Question about LG WM0642HW 4.0 cu. ft. Front Load Washer FACTORY REFURBISHED FOR USA
Where is the thermistor sensor located for replacement on the LG WM0642HW machine?
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: "UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Try adjusting the load size, and make sure the unit is level.
Posted on Aug 08, 2009
What does it mean when it says PE on my lg wm0642hw washing machine
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Jul 29, 2016 | LG 4.0 cu. ft. Front Load Washer, White -...
LG WM0642HW
make sure it drains the water out..it will not go through spin if there still water inside the tub... also drain is timed. Is there any error message? thx
Mar 01, 2014 | Washing Machines
I have a LG WM0642HW washing machine. During the wash and rinse cycles the machine runs really rough and will not turn the drum over. Sometimes the machine will stop and go into the LE error. I have...
Your problem requires very skilled LG technician to check the wiring circuit from the control board to the motor and hall sensor. Very possible that the control board is bad but highly unlikely. Suspect the wiring harness with high resistance to the motor.
Good luck
Jun 16, 2011 | Washing Machines
HELLO MY DRYER LG MOD DLG5988S GIVE ME A CODE TE1 AND IT DONT START ONLY MAKE A BIP SOUND. SOME BODY CAN HELP ME??
The "tE1" error has to do with the dryer's thermistor. The code indicates the thermistor is open, meaning that it has cracked or broken off, possible the wires are off. if the wires are good then you will need to replace the thermistor. The Thermistor is located next to the blower section of the dryer should have a bule and orange wire and it is on the blower housing. here is a picture and if you need to order it:
http://www.repairclinic.com/LG-Dryer-Sensor-Or-Thermistor-Parts
Mar 19, 2011 | LG DLG5988 Gas Dryer
Our lg washer model wm0642hw tub clean cycle stops
software problem. regarding smell, after wash keep the door opened for ventilation, use fabric conditioner etc. also check whether any rodent has gone inside and messed up the place
Mar 18, 2010 | LG WM0642H Front Load
Aug 07, 2009 | LG WM1814CW Front Load Washer
LE light is on and washer wont run. Model LG wm0642hw
I would suggest unplugging for 12 hours. If you plug it back in and it works again then order a new main control module. If it still doesn't work after unplugging for 12 hours then you probably will need a new hall effect sensor. check out pa rtstore . com for parts. Good luck!
Jun 15, 2009 | LG WM-2277HW Front Load Washer
LG WM0642HW washer gives error during spin cycle and stops.
I have this problem and you can find the solution on this same web page by searching. It is likely the Hall Sensor that needs to be replaced (see proflevy posting on Jul 16, 2008). According to the postings, it is from soap build up on the sensor and replacing it costs $18 for the part and is easy (many responses on this). I am waiting for the part and will try to fix mine soon.
Mar 06, 2009 | LG WM-2277HW Front Load Washer
LG Washer WM0642HW: Not enough water
Turn clockwise the water level sensor set screw a half turn "clockwise" under the top of the machine lid.This is the only way to rid yourself of the WICK WATER RUB WASH METHOD that is just terrible. Especially with a full load ! BELIEVE ME. I really wonder if consumers who have the WM0642HW earlier produced version with the nozzle spray system in the top of the door seal are having these troubles?. Mine is a 2009 verson of the WM0642HW, No Forced Water Recirculation. ( Discontinued) and how it was preset for fill at the factory made it perform terribly. Only after i adjusted the water level sensor does it perform well the first time around. Have yet had to rewash anything since the adjustment i made for the fill level. Good Luck.
Nov 09, 2008 | Washing Machines
LG WM0642HW 4.0 cu. ft. Front Load Washer FACTORY REFURBISHED FOR USA Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
