Question about Gateway 500XL PC Desktop
Dell Deminsion 2400, Video on the motherboard was damaged so we put in a video card. Now computer will not cut on and gives a faint beep on plug in.
  • 1 more comment
  • iecdannyboy Jun 22, 2009
    the card worked the first time and then it was shut down with the start menu. after we shut it down it no longer starts up. off the top of my head i can not remember what kind of card it is but will post it up when i am able to get to it later
    the card worked the first time until the computer was shut down using the start menu. since the shutdown it wont start back up and nothing inside is loose. and the motherboard is receiving power
    i tried taking the video card out to see if it would start up: it still didnt
    i removed the ram to see if it was the same beep as missing ram creates: it was a different sound
    off the top of my head i'm not sure what the problem would be now
    President:
  • 948 Answers
If it has never worked since you put in the video card, the card is not compatible with your system. Please post more information, what card, did it ever work, for how long, what have you tried or been told the problem is?
Posted on Jun 22, 2009
  • Dick
    Dick Jun 22, 2009
    My first suspicion is the new video card is not seated properly. Try putting it back in. If that does not work I suspect the card is bad, but it could have been damaged by your motherboard or improper installation. It is very unusual for the card to work once, then stop. Normally they work or are bad right from the start.
I have a Dell Dimension 2400 desktop. It needs a monitor. I tried new ones from Best Buy and Office Max but they say no signal when I hook them up..I tried this computer with monitor in the following
Thank you for replying,
As per the diagnostic LED's, it is an issue with Video initialization failure. Your computer has onboard Graphics which is built into the Motherboard.
Video Initialization failure could happen if there is :
Unseated AGP card
Bad AGP card
Bad motherboard
As per your Svc Tag your system doesn't have AGP Graphics Card, Probable issue with MOBO.
This computer doesn't have a AGP Slot (Graphics Card Slot) to try connecting Graphics Card.
Need to repair/replace MOBO.
Thanks.
Feb 25, 2014 | Dell Dimension Computers & Internet
Three beeps when i pluged in dell 2400 what does that mean?
check the video card, remove it from the motherboard, then try to connect using the built-in video from your motherboard,
Aug 09, 2011 | Computers & Internet
My motherboard gives 8 beeps and shows no video, I tested with several video cards and gives the same result. when the computer beeps (normal as it recognizes that although the bios), then emits...
Continious beep codes are caused by the memory (RAM). Try reseating your RAM just plug it out clean it then put it back in. Or try the other memory slots. Just transfer your memory to the other slot if you have an available slot on your motherboard. Or simply buy a new memory (RAM). Just make sure it is compatible to your motherboard. Beep codes means the computer is not reading the memory (RAM) properly. There is no post and no video in your computer because the RAM is not working properly.
Dec 19, 2010 | Intel ASRock Penryn1600SLI-110dB LGA 775...
I have a dell deminsion 8250 running Windows XP when I plug in the monitor it does nothing. I havean HP computer running Windows 7 and I plug it in and it runs wonderfully How do I get this monitor to...
Does your monitor require a driver, And it sounds like maybe an issue with your video card, But without seeing it I really can't help..
However it does sound like you ave a video card issue, can you borrow a card from a buddy to see if it works, even if you add a crappy video card it will let you know if its something more serious like the motherboard or Power supply unit
Sep 14, 2010 | Sylvania Computers & Internet
Monitor won't come on
do you hear a single beep when the computer boots? That's a sign of a good system... try your monitor with another computer...the problem might be your monitor.
Aug 16, 2009 | ASUS SiS Chipset TUSI-M Motherboard
My pc beeped twice and nothing came
Lack of video signal is usually 1 of 3 things, Power supply (PSU), Video card or Motherboard (mobo).
Situation #1: If you get a blank screen and no sounds or movement it either indicates that the power supply unit (PSU) has failed or something on the motherboard has failed, preventing normal startup.
Situation #1A: You might get some power lights coming on and some fans spinning but the video output does not happen, usually indicates that motherboard or PSU is going out or has gone out. Occasionally it will be due to a weak (damaged) PSU.
Situation #2: If you get sounds (normal Windows startup sounds) and lights but nothing on the screen then it indicates a failed or loose video card.
Always try a different power outlet that you know is working. (Eliminate the easy stuff first!)
If it is out of warranty, try opening up the case, with the power off, of course. If you have Sit #2 and have a video card that you can reseat (take out and then put back in) try that. If it is onboard video then you may have to buy a video card for it.
Also take this time to inspect the capacitors on the motherboard (they look like tiny soda cans) and check for tops that are bulging, swelling or leaking anything. Capacitors should be perfectly flat on top. If you find these then your motherboard is bad (well technically the capacitors on your motherboard are bad). The bad caps will need replacing to fix (not a job for an amateur). If it passes the visual inspection then it may just be your power supply is bad. Notice that a bad PSU does not mean you are getting no power, just not enough to start and run the computer.
A few years ago a company stole the recipe for making capacitors and started making their own capacitors at really cheap prices. The stolen "recipe" was not complete and not correct so these caps started failing after about 2-3 years of use. Emachines, DELL and Gateway were the computer companies most affected by the bad capacitor issues, although any of the big companies could have the same problem. These bad caps also affected power supply makers.
Do you hear anything else during startup, beeps, fans or drives spinning, lights on the front or back of computer flashing or lit up? Do you hear the Windows starting sound?
Let us know more then we can troubleshoot better. Do you have the 4 diagnostic (A,B,C,D) on the rear of the machine? What is the front power light on the CPU doing?
Apr 29, 2009 | Dell Dimension 2400 PC Desktop
No video on monitor, My T3256 just beeps every few seconds. HELP
Check the back of your computer, may be your monitor is connected to the wrong video port. Sometimes the computer have 2 video connections, one is built-in on the motherboard and the other one is a external video card inserted on the slot of the motherboard. Check both.
If you still don't have video check your video card. Put another monitor and see what happen.
Oct 07, 2008 | E-Machines eMachines Desktop PC
No post, only motherboard light on, green.
Hey there aj1253, It seems you are getting power to the board. are the fans running?Are you using onboard video or video card. Onboard is suggested for test. I would also suggest you reseat your ram. That is removing it and ensuring it seats properly. Beyond that I would ask you provide more info ( ie is this a new build, or did it just stop working, configuration details, model #'s, et....)
Feb 01, 2008 | Dell Dimension 2400 PC Desktop
Dell Precision Workstation 670 has no video on screen.
Support for ISV-certified PCI Express graphics cards up to 150 watts and with up to 512MB graphics memory including: nVIDIA® Quadro® FX 4500;
nVIDIA Quadro FX 3450; Quadro FX 1400; ATI™ FireGL™ V3100; nVIDIA Quadro NVS 280; All graphics cards support dual monitor configurations
Although it may not be your video card thats the problem. when youre computers posts, it beeps once. If it is beeping more then once youll want to check with the board manufacturer to see what the code its giving means.
Jan 15, 2008 | Dell Precision Workstation 670 PC Desktop
Gateway 500XL PC Desktop Logo
76 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
