Question about Fiskars Brands Power Sentry 100897 UPS System
Where can I get BT Power Sentry UPS Batteries?
My v260 sentry safe has no power, even with new batteries. I do have the key though, is there way to reset or get into my safe?
Sentry is a very responsible company. Contact them on this web page. Have you're serial number and model available.
Sentry Safe Keep It Safe
Jan 04, 2015 | Home Security
Tip
UPS - Battery Fault
UNINTERRUPTABLE POWER SUPPLY
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. Including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. If one battery is faulty in a set of batteries it will causes the whole battery system to fail and indicate a battery fault. A faulty charging circuit will not charge the batteries and will also cause a fault condition.
Lower powered and cheaper type UPS are switch over types, when the mains supply fails, the UPS switches over to the battery and inverter in milli-seconds which then supplies mains power to the computer and peripherals. A faulty inverter circuit and or flat batteries won’t deliver standby power when the mains supply fails.
NOTE the power waveform from these UPS is a pseudo sine wave (i.e. not a true sine wave).
The true UPS types are usually the higher KVA units (over 1500 VA) that supply continuous mains power. The mains power is connected to a charger which charges the batteries and the inverter draws power from these batteries and converts it to true sine wave mains power to the computer equipment, therefore there is no switch over time lag when the mains supply fails.
on Dec 02, 2009 | Computers & Internet
Charging light flashes quickly between green and yellow. Normal?
No. Most UPS's should have a Solid Green Led on if the unit is running good. This might be indication that UPS has batteries that are not charging completely which mean they are depleting. How old is this UPS and the batteries? Have you changed the batteries yet? Need more info. Do you still have the manual. Always keep UPS manual handy. I have a ton of manuals but not for these little UPS. Mine are for 10kVA to 1000kVA 480v to 208v. Anyways hope I helped.
Dec 21, 2013 | Hi-Capacity Zoeller 510-0005 Basement...
How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sep 23, 2012 | Sentry Fireproof Safe
APC 280 UPS problem. No A/C output when power interupted. Battery charges OK.
Have you load tested the batteries? DCV is not a good enough test for the batteries, they could still open right up under load. If the UPS is over 3 years old, I'd swap the batteries. Your power is drawing solely from the batteries on AC line loss, so if the UPS is failing when that occurs, almost certainly is the batteries.
Aug 20, 2009 | APC INTERNATIONAL BACKUPS PRO 280...
I have a sentrysafe t6 mode i cannot open as battery is dead
Locksmiths install sentry safe batteries this way
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the sentry safe battery holder Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Jun 07, 2009 | Sentry Fireproof Safe
No backup shut down in 30 seconds
The battery is either discharged...or bad...charge it for a day..if thats doesnt fix it...then you need to purchase a new battery
May 31, 2009 | Fiskars Brands Power Sentry 100896 UPS...
Apc ups 650va no power when connctd to ac/bt wd power in on batry
Check the relay Circuit. the relay switch must be faulty
Feb 24, 2009 | APC Back-UPS Pro 650 UPS System
Ups taking no load and gets of within 30 seconds
I thought Fiskars quit making UPS, after powerware bought them out ages ago.
Two hours...you need a much bigger UPS to get two hours of run time. A 2200VA depending on t he load is a challenge to run two hours. Something like that would cost $400.00
30 seconds sounds like an over load issue.
Aug 08, 2008 | Fiskars Brands Power Sentry 100896 UPS...
Fiskars Brands Power Sentry 100897 UPS System Logo
56 people viewed this question
Top Fiskars Brands Computers & Internet Experts
David Payne
David Payne
Are you a Fiskars Brands Computer and Internet Expert? Answer questions, earn points and help others
