Question about Jandy Aqualink Rs4 One Touch Control System Control System
6700 Rev C? code on control panel?
Control not working on indoor panel--will operate manually in service mode?
    Top Expert:
  • Jandy Master
  • 5,075 Answers
Check to see if red 4 pin plug is plugged in if ok check wire for cut
Posted on Apr 30, 2015
CNC65
  • 15 Answers
SOURCE: Jandy Aqualink - Rs, button control red lites on contriol panel
HAVE YOU HAD ANY LIGHTNING STRIKES?
Posted on Nov 06, 2008
  • 246 Answers
SOURCE: all lights are on AqL RS4 control panel with msg 6700 REV C
reset bottom at the power center
Posted on Aug 31, 2009
  • 246 Answers
SOURCE: After lightening strike, Aqualink control panel
ok check all the braker even the one for the house .turn them off all and back on if this do not fix check for 220 v if voltage is present the board is bad need replacement get the number from the back to check for prices
Posted on Sep 13, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
SOURCE: Aqualink RS6 all lights on control panel lit and won't work
I' m having the exact same problem, where the panel lights up and is non-responsive. Did you ever find a solution?
Posted on Nov 11, 2009
Display panel showing 6700 rec v
I assume you meant 6700 rev c on an Aqualink. A few possible causes are;
-The wires from the outdoor power center to the indoor controller have been affected resulting in a loss of communication.
-The system is being affected by bad wiring in the spa side control (if present unplug black terminal strip from the circuit board)
-There has been an electrical spike that has damaged the chip in either the circuit board outside or, more likely, the indoor controller.
Unfortunately the third is the most common reason for failure and the indoor controller may have to be replaced. A good pool service will have a controller on hand that can be plugged in to see if that is the problem (after verifying that the wiring is okay). Good luck with it.
Nov 10, 2013 | Pool & Spa
Blue Haven BH6100 error code 6700 Rev C
6700 REV C is usually the control boards and in rare cases the wiring between the two. Here is a post to troubleshoot http://goo.gl/4Hp7k. It also points to www.fixyourboard.com. Bottom line, don't buy new, get them fixed.
Nov 05, 2012 | Cell Phones
Display panel shows 6522 Rev HH
check wiring to controller either wires touching at plugs or wires cut
Sep 11, 2012 | Jandy Aqualink Rs4 One Touch Control...
I have a jandy rs6 pool control, and all the lights are lit on the indoor remote. The display screen says "6700 rev c" and nothing works on it.
I have the same system and have had this problem several times. You need to replace the board in the control panel of the indoor remote. The part number is PCB 6473-E. It will cost $400 - $600 if you buy it online and replace it yourself. You may be able to find just the board itself for $200 less.
Jan 09, 2010 | Jandy Pool & Spa
I have Jandy RS4 system with 4-button poolside controls for additional spa control. Inside house control panel stays totally lit up saying ''Rev 6700'', and cannot communicate or control pool operations. ...
Oct 07, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
May 21, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Why am I getting a 6700 REV C message on my AquaLink RS6 home spa/pool controller? All the lights are lighted up, too.
I had the same issue, but only after I pressed the reset button on the side of the panel. After a couple of days of troubleshooting, I found a small nick in the wiring from the outdoor unit to the indoor paneI. I turned off the breakers to the pool equipment, rerouted a new cat5 cable, but cat3 will work just as well, wired it up and all was good. A local pool guy wanted to charge me about $2000 to replace both units. I spent less than $5.
Good luck
May 02, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Auto shut down function not working (Jandy Aqualink RS6)
Jandy relays are known to stick. You can diagnose this yourself with a screwdriver. Remove the four screws on the outside panel. You will see a series of black rectangular relays and a lot of wires. Typically the pump relay is the one in the upper right. It will certainly be the one plugged into the left hand socket at the bottom of the circuit board.
Be sure to do all of this simply be looking. You can move the twisted red/black wires a bit to determine which relay is plugged into the first socket. Try to notice on the bottom of the relay a small black tab that is sticking out. When out, the relay is on. If the pump is running, this tab is out. If you then put the controller into service mode and the lights go out without the tab popping back in, you have a bad relay. If turning the pump off does not put the pump light out, you have a bad board.
In most cases, the relay is bad and it is a simple fix.
Nov 24, 2008 | Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink Rs4 One Touch Control System Control System Logo
108 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
