If you have a Ketron Vega C keyboard where one of the keys requires more pressure to work, it could indicate a mechanical issue with that specific key. Here are a few steps you can take to address the problem:
- Clean the Key: Dust, debris, or foreign objects may be obstructing the key's movement. Use a can of compressed air or a soft brush to gently clean around the key and remove any particles that might be causing the issue.
- Check for Physical Damage: Examine the key and the surrounding area for any signs of physical damage, such as a broken keycap or a loose key mechanism. If you notice any damage, it may be necessary to replace the affected key or seek professional repair.
- Lubricate the Key Mechanism: Over time, the key mechanism may become stiff or sticky, causing the key to require more pressure to function. Apply a small amount of silicone-based lubricant or contact cleaner to the key mechanism, following the manufacturer's instructions. Be careful not to use excessive lubricant, as it could cause other issues.
- Test Other Keys: Check if the issue is isolated to a single key or if multiple keys are affected. If only one key is problematic, it's more likely a localized issue with that specific key mechanism.
- Seek Professional Repair: If the above steps do not resolve the issue, or if you are uncomfortable performing the repairs yourself, it is recommended to contact a professional technician or the Ketron customer support for further assistance. They will have the expertise and tools to diagnose and fix the specific problem with the key.
