Question about Pyle Audio Players & Recorders
No power when i plug it up !
Just ordered the pyle pro pdcd 4000 used, and plugged up the cords and the control doesn't come on. what could be the problem ?
  • 6,784 Answers
HI, check to make sure the wall socket is live by, plugging another device into the socket. if the socket is live, this will confirm a internal issue that concerns the power sector of the unit.
Contact pyle for this repair.
***In some model, there will be an In-Line fuse located inside the unit on the power board or transformer. replacing this fuse(if installed), may fix this issue.(uncommon)
Posted on Jun 23, 2009
My lexmark all in one will not power off
Try this: while printer is on, press and hold down power button. Then, unplug power cord. The power button makes sure that all the power is used up. Wait for at least 3 minutes and plug back in.
If this doesn't work, the power button or surrounding may be faulty. Please have a qualified technician look at it.
Sep 08, 2014 | Lexmark Office Equipment & Supplies
I need a remote cable for a pyle pro pdcd 210
Contact PAC Pacific accessories corporation or e-bay for a PAC TR-7
Jun 05, 2014 | Car Audio & Video
Fuse Type ?? Had a Speaker Cord Short out and Took out the Fuse....Can't Read the Little Glass Fuse
I am having the same problem but mine did not come with a fuse and I can't get a hold of Pyle.
Apr 10, 2014 | Pyle PRO PMX602M 6-Channel 600 Watts...
No power Pyle PLDN74BTI
Is your power cord plugged in? Are you using a power strip extension cord, if so check it to see if the power surge button hasn't been tripped. If so reset it. See if your wall outlet is working by plugging something else into it. If not working reset your breaker.
Oct 06, 2012 | Pyle PLDN74BTI 7 Double DIN TFT Touch...
Euro-pro #S3101 doesn't turn on
Check in the following order.1. Plug unit in firmly in wall socket.2. Check fuse or breaker. Replace fuse/reset breaker.3. Check the continuity of the power cord.
Oct 30, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
YES I HAVE A SONY STR-AV770X RECIVER. AND A PYLE PRO PDG 4000 POWER AMP AND I WONT TO RUN MY BOSE 901 SERIES VI SPEAKERS WITH THE ACTIVE EQULIZER FOR STEREO MUSIC ONLY AND USE MY SONY RECIVER FOR THE...
There's no reason you can't use the 901's in ALL of your audio experience.
Try this:
Remove the short plugs from the Adaptor jacks. They claim you can record some of the effects (surround, dbfb and tone) from these jacks so that implies it's late in the preamplification path. The question is - did they place it after the Volume Control, too - as many other receivers with jumpers do?
Take an RCA pair from the Adaptor Out to the 901 Active EQ's Line IN; then the EQ's Line Out to a separate amp's Line IN. Attach the 901's to the new amp.
Because we don't know if the Volume Control is in the path at this point, find yourself a CD with a long, low fade-in just in case the signal is at maximum power here. Be ready to Pause it if it gets too loud.
If the Volume Control affects it ok, then get yourself a pair of RCA cable splitters and place them where the Adaptor Jumpers were with the extra leads going to the cables we ran to the 901 EQ at first. That way the receiver still keeps the program internally for its own speakers and the 901's get it, too, but without modifying what the receiver sees.
If the volume control on the Sony isn't in the Adaptor loop you'll have to use the Pyle's volume control. But you could still have the speakers that are directly attached to the Sony useable at the same time.
Mar 25, 2010 | Audio Players & Recorders
I need a foot pedal/power cord for my Euro pro serger model 101-854H. Can you help me find one?
Email me a picture of the spot on the machine that the foot control cord plugs in and I'll send you the link to the correct one and to order. info@sewingpartsonline.com
Apr 22, 2009 | Euro-Pro Sewing Machines
Brand new Magellan Maestro 4000 does not turn on or indicate powe
I had the same problem and I solved it by cutting a few strands of speaker wire and twisting them together and inserting them into the center of the generic car gharger end which plugs into the Maestro 4000, It seems that the 4000 has a very small center conducter on the GPS itself and by adding a few strands of speaker wire about 1/2" long into the plug before pluging it into the 4000 it allows it to makes contact with the small power inlet conductor which is smaller than most generic cigarette lighter 5vdc power cords. I did this to mine and it powered up right away. The other solution is to buy the actual car power cord from Magellan which has the proper size connecton and makes proper connection all the time.
Dec 24, 2008 | Magellan Maestro 4000 Handheld GPS...
107 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Marvin
Marvin
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
