Question about LG Heating & Cooling
LG split system LSH096QNAO - LG Heating & Cooling
Lg split system ch 46 error? help!!!
Ch-46Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor
Jan 07, 2011 | LG Art Cool LA181CNW Split System Air...
Installed LG split system. The unit does not
Any chance that you've got L1 and L2 hooked up to the same leg of the main? That would still give you 120 on each but not 240 from L1 to L2 like it should be. I'm not familiar with the LG system, but I would think that a comm line would have two wires.
Jul 14, 2010 | LG Art Cool LA181CNW Split System Air...
Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
May 18, 2010 | LG Art Cool LA181CNW Split System Air...
LG dual split CH 46 display.....
We have an LG Split System with a Remote Touch Screen Control Panel. There is a message flashing "CH46". How do we fix this?
Jul 04, 2009 | LG Art Cool LA181CNW Split System Air...
LG remote problem
Most probably if the remote works on the other units then the receiver on your problem unit is busted. You have to call an authorized service repair shopr to replace the board.
I hope it helps.
Jun 13, 2009 | LG LSC121PMA Split System Air Conditioner
Dont know what symbol on remote is for heating for LG split system airconditioner
On mine, it's the symbol on the right-most one of 4; looks like a sun-symbol with several single lines emanating outward from the circle.
May 19, 2009 | LG LSC121PMA Split System Air Conditioner
LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Apr 13, 2009 | LG LSC121PMA Split System Air Conditioner
Lg split system ch 05 error outside fan not working
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Jan 26, 2009 | LG LS-L1210CL Mini Split Air Conditioner
LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
Jun 05, 2007 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
