Question about Grohe Ladylux Pullout Kitchen Faucet S Steel 33759SD0
What tool do I use to remove grohe ladylux faucet handle?
Need to replace cartridge. The cap at the end is supposed to come off by turning clockwise. Don't want to force. The faucet is not stainless. It is impact plastic for lack of better description.
NOT my vid but See if this helps...
watch the video. If it matches your faucet , proceed to disassembly.
Once removed follow the following:
Be sure to do a quick debris flush of the faucet (not shown in video) by opening the stops a bit. prepare for the squirt before doing so. once clean, I recommend silicon grease on all seals screws. You can acquire a small amount from an auto parts store. A small ketchup squeeze package type for auto ignition wires is usually available. Do not over apply. A very thin coat is all that is needed. It will protect and lubricate. Vaseline can be used also but with less effectiveness.
Follow re-assembly instructions.
https://www.youtube.com/watch?v=yuMqVFD5Akw
Hansgrohe How to Change an M2 M3 Cartridge
Sep 15, 2015 | Grohe LadyLux One Handle Kitchen Faucet...
How to remove lever
There have been at least 2 different versions of the 7590C... on one version there's a plug on the 'back' (180 degrees from the handle) that covers a horizontal set screw, and on another version there's a cap on top that pries off and covers a vertical mounting screw.
User manual - http://moen.com/shared/docs/instruction-sheets/ins801l.pdf
Parts diagram - http://moen.com/shared/docs/exploded-parts-views/7590cpt.pdf
In this case, the parts diagram should clue you into which version you have better than the user manual does.
Mar 08, 2015 | Moen 7590C Aberdeen One Handle Kitchen...
Grohe alira loose on granite counter
Needs to be tightened from under the sink, may need a right angle faucet wrench, they are about $10, or you can try and snug it up by hand, hope this helps?
Aug 31, 2014 | Grohe Alira Pull-Out Kitchen Faucet S....
Why is my grohe alira kitchen faucet loose
There is a nut up under the counter its hard to see but tighten that . Most faucets come with a special tool fo hat but can be done with wrench
Why is my grohe alira kitchen faucet loose on a granite counter
Probably a loose fixture nut under the counter behind the sink.
Yeah ya gotta pull out everything and crawl up into the cabinet on your back and see if the nut (right up at the granite, above the hot and cold inlet pipes) is loose. If it is THEN you'll need to tighten it. Wrench, slip-joint pliers or a basin wrench. (probably basin wrench which is a specialized tool made for reaching up into tight places)
How to fix
If the faucet leaks tighten all connections if that does not work call Moen as their faucetts usually have a lifetime warranty.
May 07, 2014 | Moen Aberdeen One-Handle Kitchen Faucet...
Need a repair manual for U6476- Self Propelled WindTunnel Bagged. On/Off switch broken.
You don't need a manual for this.
Place the handle drive lever in the locked, off position.
Remove the 2 screws for the handle them remove the handle, you may have to give it a good knock from the front with the heel of your hand. You should now see the front of the switch.
Remove the bad door and set a slide.
There should be a tool caddy at the top front of the unit now, may or may not have a clear door. Remove the tools and locate 3 screws if there was a turbo hand tool, or 4 screws without if 3 attachment tools.
Remove the tool holder and you will see the wiring and switch.
There are 2 kinds of switches; one with clips and one with wires coming directly out of it.
It would be helpful now to take a picture of what you're looking at for reference and ease of putting the wiring the new switch in place.
Remove the clips from the old switch or disconnect the wires.
You can now remove the switch from the body by pushing the clip on the top and bottom until it slides out the reverse side where you first removed the handle.
Push a new rocker switch into place, rewire with clips, or wire nuts according to the picture, drawing, scribble or mental note you made and reverse the rest of the steps.
When you are finished, slide the drive lever to on and you're ready to go. It's a good idea to check the motor filter under the bag, the long side filter and replace the flat belt if have not done previously in the last 6 months. Good luck.
There is no manual but here is a parts break down to see how things fit together. http://c.searspartsdirect.com/lis_png/PLDM/M0605111-00002.png
Oct 29, 2013 | Hoover Vacuums
Electrolux Renaissance Hose Replacement
Notice how the hose has a groove just around the outer edge of the gray plastic near the white plastic insert. The hose is held into the handle buy two "tongues" inserted into this groove. One of these tongues is on the end of the top plastic piece of the handle. The second is on the piece of plastic that is slid into the little hole at the base of the handle and it is visible in the picture.
To remove the first, you'll have to remove the two screws in the top of the handle that hold the top plastic piece. This can be a challenge unless you have the right tool. It's essentially a hex-star allen wrench tool that is required, I'm guessing about 1/16 inch. I had one in my tool box that fit. Remove the screws and pop the top plate off. This frees the first tongue from the groove. Now, just get a screw driver (or use your finger) to press the plastic piece inserted in the hole at the bottom of the handle. Press from the "t" side and this should slide right out. Now your hose will slide right out of the handle and you can replace the old with new. Re-insert the small plastic insert, and refasten the top plastic piece of the handle and you're good to go.
-DB
Dec 04, 2007 | Vacuums
Grohe Ladylux Pullout Kitchen Faucet S Steel 33759SD0 Logo
Top Grohe Vacuums Experts
JoeVacs
Are you a Grohe Vacuum Expert? Answer questions, earn points and help others
