Question about Panasonic KXDT343 Phone
Why can't people hear me?
It will ring, but when I answer it the people on other end can't hear me.
  • Mary Keyes
    Mary Keyes Nov 16, 2015
    I am experiencing the same thing...did you ever figure it out?
Phone rings we answer we can hear caller but they cannot hear us ring number on mobile no problem
Hi
Please check your mobile mice may be its not working that way the second end user didn't here your.
Jun 02, 2011 | Cell Phones
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
My phone rings but it will not answer i can't hear the person on the other end
If the other person can hear you, then the problem is with the earpiece on the phone. The phone rings using another speaker on the base unit. Swap the mic/earpiece handset unit with another phone and use with existing base unit, to narrow down the fault.
Jan 15, 2011 | Emerson EMSEM2646WH Phone
Number of Rings, I want to reduce the number of rings
Press and hold STOP/SET button for two seconds to access the set-up menu. Press STOP/SET to continue. Press STOP/SET over and over until the Machine says "Rings to Answer". To set the rings to answer just press NEXT or PREVIOUS to select how many rings you would like. Toll Saver option answers after 5 rings unless you already have a message, in that case it will answer after 2 rings. After you hear the option you like, Press STOP/SET button to store it. Now just press STOP/SET over and over until you get to the end of options, it should beep when you get there. Once you get to the end the machine will announce all the settings for review.
Aug 13, 2009 | GE 29878GE1 Digital Answering Machine
PIXMA MP780 will not receive fax with Verizon DSL connection. Before unit was ok with comcast cable, Note: I'm able to send fax. RBRANT
Solution: Contact local phone company to check the telephone wall jack for low ring voltage.
Ring-in Voltage Facsimile equipment?(fax machines), like other telephone anwering devices, require ring voltage at a telephone jack to answer automatically.? The ring voltage is one of the services provided by the local phone company.
  • Low ring-in voltage can cause short bursts of ring tones at the phone jack.
  • Callers may hear one or two ring back tones and then ringing will stop and nothing else will be heard.
  • Inside the home, the called party will hear a brief ring and then nothing else will be heard. If the telephone handset is lifted, the caller may be on the other end.
To check if the fax will not answer due to low ring-in voltage, do the following:
  1. Disconnect the fax at the telephone wall jack.
  2. If an answering machine is available, connect it directly to the telephone jack. If an answering machine is not available, connect a telephone to the telephone jack.
  3. Dial the fax line and see if the answering machine answers the call, listen for uncommon ring tones inside the home or check for similar symptoms as described above. If any of the above symptoms occur, please contact your local telephone company.
May 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I can only receive faxes not send when i try to send it just keeps ringing will not transmit
If you dial a number and just hear ringing that means the other end is not answering. Even if a person or answering machine picked up the ringing would stop. The problem is at the other end.
Mar 10, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
Phone does not allways make the ringing tone
i presume the phone you are having problems with is cordless... take it and drop it into the main phones base for a couple seconds and try it then... also make sure the ringer is not off
Robert
Jan 26, 2009 | Lands Phones
GE 29893GE1-B Digital Answerer Problem
G.E.speaker phone model#29322GE1-a how to program other numbers in phone
May 17, 2008 | GE 29893GE1 Corded Phone
I've lost my manual and need troubleshooting help
Our phone decides to call screen people so the answering machine goes on after 2 rings. We can't find the manual.
Dec 10, 2007 | Uniden TRU8885 Digital Answering Machine
Panasonic KXDT343   Phone Logo
109 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
