Question about Thetford RV Compact Gas/Elect Refrigr, 2 Way, Left Opening"
How do I figure out which wire goes where for power on norcold de 400-c fridge
I got 6 wires on a norcold de 400c fridge. Which are the ac power and which are the dc and what do the leftover ones go to?
  • Thetford Master
  • 4,654 Answers
Go to page 19 HERE=> DE 400C Service Manual
Still have questions? Let me know, Thanks John Tripp
Appliance 911
Posted on May 08, 2014
I have a Winni Minni with Norcold refrigerator 682. I have change board and element,but its not working on electric only on gas, prpblems ?? I live in Norway.
Sounds like your selector knob may net be making proper contact with electricity. You have changed everything else. You could check power available with a multimeter to your element. If power not available to your element, back trace to source and check for burned wires or breaks in wiring.
Hope this helps!
Apr 18, 2016 | Refrigerators
I shut down the fridge. Not getting any power to it now. I have checked breakers and fuses. There is power to 110 outlet where it plugs in. No power to gas valve. What do you think the problem is?
Your Norcold refrigerator is powered by 12V DC, not 110V AC. You need to check input power at the power board. If the fuses are good and you have good 12V to the refrigerator, check to see if you are getting 12V past the 5amp fuse on the board. If not, you may have a bad board. Norcold Power Circuit Boards for Sale The Norcold Guy
Jul 12, 2015 | Norcold Inc Norcold 1210IM Refrigerator
Norcold fridge in my motorhome
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Jul 09, 2014 | Refrigerators
We have a Norcold model N811FLT, it is connected to power, but is continuously running on gas. We've tried resetting it with no change. Could it be the power board or the control board?
you can reset the control board . to do this you must ground the # 15 terminal with a jumper wire to ground. this is usually the terminal next to the white & violet wire. check diagram.
Jul 07, 2014 | Thetford Norcold RV Cooler/Freezer
Fridge will not work on AC mode. AC is present into fridge.
There should be a code appearing on the display. If you are not getting any 12V to the Fridge your fridge will not function. You may also want to check for any blown fuses inside the electronic board assembly. ">
Aug 30, 2013 | Norcold Inc Norcold 1200LRIM Refrigerator
Wire hook-up
see schematic on side of inside back cover if 120 volt plug that goes to outlet then if 12 volts from black and green ground go to block they should be marked
Jun 18, 2013 | Dometic RM2620 2 WAY REFER
Norcold 3163 Fridge
There is a 3 amp.fuse in the wiring behind the control panel or somewhere between the control panel and the terminal block. If the fuse is blown do not replace with any higher amperage rating more than 3 amps. Here is a Norcold 3163 Service Manual On page 10 of the service manual shows all of the components that the ac power goes through. Let me know what you find and I will be here to answer any questions you may have, Thanks Sea Breeze
May 08, 2013 | Refrigerators
Norcold model 1200LRIM. Unable to select AC or LP mode. Auto is only option. Fridge frequently quits in Auto mode. No error codes. Display just goes blank. Battery connections are good; voltage is good....
Try to unplug it from the battery a few hours and then plug it back in and see if you are now able to select the AC or LP mode. There has been a recall on the 1200LRIM, The defect is a potential cooling unit leak caused during AC electric mode operation. Click on the link below to read more:
http://www.texastriallawyer.com/norcold/index.html
Nov 21, 2010 | Thetford Norcold RV Cooler/Freezer
My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Thetford RV Compact Gas/Elect Refrigr, 2 Way, Left Opening" Logo
126 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
