How can i adjust colors in konica c450 - Office Equipment & Supplies
  • 641 Answers
HI ganesh,
Instructions
    • 1Go to the Application screen on the LCD panel located on the printer and press on "Edit Color." Press on "Color Adjustment."
    • 2 If unhappy with the hue of your copy, press "hue." Look at the 'hue" screen and press the arrow keys in the direction you wish to change the color hue. Press "Sample Copy".
    • Sponsored Links
    • 3 Take a sheet of paper and place in the top left corner of the glass surface of the Bizhub. You will see that the area is marked "Sample Area" alongside the glass area. Press the "Start" button on top of the Bizhub.
    • 4 Wait for the Bizhub to produce a sample sheet. Look at the finished sample sheet -- there are six options showing three incremental "plus" hue options and the three incremental "negative" hue options. Select the one you like and press to confirm the required hue adjustment on the "Hue" screen. You have now calibrated your colors as desired.
Read more: http://www.ehow.com/how_7590176_calibrate-colors-konica-bizhub.html#ixzz316wHLgOK
Posted on May 08, 2014
oranous_comp
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
taminol
  • 62 Answers
SOURCE: Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
Posted on May 26, 2009
  • 903 Answers
SOURCE: I have a Konica Minolta
Hi, you can print a test page from your computer by doing the following:
- Right click the c450's icon in the Printers folder and choose Properties. - Under the General tab, select either "Print Test" or "Print Test Page."
The test page will print out and you can check the printer's operation.
Posted on Dec 30, 2010
  • 1156 Answers
SOURCE: I have a konica minolta c450 copier and I was
Hi, IC-402 external fiery does brightens color print, It all depends on what texture of printing you are looking for...
Normally if i were you i would go for something like IC-402 external fiery, it's has a Good quality color printing..
No need to bit around the bush for too long,Go get it and try it out,but make sure you read instruction carefully before using it..
Take care.
Posted on Jun 23, 2011
  • 77 Answers
SOURCE: Konica Minolta Bizhub C450 touchscreen doesn't work
You need a new touch screen panel or I/O cable, they are fairly expensive if you don't have a service contract with your Office Printer supplier. Recently just replaced one a few months ago.
Posted on Nov 28, 2012
Konica minolta c450 toner problem
Did you replace the image unit for cyan and magenta, you don't replace the developer you replace the whole unit which includes the drum! Did yo use third party ? BAD!!!!! Replace the cyan and magenta image units with OEM cartridges
Apr 01, 2018 | Konica Minolta Office Equipment & Supplies
My konica minolta bizhub c450 touch panel not working at all
Sir, Touch the access button on the left side of the screen should bring up a screen where you allowed to do panel adjustment follow the screen direction if not then you need a new control screen/control board
May 09, 2014 | Konica Minolta bizhub Office Equipment &...
Error p5 in konica minolta c450
Clean them located under the transfer belt when it is removed. after which you need to accurate the sensor cover protectors manually the clean the sensor with a try cloth no static electricity or you will cause the sensor to be destroyed..
Mar 01, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Nov 28, 2012 | Konica Minolta bizhub C450 Touch Panel...
Bizhub C450
sounds like the wrong image unit. Oce and ollivetti have the same machine and take the same image unit but with a different chip. Make sure it is a genuine konica minolta image unit. If need be try putting the chip from the old unit on the new one and see if lays down the colour
Jul 10, 2008 | Konica Minolta bizhub C450P Laser Printer
101 people viewed this question
k24674
jasbo
jasbo
