Question about AOpen (MX4SGI4DN2PRE) Motherboard
Mp57-D I computer do not boot, it is deep, but some time turn it on and working fine few days, any idea. Thank in advance
    Brigadier General:
  • AOpen Master
  • 3,400 Answers
RE-WIRE THE ELECTRICS BY THE MANUAL.
Posted on Jun 01, 2015
Deep fryer pilot light switches off automatically
First make sure that the thermocouple tube is directly in the pilot light flame. If it is, then the thermocouple is defective.
May 04, 2014 | Frymaster Dean SR42G Deep Fryer
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
I have a A8V-VM Ultra socket 939 with AMIBIOS 0903 version. When I boot normally with the Windows XP (SP3) on the hard disk it seems to work fine, nothing abnormal happens. Booting with a Ubuntu 10.04...
Go into your bios settings make sure your hard drive is set to IDE and make sure secure boot isnt on. You could just try resetting to default.
Also check your ram. Take out one then the other. This usually happens when Windows loads the files it is about to install into the ram. It takes up a lot of space and could cause faulty ram to overload.
Mar 19, 2017 | ASUS A8V-VM SE (MB-A8VVMSE) Motherboard
How to disable deep freeze without a password
How to Uninstall Deep Freeze for Windows 2000/XP/Vista without the password.
Note: Without a complete uninstallation you may not be able to reinstall Deep Freeze on your system.
What we are going to do is edit the registry and delete the startup references to Deep Freeze. This will prevent the Deep Freeze driver from starting up the next time you boot. (c:\windows\system32\drivers\deepfrz.sys)
1. First we need a way to edit the registry. The way to do this depends on your situation. If your computer is thawed you can simply use Regedit. If your computer is frozen or if it doesn't boot you'll need to find another way. Here are some alternatives:
If you have a multiboot computer with another copy of Windows 2K/XP you can boot from there. Or, you can physically mount the disk on another computer that uses Windows 2K/XP.
You will probably use a tool that lets you boot and edit the registry. A good example of this is PE Builder that lets you build a Windows PE CD and boot Windows from there. Or use Bart's, http://www.nu2.nu/pebuilder/ or Winternals ERD Commander. There are several, including some USB memory sticks capable of booting like a CD. The goal here is to boot separately from your hard drive and access it while it is "asleep".
2. If your computer is thawed run Regedit. If it's not thawed follow one of the alternatives described above, and run Regedit (or Regedt32 on Windows 2K).
3. On the Find dialog box type UpperFilters and check only the Values checkbox. Then click Find Next.
4. The program will find a value with the name UpperFilters. Open this value and if there's a line with the name of the Deep Freeze driver (DeepFrz or DepFrzLo) delete it including the return, leaving the rest of the lines intact. Also, if you are using ThawSpace and you want to get rid of it delete that line too (ThwSpace), if you want to keep the ThawSpace leave it there. Press F3 to find the next match and repeat the operation until you have fixed all the UpperFilters values inside the HKLM\MySystem key.
5. Navigate to HKLM\MySystem\Select and check the value with the name Default. It has the number of the control set key that the system will use when booted. If it is 1 the control set is ControlSet001, if it is 2 the control set is ControlSet002, and so on. We'll assume the control set is ControlSet001 but you should use the one specified by the value Default.
6. Now go to HKLM\MySystem\ControlSet001\Services and delete the keys with the name of the Deep Freeze drivers (DeepFrz or DepFrzLo and DepFrzHi). Also, if you decided to get rid of the ThawSpace delete the key with the name of the ThawSpace driver (ThwSpace).
7. That's it. Now reboot and Deep Freeze will not load.
QUESTION: What if the BIOS settings prevent me from booting from CD or USB? Answer: Deep Freeze prevents you from decrypting the BIOS password, but it does not prevent removing it, if you have the right tool! Most of the BIOS hacking programs will not work to remove the BIOS password on a Deep Freeze protected computer, but CmosPwd by Christophe Grenier does.
You'll need to know how to use a command line and install the driver. Yes, it uses a driver to remove the BIOS password. But it works, even on Deep Freeze protected computers. Use CmosPwd to remove the BIOS password and reset the default BIOS settings. Then you'll be able to boot from CD or USB and edit your computer's registry and remove the DeepFrz, DepFrzLo, and DepFrzHi references which start Deep Freeze.
Now here is a little known secret: Faronics (the makers of Deep Freeze) uses a special driver to remove broken or malicious Deep Freeze installations. They do not have any backdoor passwords, so they use a special driver to remove a Deep Freeze installation where the password is not known or that someone is having trouble with. Will they send it to you, or even admit to you that they have it? I don't know. But, even if you do have it, you will still have to boot separately from the hard drive and replace the existing Deep Freeze driver with the special one and reboot. And after that, you need to use a Deep Freeze installation file to fully uninstall Deep Freeze (it will be thawed when you boot up with the special driver). If you want to re-install Deep Freeze, you'll have to first delete the special driver too.
Only a few people have this driver. It is the only solution Faronics has for those who need to remove Deep Freeze without the password. And, like I said, you will have to be able to boot from CD or USB and access the NTFS hard drive. If the boot-up order is locked (hard drive first and only) in BIOS settings, use CmosPwd to reset BIOS and boot order. Then you can boot from CD or USB.
Booting from CD or USB and removing the registry references works also, but then you should uninstall Deep Freeze with an installation file once you are able to boot thawed.
If you are dealing with a trial version of Deep Freeze, just forward the BIOS date past 60 days and then restart.
If anyone is wondering if Deep Freeze has ever been hacked, the answer is "yes" it has, several times over the years. Most of the time these were weaknesses that Faronics was able to quickly fix or prevent. However, there was one hacker that really, REALLY gave them headaches. His name was Emiiano Scavuzzo from Argentina. He was really good at low level programming and used OllyDbg to come up with about five versions of his "Deep Unfreezer" which gave Faronics their greatest challenge to date. Deep Unfreezer now only works on older versions of Deep Freeze.
Faronics is doing very, very well right now (as of 2008). They sold Apple Computer their Mac version of Deep Freeze, which, if you know how to look for it in the Applications folder on a Mac, is used in all the Apple Stores on both their desktops and their laptops. So, if you're ever in a Mac store playing around with PhotoBooth or whatever, and the computer settings are all messed up, just restart the Mac and thank Deep Freeze.
Apr 11, 2010 | Computers & Internet
Computer is stuck on blue screen. will not reboot. will not turn off with power button.
Hello
Thank you for using
FixYa for your problem
Blue screen is a device isure, remove power and battery, put back the power and restart and press F8 and goto "Safe Mode with internet"
If the unit boots up fine we then know it is a device isure.
Try using the system restore feature and go back a few days and see if this helps
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 18, 2009 | Dell Inspiron E1505 Notebook
Ice maker wont work after water turned off then back on in few da
it's common for the icemaker fill tube to freeze up when water pressure is lost such as when water is turned off for a long period of time. the fill tube is the piece that comes into the back of the icemaker from the rear of the refrig. what i do is heat the tube up with a hair dryer and melt the ice out. message back if you have any other problems or questions thanks peyton..
Feb 22, 2009 | Refrigerators
Power save mode problem -- during the PC boot up
Hi Geekman,
Thank you very much for the quick follow up. I am very sorry that I couldn't update the issue on time as I was very busy on my work.
My problem was solved even I am not sure what was happened to me.
As I wrote down before, I left my computer disconnected to all power cable (power supply cable and monitor cable) on Nov. 18 at 5 am. This afternoon I connected monitor's power cable and main AC power cable, and turned on main AC power; then the bios check and memory check had appeared on the screen, and also asked for resetting the COMS. After I have reset all parameters, the computer is boot up as before and had the Windows Advance Options Menu (I didn't hit F8). I chose boot as "last knowing ...", after I had the desktop, then I went to Control Panel ... > to switch off the Screen Saver. Now everything is fine. I don't know if the length of the time of the disconnected power was the key point. Until now, I still do not know what is the correct scenario (the exact step by step) of clear COMS. I checked with websites, seems like there are so many different ways to do it (more than four ways). Does this mean every way is correct or can I say COMS can be cleared in any way?
Thank you again,
Nov 17, 2008 | Microsoft Windows XP Home Edition
Scanning App won't open.
Actually, it's okay- I just installed the windows drivers under Boot Camp, and that seemed to 'reset' the scanner under OSX.
Oct 12, 2008 | Epson Perfection 1670 Flatbed Scanner
BIOS problem
Turn of computer re start and reset the BIOS through the motherboard BIOS Reset jumpers
Aug 08, 2008 | Gigabyte GA-6WMM7 Motherboard
Monitor show picture for a few seconds, then turns black
It sounds like the power supply board on your monitor is failing. If it's still under warranty you might be able to get a replacement from the manufacturer - if not, you might be able to have it repaired at a computer or TV repair shop.
May 14, 2008 | E-Machines E17T4 LCD Monitor
AOpen (MX4SGI4DN2PRE) Motherboard Logo
144 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
