Question about Seiko Smart Label 240 Thermal Printer
I get an error 6 when I try to install my 240 to windows 8..1. What to do? I have been able to download a driver, but not the program to be installed.
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 70 Answers
I think you're out of luck. The latest driver I could find is 6.9.0.385, you can find it at the site below:
Smart Label Printer 200 420 overview Smart Label Printer 200 420 overview
This is a third party site, Seiko has removed all legacy support from their site. It was really only written for Windows Vista but people found it would work for Windows 7. Given the major structural changes in Windows 8.1 I don't think the legacy software will run in a Windows 8.1 environment
Posted on Dec 15, 2014
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Jan 11, 2016 | Dell Inspiron Computers & Internet
Can't find my software for digimax 240 where can I get
You don't need the software than came with the camera to access it and download the images. The drivers will already be included in Windows 8, just connect the camera to the PC and it will automatically install them. If you're looking for image editing software you can download a free, open source one called GIMP that works very much like Photoshop.
http://www.gimp.org/downloads/
Oct 19, 2014 | Samsung Cameras
Why can't I use MP3rocket on my windows 8 64-bit laptop. The software keeps freezing up every time I try to use it
Are you sure the software is compatible with Windows 8 and 64-bit installations?
You could also check and make sure that you don't have the 32-bit version installed.
Jan 13, 2014 | MP3 Rocket
Casio 240 CR error e94
This error may occur if the registry entries and the drivers for the mass storage controller hardware in the backup computer are not installed in Windows. Download any reliable program like I always use Reginout to fix such errors by using its Repair Registry feature. And update drivers.
Dec 08, 2013 | Computers & Internet
I have installed PaperPort 11 some time ago and it all worked fine. Recently Paperport started installing after every reboot. The installation fails with the error: 1: The engine of the installscript is...
  1. Open the folder C:\Program Files\Common Files\InstallShield\Driver\ from the machine.
  2. There should be folders with numbers in this Driver folder, for example 6, 7, 8, 9, 10, 1050, 11. Delete these folders.
  3. Download ISScript11.zip.
  4. Unzip this file. For more information on unzipping files, see How Do I Unzip a File in Windows XP? or How Do I Use the WinZip Utility in Windows 2000 or Earlier?.
  5. Double-click the IsScript.msi file. This installs the IsScript engine for this version of the installation.
  6. Now try running PaperPort 11 again. If it still has problems opening, try reinstalling PaperPort 11.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 23, 2011 | ScanSoft Nuance ® PaperPort® 11 Full...
When i tries to download anything system shows the following error- " error while unpacking the program code LP5. pls contact author"
I think this is an issue with improper download try using a download manager
Possible Reasons:
1. LP5 means the package is corrupted. This can happen mainly because of some bad download or obsolete package.
2. Obsolete Antivirus
3. Improper Download Software
4. Flash drive
5. Spyware
6. interference from other applications running on the computer
7. During installation of security sites
Possible Solutions:
1. Check For the version of Anti virus
2. Goto control panel /Add Remove Programs/
3. In the list of installed programs we can see the antivirus version.
4. If it is obsolete, uninstall it and reinstall it with the latest one
5. Check For any 3rd party tool that may interfere with the unpacking of software
6. If so un install it.
7. Run Restore disks (or built-in System Restore). It will reinstall the software automatically.
8. Instead of flash drive, use any download manager
Oct 06, 2009 | Microsoft Windows XP Professional
My hp laserjet 2300 keeps printing an error message. It began after I installed another all in one printer. the message is pcl xl error subsystem: kernael error: illegal operator...
Try updating the printers firmware.
You can download firmware here http://bit.ly/13kZ7i
If the problem remains, try replacing the driver with a PostScript-driver. That should help you out.
Jul 29, 2009 | HP LaserJet 2300 Printer
Newdev.dll error and asking for admin rights on bt modem 105
If you have IE-8 installed, then uninstall it and it will start working.
You can uninstall IE-8 using this command in the run dialog box:
"C:\WINDOWS\ie8\spuninst\spuninst.exe
Regards,
Ashish
Jun 20, 2009 | Computers & Internet
NO sOuNd
try this steps
When installing Sigmatel* or Realtek* audio drivers (either from the Express Installer CD or using the latest driver download available from the web), the installation may fail with either of the following error messages:
· Device Object not present, restart the system and run setup again.
· The system does not support the driver you are attempting to install.
The Universal Audio Architecture (UAA) High Definition Audio class driver for Windows* may be corrupted or causing problems with the audio driver installation.
To resolve this, try the following:
1. Click Start > Control Panel > Add/Remove Programs.
2. Look for the following two items: Realtek* High Definition Audio Driver and High Definition Audio driver Package - KB888111.
3. If these items are listed in Add/Remove programs, remove them.
4. Restart Windows.
5. Download the latest audio driver for your desktop board from Download Center.
6. Double-click the filename to extract the files.
7. Go to the folder where the files have been extracted and browse to the \HDAQFE\xpsp2\us\ folder or the \MSHDQFE\Win2K_XP\us\ folder. (The name of this folder depends on your desktop board model.)
8. Double-click the file kb888111xpsp2.exe to install the High Definition Audio Driver Package.
9. Restart Windows.
10. Install the audio driver.
May 15, 2008 | Edirol UA-4FX External Sound System
Vista installation
try downloading updated drivers from the manufacturers website as this may be a known issue for winXP
Jul 25, 2007 | Manhattan Graphics 8 x 6 (174459)
Seiko Smart Label 240 Thermal Printer Logo
153 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
