Question about Panasonic KX-FL501 Plain Paper Laser Fax
WHY DO I GET CLEAR LINE WHEN I COPY - Panasonic KX-FL501 Plain Paper Laser Fax
What is a 116-386 error code
Resetting to Factory Defaults / Clearing the Memory
You can selectively clear information stored in your machine's memory.
  1. Press Menu on the control panel until Maintenance appears on the top line of the display.
  2. Press the scroll buttons until you see Clear Memory on the the bottom line and pressEnter.
  3. The first available menu item, Paper Setting, displays on the bottom line.
  4. Press the scroll buttons until you see the item you want to clear.
    • Paper Setting: Restore all of the Paper Setting options to the factory default.
    • Copy Setup: Restores all of the Copy Setup options to the factory default.
    • Fax Setup: Restores all of the Fax Setup options to the factory default.
    • Fax Feature: Cancels all of the scheduled fax jobs in the machine's memory.
    • Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
    • Sound/Volume: Resets the sound and volume settings to the factory default.
    • Machine Setup: Resets all of the system settings, such as the machine ID, date and time, display language and save modes, to the factory default.
    • Set Report: Clears all records of your faxes sent.
    • RCV Report: Clears all records of your faxes received.
    • Phone Book: Clears the speed dial or group dial numbers stored in the memory.
  5. Press Enter. The selected memory is cleared and the display asks you to continue clearing the next item.
  6. Repeat steps 2 and 3 to clear another item.
  7. ORTo return to Standby Mode, press Stop/Clear.
http://www.support.xerox.com/support/enus.html
May 08, 2015 | Office Equipment & Supplies
I ned reset (lsu) for printer dell 1610n
[Clearing the Memory]
You can selectively clear information stored in your multi-function printer's memory.
Press <Menu> on the operator panel until "Maintenance" appears on the top line of the display. 1.
Press the scroll button ( or ) until you see "Clear Setting" on the bottom line and press <Select>. 2.
The first available menu item, "Paper Setting" displays on the bottom line.
Press the scroll button ( or ) until you see the item you want to clear.
Paper Setting: Restores all of the Paper Setting options to the factory default.
Fax Feature: Cancels all of the scheduled fax jobs in the printer's memory.
All Settings: Clears all of the data stored in the memory and resets all of your settings to the
factory default.
Sent Report: Clears all records of your sent faxes.
RCV Report: Clears all records of your received faxes.
3.
Press <Select>. The selected memory is cleared and the display asks you to continue clearing the next
item.
4.
Repeat steps 2 and 3 to clear another item. 5.
OR
To return to Standby mode, press <Return>.
[Page 130]
Dell Laser Multi-Function Printer 1600n User's Guide
ftp://ftp.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers/dell-1600n_User's%20Guide_en-us.pdf
Jun 12, 2014 | Dell 1600n All-In-One Laser Printer
When someone receives a fax from me it has a blank line down the middle of the page
fax delivery problems are not clear, it is a problem on the line or problems at the head of the printer or ink for machines that use ink or printer heads printer or a problem on the machine. to identify you to do troubleshooting.
1 - Make a copy of the document using the machine, if the copy is made there is no problem, this means that the head of the printer or the ink does not have a problem.
2 - use another machine to identify the problem line and engine problems.
- If the problem remains the same, it is a problem on the line but, otherwise, your machine needs to be done further examination, it is likely there is a problem rj11 port.
TQ
Sep 19, 2011 | Office Equipment & Supplies
The receiver of my FAXes says that there is a black line down the middle of each page. The FAX is a good copy-clear, etc.... but this line has to go. What can I do? Thanks, Donna
Dear Donna,
When a document is scanned from the top portion of the printer, it will loop around and output from underneath. The scanning glass on the far left side will have some debris on it. Lift the the lid exposing the glass portion, inspect for "stuff" on the glass, perhaps pen or white out. You can use a mild soap and lightly dampened cloth to remove any debris.
Good Luck,
Pre
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Single narrow black vertical line about 1 3/4 inches from right side of copy. Line runs the entire length of the copy. Happens only during copying color or black and white.
The line issue is caused by something on the image sensor. To get to it and clean it just pull the front up where you put the paper into it to scan. Inside you will find a glass strip, this is the image sensor. Use a paper towel dampened with window cleaner and gently scrubbing the glass strip, After cleaning the strip let it dry for a minute or teo before you close the cover and try a scan. It should be clear and should copy great again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
Jun 18, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
How to restore manufacture setting on 18D Avaya phone
It's not that simple. You can clear all the non line buttons from a set by pressing FEATURE 00 , the button and MIC/HFAI. Line selection and line appearance is programmed from Centralized programming on the main phone(s). You can also use COPY commands to make a phone behave like another.
Carl
Jun 01, 2010 | Avaya Corded Phone avaparp18d
How to clear One Touch stored number On SF 1600
To delete all of the number or
name, press left arrow when flashing line is at
the first digit.
To correct a digit, use the right arrow or left arrow to
move the flashing line under the digit,
then enter the correct digit.
If this doesnt work for you You will have to clear the memory of this machine and start over.
Press MENU.
Press 7.
The LCD shows "MEMORY"
CLEAR". 7 . M E M O R Y C L E A R
Press START/COPY.
Select the desired menu by
using or .
The LCD briefly shows the
menu you have selected. T X / R X J O U R N AL
4 Menus available :
TERMINAL ID
SYSTEM DATA
ONE-TOUCH DIAL
SPEED DIAL
TX/RX JOURNAL
5
Press START/COPY.
The LCD asks if you are
If you do not want to clear the
sure you want to clear the
memory, select ‘N’ and press
A R E Y O U S U R E ? Y/N START/COPY.
memory.
6
If you want to clear the
memory, press
START/COPY.
The LCD shows the
message “MEMORY
CLEARING.”
M E M O R Y C L E A R I N G
Apr 07, 2010 | Samsung SF-4500 Plain Paper Thermal Fax
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
Mar 11, 2010 | HP Officejet Pro L7680 All-In-One Printer
Streaking on the IR C3100
Dear sir; Streak line, I have two things come out from my mind I need to clear; no. 1 do you make copy through ADF and got streaking line? if your answer is "yes" would you to make another copy direct from glass plateform, if copy coming out same problem that's means you need to replace drum cleaning blade, if copy coming out perfect then you need to clean the glass especial the narrow piece if they have, try it out and let me know, good luck!
HAVE A HAPPY HOLIDAY!!!
Dec 17, 2008 | Canon imageRunner C3100 Copier
I'm trying to scan and it says check phone line connection.
Try to clear the memory of the or the printer is in fax mode please choose copy or scan mode
Apr 05, 2008 | Lexmark X4270 All-In-One InkJet Printer
Panasonic KX-FL501 Plain Paper Laser Fax Logo
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
