Question about Hotpoint Washing Machines
Hooking up the cold and hot water in back of the washing machine
Does it matter which hose goes in the back for the hot and cold water?
    President:
  • 1,185 Answers
In a word Yes!!
The machine will fill with Hot water to rinse and if that water is as hot as the normal supply your clothes will shrink and the colours will run.
You need the hoses and the supply to the hoses to be correct so that when you put it on a cool wash it fills with cold water and brings the temperature up to the right level.
Bringing in hot water will kill the soap powders action.
Also the machine adds hot and cold water to make sure that it gets a correct balance for other programs
If you are not sure how they are connected then look at the back of the machine, there should be either a H and C stamped into the backplate or the inlets are Red and (White or Blue).
If the hoses coming from the fawcets are the same colour then take one off the machine place the end in a bucket and turn the fawcet on , if it does not get hot then its the cold one so then make sure it goes back onto the C or the White connector
Posted on Jun 22, 2009
My Bosch vision 300/500 DLX series washing machine continually dispenses hot water no matter what cycle I have dialed in. What can I do?
if it's hot and cold fill machine , have you got the hoses connected correctly hot to hot supply , cold hose to cold mains supply
if its cold supply only to machine , make sure it's not connected to hot water supply, this could be worth checking.
Oct 28, 2016 | Bosch Washing Machines
Can I hook the wash and rinse to cold water hose?
Not sure what you are asking. If you want to wash and rinse you clothes in cold water only, there should be a water temp selection switch to allow you to do that. If you are asking if you can hook cold water hose to both ports on the washer back the answer is yes but it is easier to just cap off the hot side of the water valve on the back of the machine. Most machine water inlet valves are a 3/4 thread garden hose connection. Go to a hardware store or a Lowes/ Homedepot and ask for a screw on cap. They come in both plastic and brass. If you do cap the hot side of the inlet valve, make sure your washer has a cold only setting for wash and rinse and keep it set there. If it gets moved to hot nothing will fill or run.
Apr 15, 2015 | Washing Machines
Wash machine water issues
pull the hot water hose off at the faucet and machine and check for blockage in the hot water hose,clean or replace the hose sediment screens,then hook back up to water faucet and flush hose with hot water,then check water valve on machine for a screen and clean it as well before reconnecting hot water hose
Apr 07, 2013 | GE WSM2480DWW Unitized Spacemaker Washer...
Setting is on cold/cold, but only burning hot water is coming out. When I switched it to warm/cold, it got a little cooler but still not cold. The hot/cold setting is also just warm water, so the hottest...
This seems to me to be that the hoses are connected backwards. It matters very much which hose is connected to which inlet. Make sure that the hoses are on Hot to "H" and Cold to "C" on the machine.
Aug 29, 2011 | Admiral AW22 Top Load Washer
I believe the water temp switch is bad. It will start filling on warm then stop if I put it on hot it will fill with cold water. I have cut the hot water off to achieve this but when it reaches rinse it...
it sounds to me that the hoses are connected to the machine incorrectly. Typically if the plumber ran the water lines behind washer correctly the hot pipe is on the left and the cold pipe is on the right sometimes thats backward and be determined by touching hoses while filling on warm setting and see which hose feels hot. On the back of washer they where they connect hot goes on the bottom and cold on top
Aug 08, 2011 | Estate ETW4400VQ Top Load Washer
Water hammering after disconnecting a washing machine. I have just replaced our old washing machine that took a hot and a cold feed, with a new washing machine that only takes a cold feed. I have turned...
You can use a water hammer arrestor and hook it up to old washing machine hot valve by use of a standard washer hose. This type of aresstor is basically. a shock absorber. You will needtonget pipe adapters to go from hose thread to pipe thread.If you can mount the hammer arressror higher then the washer valve. Hook everything up and turn old hot water valve back on. This shoulg take care of your problem. Thank you.
Jun 02, 2011 | Plumbing
We have both hot and cold hoses going into washing machine but cannot get anything but cold or lukewarm water no matter what setting we choose. The pipe leading into the hot water hose feels warm and we...
sounds like the mix valve on the washer is broken and not opening properly -- the mix valve is the valve that both hot and cold water are connected to on the back of the machine.. turn off water valves and remove the hoses,, remove the back panel from the washer -- the mixer is held in place by one little screw,, also mark the wires going to the mixer ( hot/cold ) --- remove the mixer valve and take it down to your local appliance repair shop and match it up to a new one -- install the new mixer and connect wires and panel and then hoses and all will be working good as new.
c...
Feb 01, 2011 | Hotpoint Washing Machines
Slow fill on cold water washes
the cold water comes from your service (well , city) the hot goes throug your heater so it catches all the contaminates you have a screen where the water hoses hook to your machine they become partially plugged mostly the cold
Jul 04, 2009 | Kenmore Washing Machines
Orientation of inlet pipes
I am not to sure if this answers your question but I think you are asking which way the hot and cold hoses connect to the wasing machine? if this is the case if you look on the back of the washing machine you will see stamped in the metel a H for hot connect the hot water inlet hose to this, If it is not marked, hook up the hot water hose to the washing machine and place the water temp selector to hot and turn machine on if hot water comes out you have the correct hose hooked up,if not then the cold water hose goes were you hooked up the hot water hose. hope this helps
Jun 24, 2009 | Washing Machines
Water flows in cold side of water valve and out hot side valve
It seems unlikely that something went wrong just from moving it unless it got banged up!
It sounds like you may have stripped the hot side.
I'm assuming the water is going in the cold side and out the hot side and out the back.
If this is so and you are happy with just cold water try this:
Go to a Plumbing Store and buy a cap for the leaking intake...if it still leaks you can try soldering the two together!
I hope this was helpful.
Good Luck!
Jan 20, 2009 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
