have access to a Windows Vista system. click here to download raspppoe.sys file (unzip)
DO VOTE ME
Dec 07, 2010 | Computers & Internet
Memory file dump error, pc freezes
This is the issue with your RAM chip or Operating System .Pls replace the RAM chip with goods one and on the system .If still problem not resolved pls re-install the Operating System again.
Nov 17, 2009 | E-Machines eMachines Desktop PC
I want to align printf()'s text in center.
printf("Color %s, number1 %d, number2 %05d, hex %x, float %5.2f, unsigned value %u.\n",
"red", 123456, 89, 255, 3.14, 250);
will print the following line (including new-line character, \n):
Color red, number1 123456, number2 00089, hex ff, float 3.14, unsigned value 250.
The printf function returns the number of characters printed, or a negative value if an output error occurs.
for further inf u can see.
http://en.wikipedia.org/wiki/Printf
Nov 26, 2008 | Computers & Internet
Error message: HD521-2W
this error is basically a fatal error. you will endd up needing to replace your hard drive soon but if you dont like doing a recovery every few days and loosing your information all the time replace the hard drive
Mar 30, 2008 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Computers & Internet Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
