My logic TV/DVD player keeps turning off
I switch it on and it turns off after 30 seconds
Shuttle83
  • 1139 Answers
SOURCE: TV keeps turning off after 30 seconds
This is usually a sign that a function has not completed or a switch has stuck in an incorrect position. eject can only happen if the sensor (either optical or mechanical senses that a tape is present. The swich might be stuck or the sensor might be blocked or bad. You can open up the unit and try to determine if the sensors are not being blocked by any of the mechanical parts of the unit. You will need the service docs to show you where the components are located. I hope this helps. Shuttle83
Posted on Sep 06, 2007
dickgs
  • 22 Answers
SOURCE: TV turn on and off
Your TV has a power problem, it maybe high or low supply voltage that causes the TV to turn it self off because of an error. A technician from the manufacturer knows what error it has just by looking at the flashing standby light. Best is to take it to an authorize service center for repair... ^_^
Posted on Jan 16, 2008
  • 3 Answers
SOURCE: I have a 32" HD AKAI TV that keeps turning itself off
If the service shops didn't charge people $200 to fix this I would not post.. But since they do - here's the $8 fix.
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Posted on Jan 11, 2009
  • 1039 Answers
SOURCE: My tv keeps turns itself off and clicks every
replace any swollen capacitors on the power board.
Posted on Sep 01, 2009
  • 21 Answers
SOURCE: Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Posted on Sep 14, 2009
Connect dvd player element tv
Yes if the set has a set of audio/video jacks(a rear or side input) and that would be cheaper than fixing the player in the set.
Jul 19, 2013 | Televison & Video
Sanyo beeps every 30 seconds
Any timer working? Any keys on the remote are jammed? Do you get the same problem even when you use some other input like a DVD player?
Aug 19, 2012 | Televison & Video
I am unable to play DVD from different region on my Samsung ht-c655w??
Hi!
Follow this:
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and unplug from power. wait 30 seconds (this clears RAM)
4. Reconnect to power.
5. Turn on player with remote.
6. Press ENTER (middle button of the arrow keys) on remote. (ignore message on screen)
7. Press 8, 4, 2, 6, 9 using keys on remote.
8. Press ENTER on remote.
9. Wait until player finishes processing. (approx 15 seconds)
10. Player will turn itself off, otherwise turn off player with remote.
11. Turn power back on with remote.
Player is now Region Free.
Regards,
Pelu.
Mar 21, 2011 | Samsung Black DVD Player DVDC350
Unlock area code for LG DV450 Dvd Player
Make sure the TV is set to the DVD player.
Press OPEN on the DVD player.
Press PAUSE on the remote.
Enter the code 314159 on the remote.
The TV screen will show a prompt for region code - press 0 for multiregion.
Switch the DVD player off and wait for 30 seconds.
Switch player back on and it should now play DVDs from any region.
Mar 07, 2011 | LG Televison & Video
I have a 32md357 magnavox tv. a dvd disk is stuck in TV dvd player. How do I remove it?
Hello
Please try turning off the tv... wait about 30 seconds, PRESS AND HOLD THE EJECT BUTTON then turn the tv back on again. You can let up on the eject button as soon as it starts to spit out your dvd. This is a standard way to remove disks.
I hope this helps
Nov 27, 2010 | Philips Televison & Video
Freezes turns white then turns off then back on
IF YOUR IMAGE IS ALL WHITE YOUR LOGIC BOARD IS DEFECT BUT IM SAD TO SAY DO NOT REPLACE THE LOGIC IT WILL ONLY TEMPORARLY SOLVE THE PROBLEM THE PANEL IS OVERLOADING THE LOGIC BOARD PANEL IS BAD
Apr 24, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
No image from inputs 1 and 2
i just spoke to a tech guy and his solution worked for us. turn everything off including the dvd player or whatever you have in your video inputs.
pull the tv power cord out from the back for 30 seconds. plug the cord back in. turn on the set for 30 seconds. then turn on your dvd player. you should now see a picture.
we had something funky happen to our cable the day the set starting giving us trouble. pulling the power cord apparently allows the tv to reset.
good luck.
Aug 29, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Trouble Loading & Not Registering To TV
I can't say 100% but it sounds similar to the problem I had with the same model . The sleep mode in the on/off switch had gone bad and a new switch fixed the problem. It was about $42 to rtepair at my local electronics repair shop. Hope this helps.
Jan 30, 2008 | Yamakawa DVD-218 DVD Player
Disk holder will not open when open/close button pushed
a switch outside or inside is broken, dirty, or somewhat that get inside a switch.
Jan 13, 2008 | Emerson EWD2203 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
