Question about Sony PS-LX250H Turntable
My tone arm starts about half way into the first song when i srart it where is the adjustment for it ?
The tone-arm on my turntable automatically stops too early. Is there any way to fix this?
Yes. you need to set the travel on your arm. I don't know your specific model but they are all the same concept. On the back by the pivot point there should be a small screw that you can adjust the travel before it returns.
Dec 31, 2015 | Audio Players & Recorders
How can I stop the tone arm from returning too early on smaller records?
The adjustment for auto return position is normally at the tone arm base on the left side under a rubber grommet. Use a flat blade screw driver to move adjustment screw, then test. Keep fine tuning until arm lifts at desired position. Cheers John. Stylus City NZ
Jun 14, 2014 | Crosley 0187SST Turntable
Adjust tone arm
Usually there is a hole towards the back of where the tonearm is mounted that adjusts the set down area. Be aware that some have two holes one for set down and one for pick up of tonearm. These can be adjusted with a flat blade screwdriver. Check and see with a good flashlight. Adjust slowly and check to make sure you are turning it in the correct direction.
Apr 04, 2014 | RCA Audio Players & Recorders
Wurlitzer jukebox 1015 78rpm records needle does not start at the begining sometimes starts 1/2" in. How do I adjust tone arm
If you study the screws around the cradle that the tone arm sits in you will see that it is adjustable. This determines where the tone arm is when the record comes up. If the machine was always wrong like this it may have been set for 45rpm records. You need to adjust the whole tone arm post with the screw that goes up into the base of the post..
Mar 22, 2013 | Audio Players & Recorders
Record tracking problem
There is a switch, or lever to a switch, that detects the end of the arm travel. For some reason, it is being tripped early. Try to open it up, and see what you can see. It doesn't sound like a broken part, but a dislodged part, maybe. That's all I remember, only had this problem once, years ago.
Mar 14, 2010 | Audio Players & Recorders
Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
NSM Hit120 Jukebox.
there is an opto sensor the gets blocked when the tone arm is at the end of the song. It looks like a black u mounted on a circuit board. The flag that interupts the sensor is on the tone arm. The opto must be dirty so it thinks it's at the end of the song and continues to the unload sequence dispite the tone arm having just started playing.
Jan 03, 2009 | Audio Players & Recorders
I balanced my tonearms correctly. i think .. but the stylus jumps off the record and when i back spin (cue) the needle skates drasticly. can you walk me through the balancing proceedure and tell me how to...
Balancing the tone arm is a two step process. Set the needle weight adjustment to zero(0) and make sure that the tone arm is balanced. It should rest horizontally without touching anything. Next, set the needle weight (usually 1.5 grams). Both adjustments should be on the rear of the tone arm. That should cause the tone arm to drop toward the record and have the correct pressure for the needle. Also, check the anti-skate adjustment. If that is off, the behavior you describe will occur as well.
Dan
Jul 21, 2008 | Technics Audio Players & Recorders
Wurlitzer 2600
Think it's only a small adjustment on the tone arm. See if you can find a manual for it on Ebay. It's a must..I think Victory Glass has them or maybe Always Jukin Both dot coms
Dave
Mar 12, 2008 | Audio Players & Recorders
Early tone arm pickup
On some record players there is an adjusting screw at the back of the tone arm that adjusts the tone arm drop in location but I don't think it will adjust the pick up point. That is controled by a steel rod under the record player deck that moves over and pushes a little trip lever near the center of the platter so that a gear is engauged and the end of record cycle is started. I'm not sure but you may be able to find an adjustment under the deck that is near the rotation point of the tone arm that will adjust that rod so that it will pickup later. Hope this helps some.
Dec 26, 2007 | Teac GF-350 CD Shelf System
Sony PS-LX250H Turntable Logo
49 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
