Question about Cobra 6000 Pro HD GPS Navigation Trucker Routing w/5" Touch Screen &
Cobra 8500 shows qualnetics page on the screen
When i downloaded the cobra updates on the navigation a Qualnetics Access point Configuration page shows on the screen of the navigation and doesn't want to move, and i don't know what to do
Are the updates done automatically?
No, you pay for the upgrade through the Dealer or Manufacturer.
Jan 13, 2016 | Cobra 8000 Pro HD GPS Navigation Device
I have a Nav one cobra gps and when I try to enter and address and start Navigation it always goes to an Illinois start point it will not start from my current location. Im in West Virginia
PDF]8500 PRO HD - Cobra Electronics
https://www.cobra.com/.../8500PROHD_MANL_0.pdf
Cobra ElectronicsOct 24, 2013 - Before installing and using the Cobra Navigation System, please read... DO position the unit so the screen can be viewed with just a ...... and may beincorrect. .... Select one of locations on the list then tap the GO button to route directly ... begin moving, the system will use the GPS information to update your ...
Nov 28, 2015 | Cobra GPS
How to update maps
You need to update it through a PC. You can download the HomeBase Cobra software from this link Cobra HomeBase
Oct 26, 2014 | Cobra 7750 Platinum 7" GPS Navigation for...
Cobra gps update
You need to download from the following link their HomeBase software to do so:
Cobra HomeBase
Aug 30, 2014 | Cobra 6000 Pro HD 5 GPS Navigation
How do i update cobra 8500 pro hd
You need to download the free Cobra HomeBase software to do so. Cobra HomeBase
Jul 15, 2014 | Cobra GPS
Hi i'd like to know how to update the maps this uses navione app. Thanks
which device ?
Cobra NavOne 3000
Go to the Cobra website (see Resources) and click on "FAQ" at the top of the page.
Use the drop-down menus to select "Nav One 2750-2950-3000-3080" and "Software Updates." Click "Submit."
http://reviews.cnet.com/car-gps-navigation/cobra-navone-3000/1707-3430_7-31138256.html
Click "How do I get and load software updates?" Click the bold "HERE" link.
Scroll down and click "Nav One 3000/3080."
Click on the latest update link to download the update to the computer.
Connect the NavOne's power but do not turn it on. Connect a USB cable to the computer, and connect the other end to the GPS.
The GPS device's LEDs light up, indicating a connection.
Double-click on the update file you have downloaded.
Click "Next" until the update begins.
When you are notified of completion, close the update
hope this helps
Oct 11, 2012 | GPS
How do you perform a network update on the system
To configure a network access point, press Home then move to Network Update, then you get to the configuration screen that asks for the WLAN Settings (the default is to enter an SSID), choose "Scan" and let the PSP identify all the wireless networks it can see. Choose whichever one is your network.
Choose all the default configuration settings and you should promptly be asked to press the X button to save your new access profile. Do so, then select it again and, if your connection works you'll see "Checking Server...", then, if there's an update available, the PSP shows:
Network Update has found a later version.
To download, insert a Memory Stick with at least 14MB of free space and press the X button. Press the X button and you'll see "Downloading..." and a warning not to turn the unit off or remove the Memory Stick while downloading, then the download starts.
When the download succeeds, you'll now see:
Download completed.
The update is now available on your
Memory Stick.
To install now, press the x button.
To install later, go to [Game]..
Let me know if there is anything else.
Reagrds.
Aug 15, 2010 | Sony PlayStation Portable (PSP) Console
Reset cisco airnet 1130ag
There are 2 ways to reset the access point.
Using the MODE Button
Follow these steps to delete the current configuration and return all access point settings to the factory defaults by using the MODE button:
1. blank.gifOpen the access point cover
2. blank.gifDisconnect power from the access point (the power jack for external power or the Ethernet cable for in-line power).
3. blank.gifPress and hold the MODE button while you reconnect power to the access point.
4. blank.gifContinue pressing the MODE button until the Ethernet LED turns amber. (approximately 2 to 3 seconds). Then release the button.
5. blank.gifAfter the access point reboots, you must reconfigure it using the web browser interface, the Telnet interface, or the access point console port.
Using the Web Browser Interface
Follow these steps to delete the current configuration and return all access point settings to factory defaults using the web browser interface:
1. blank.gifOpen your Internet browser. You must use Microsoft Explorer (version 5.x or later) or Netscape Navigator (version 4.x or later).
2. blank.gifEnter the access point IP address in the browser address line, and press Enter. An Enter Network Password screen appears.
3. blank.gifEnter the username Cisco in the User Name field.
4. blank.gifEnter the password Cisco in the Password field and press Enter. The Summary Status page appears.
5. blank.gifClick System Software. The System Software screen appears.
6. blank.gifClick System Configuration. The System Configuration screen appears.
7. blank.gifClick the Reset to Defaults button.
Note blank.gifIf the access point is configured with a static IP address, the IP address does not change.
8. blank.gifAfter the access point reboots, you must reconfigure it.
Aug 13, 2010 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
HOW TO UPDATE ASUS WL-AM604g Wireless Router Firmware I HAVE THR TRX FILE
1. Download the updated software from the vendor's web-site.
2. Connect your computer with an Ethernet cable, *NOT* via wireless, to the router.
3. Access the router's built-in web-server interface.
4. Navigate through the web-pages to the "update firmware" page.
5. Click "browse", and point to the file on your computer that is the updated software.
6. Click "update".
7. Hopefully, BC Hydro wil NOT cut your AC power while your router is updating.
8. The router will restart.
9. Done.
Dec 14, 2009 | ASUS WL-AM604G Wireless Router
How do you print config sheet (mac address) from phaser 8500 pri
Here ya go.
NOTE: The Configuration Page can be printed to help solve printing problems and obtain the best results from the printer. Access this page from the printer's Control Panel.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Configuration Page], and then press the [OK] button to print.
  3. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main Menu.
Mar 17, 2009 | Xerox Phaser 8500/DN Printer
Cobra 6000 Pro HD GPS Navigation Trucker Routing w/5" Touch Screen & Logo
Top Cobra GPS Experts
TO Lady
Avishek Samaddar
Avishek Samaddar
Are you a Cobra GPS Expert? Answer questions, earn points and help others
