Question about Kenmore Refrigerators
How to reset measure fill on kenmore model 795.71069.011? right now starts at .34 oz instead of zero.
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: 10 year old model kenmore top load washing maching won't fill.
That means that eithere the membrane water lever switch is faulty (most common) or that the drain pump solenoid is stuck on open.
Posted on Dec 21, 2008
2.8 oz of onion straws is how much in cups???
cut up the onion straws and weigh out 2.8 ounces
get out your measuring cups and take the weight and start filling the measuring cups
there is no correlation between weight and volume as a conversion
Nov 24, 2016 | Coffee Makers & Espresso Machines
My model number is not showing up. Now what do I do?
your not typing an O instead of a ZERO are u? or A zero INSTEAD OF AN 0
Sep 14, 2014 | Kenmore Dryers
Where can I find the measuring cup for Black and Decker Model RC446 part #RC426-30
Using 1 cup of rice to 2 cups water does not result in perfect rice in this rice cooker. The measure cup that comes with the unit is actually 5.5 oz. measurement of dry rice and then you fill the water line accordingly. 5.5 oz of dry ingredients is equal to about 2/3 cup.
Nov 08, 2012 | Black & Decker RC400 7-Cup Rice Cooker
Kenmore washer does not fill first ,goes right into washing.Replaced timer ,same problem.
Hello Sue,
The reason your washer starts agitating instead of filling first is shortted water level sensor switch that should be replaced.
The part number for that switch is W10177795
GENE
Nov 11, 2011 | Kenmore Washing Machines
Gas ratio for a weedeater XR50
the listed 40:1 ratio works fine but 50:1 has been my usual mix. Important - use non ethanol gas E0 or gas that has chem ethanol modifier. (Pilot brand Gas works) When finished try to run it out so the carb is empty. Even a dead start with quick start to clear all fuel. Easy mixing is to measure a 41 oz marked bottle. Add 1 oz of best two cycle oil then fill to mark.liljack
Aug 16, 2011 | Garden
Washer fills up but drum does not turn. After this part of the wash cycle has elapsed the washer will contniue normally with the rest of the wash (i.e. spin....). So not a fuse problem. Not sure of the...
If your motor does not run after the washer fills, then your failure is in the water level pressure switch, the timer, the drive motor or the wiring harness. The pressure switch would be the first component that I recommend checking. With the washer filled to satisfy the pressure switch, you can disconnect electrical power and pull the tan and violet wires off of the pressure switch. With a volt/ohm meter, measure the resistance across the leads of the pressure switch where the tan and violet wires were connected. You should measure near zero ohms of resistance with the washer full of water. If not, then your pressure switch would need to be replaced.
Jan 07, 2011 | Kenmore 43042 Front Load Washer
Ive never filled my own gas bottle Co2 do you screw the filling station straight onto the carbon dioxide gas bottle or do you run it through a regulator ?if so at what pressure do you set regulator at
You just need to. Hook your fill station up to the big co2 tank and then hook your little tank to the fill station and turn the little one on first then the big one and make sure the little one is completely empty before filling. Co2 is measured by weight not pressure you will also need to weight before and while filling to make sure you do not overfill. if its a 20 oz weigh it before filling it then zero your scale and fill until it reaches 20oz on your scale.
Dec 03, 2009 | Tippmann A 5 Standard Paintball Gun
How mutch fork fluid does it require for the xt 600
hay matey, best to use mums or the mrses plastic gravey jug,or if u have your own 4 measuring .. , in each fork leg u need 18.9 imp oz,,or 18.1 us oz of 10w fork oil or equivalent, after filling ,slowly pump fork up and down to distribute oil,, ,ok m8,, i had one of these babys,,so u no if its filled correctly, from the top of the inner fork tube, fully comprest with out the spring inserted,,, the gap from top of tube to the top of oil level , should measure 155mm,, hope that helps yuh
Jan 10, 2009 | 2000 Yamaha XT 600 E
Need equivalent cup measure for lost Sunpentown rice measuring cup
Use 3/4 of an American cup measure instead. The Japanese cups are 6 oz, American cups are 8 oz.
Apr 25, 2008 | Sunpentown SC-0720 4-Cup Rice Cooker
Refrigerators Logo
21 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
