Question about Casio FX-9860G Graphic Calculator
Casio from memory - Casio FX-9860G Graphic Calculator
How do I delete photos from the internal memory
Firstly remove the memory card if present. Then use the 'view' command button. This should bring up the photos which are in internal memory, then delete to your heart's content!!
Check out world casio com CASIO
and Support world casio com CASIO
Jul 26, 2015 | Casio Exilim EX-Z57 Digital Camera
How to turn memory off on casio fx300es
There is no memory that YOU can turn ON or OFF. All you can do is store numbers in some memory locations (A,B,C,D,X,Y) and M. By pressing ALPHA 9 (CLR) you reset the calculator, thus clearing the contents of the memory locations. Another way to clear a memory location is to store 0 in it. 0 ->ALPHA A, stores 0 in A.
Sep 05, 2011 | Casio fx-300ES Calculator
Card error
Try turning off the camera. While it's off remove and reinsert the memory card. If the same message appears, you should re-format the memory card. CAUTION: Formatting the memory card will delete anything on it. Copy the files off of it before formatting.
Here is your manual:
http://support.casio.com/pdf/001/EXZ60_e.pdf
Apr 28, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio fx-250HC
press "0"(zero) then Min (memory in). This will clear the memory- do it that way with my 250hc all the time.
Oct 17, 2008 | Casio FX-250HC Calculator
Erasing Memory
Use this key operation to initialize the calculator and clear memory:
SHIFT CLR 3 (ALL) =
Refer to this calculator manual on Casio's web site for more information.
Jan 19, 2008 | Casio FX-300MS Calculator
Casio ex-z60 cannot read memory card
Make sure that the SD card you are using is either a SanDisc, Toshiba, or Panasonic. Those are the only cards that have been tested with Casio cameras. Also make sure that you format the card WITH THE CAMERA before you try and use it the first time. If it still doesn't work I would try resetting the camera and then you should have no problem.
May 29, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio FX-9860G Graphic Calculator Logo
13 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
