Question about Saeco Odea Go
Not starting up
After self test temp error is in display
Nuheat thermostat keeps rebooting
replace the thermistat module..sounds like it has a bug in the firmware
Jan 08, 2014 | Nuheat Harmony Thermostat
I am looking for the A/C fuse for a Ford mustang gt 2002
manual system
  • Blown fuse(s):
  • Battery junction box (BJB) F26 (65A).
  • Central junction box (CJB) F33 (20A), F36 (7.5A), F37 (10A), F39 (20A), F45 (15A), F47 (15A), F58 (10A) or F59 (7.5A).
  • Blower motor inoperative.
  • A/C compressor inoperative.
  • Disconnected electrical connectors.
  • Engine cooling fan inoperative.
  • Damaged control switch(es) or climate control panel.
  • Circuitry open or shorted.
Electronic Automatic Temperature Control Module Self-Test
  • NOTE: The vehicle interior and exterior temperatures should be between 10° - 32.2°C (50° - 90°F) when carrying out the self-test. If the temperature is not within the specified range, false in-vehicle temperature sensor DTCs will be displayed.
    The EATC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to continuous diagnostic trouble codes for concerns that occur during system operation.
  • The self-test can be initiated at any time. Normal operation of the system stops when the self-test is activated.
  • NOTE: The key must be in the RUN position to enter the self-test.
    To enter the self-test, press the OFF and floor position buttons simultaneously and then press the AUTOMATIC button within two seconds. The display will show a pulse tracer around the center of the display window. The test may run as long as 30 seconds. Record all DTCs displayed.
  • If any DTCs are retrieved during the self-test, proceed to Electronic Automatic Temperature Control (EATC) Module Diagnostic Trouble Code (DTC) Index.
  • If a condition exists but no DTCs are retrieved during the self-test, proceed to Symptom Chart.
  • To exit self-test and retain all continuous DTCs, push the blue (cooler) TEMP button. The module will exit self-test, retain all continuous DTCs and then turn off (display blank).
  • To exit the self-test and clear all DTCs, press the defrost button. The display will show 888 and all function symbols for one second. The module will then turn off (display blank) and all DTCs will be cleared.
  • Always exit the self-test before turning the EATC system off.
  • Continuous DTCs will be deleted after 80 ignition switch ON cycles after a continuous condition occurs.
Mar 28, 2011 | 2002 Ford Mustang
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Error 0xb9000003
* Where exactly you are receiving this error, on the printer display or on in computer?
* When exactly you are receiving this error?
* Does the unit print a self test page? Steps are given below:
1. Load the paper tray with unused plain white paper.
2. Press Setup until Print Report appears on the display, then press OK.
3. Press OK again. The self-test report prints.
:) Dr Tony
Apr 17, 2010 | HP PSC 1610 All-In-One InkJet Printer
Computer will only start in safe mode hp cue root and hp help and restore are not working? what is the best resolution? hard drive failure?
I have included some directions from HP about using an embedded Hard drive test. This is done using the BIOS. Try this to rule out a hard drive problem. This is supposed to also repair some hard drive issues. Then, we can go from there.
Brian
Perform a hard drive self test Many computer problems are related to soft failures on the hard drive. The comprehensive portion of the HP Hard Drive Self Test repairs soft errors on the hard drive, but does not report the errors. After the test completes, be sure to restart the computer to determine if the test repaired any problems you are experiencing with your computer. To use the HP Hard Drive Self Test, follow the steps below. NOTE: If the notebook computer is configured with two hard drives, then it may be necessary to test each drive separately.
  1. If the notebook computer is running solely on battery power, plug the AC adapter into the notebook.
  2. Shut down the computer if it is running.
  3. Press the power button to turn on the computer.
  4. Press f10 when the HP/Compaq logo displays.
  5. After the BIOS Setup Utility displays, use the Right Arrow key to select the Diagnostics menu.
  6. Select HDD Self-Test options .
  7. Press enter to display a list of HDD/Self-Test options.
  8. Select Notebook Hard Drive and then press f10 to display an Estimated test time .
  9. Press f10 to continue. The Hard Drive Self Test executes a Quick test , a Comprehensive test, and a SMART test.
If any test fails , contact HP for instructions on how to order a replacement hard drive. If all of the tests pass, the hard drive is not damaged. As a rule, HP does not replace a hard drive that is under warranty if it does not fail the HP Hard Drive Self Test.
Mar 01, 2010 | HP Pavilion dv9000z Notebook
Where is the electronicnautomatic temperature control module located on a 05 ford 150
I assume you have checked all fuses. It could be the heater control switch , the blower motor resister , I would start testing if power is getting pass the switch to the blower motor.
Nov 28, 2009 | 2005 Ford F-150
When i boot up i get a message that my hard disk failure is immenent is there anyway to repair this problem
if you get a "Disk Controller Error" error messages that may occur before Windows XP or Windows 2000 is started. Imminent Hard Disk Failure This error may appear when the hard drive detects that it will fail or stop working sometime soon.
Backup Data Before Proceeding Although the notebook may continue to start Windows after displaying the message, it is advisable that you immediately backup your personal data from the PC by copying it to a Network Drive, CD, DVD or USB storage device. After completing the backup, use one of the following methods to resolve the error. Step 1: Test the Hard Drive Use the steps below to test the hard drive in a Notebook PC using the HP Hard Drive Self Test.
  1. Plug the AC Adapter into the Notebook PC.
  2. Press and hold the Power button for 5 Seconds to turn off the PC.
  3. Press and hold the F10 key while you press the Power button to turn on the PC. Release the F10 key after text is displayed on the screen of the PC.
  4. After the BIOS Setup Utility is displayed, use the Right Arrow key to select the Tools menu.
  5. Select Hard Drive Self Test
  6. Press the Enter key to start the test.
The Hard Drive Self Test will provide an Estimated test time . A Quick test, a Comprehensive test, and a SMART test will execute when the Enter key is pressed. If any test fails , order a replacement hard drive. If all of the tests pass, the hard drive is not damaged.
If all tests pass , press the power button to restart the PC. The error was most likely a result of a shock to the PC triggering a SMART error from the Hard Drive. Since the Notebook PC passed the Hard Drive Test, it is safe to use.
Mar 07, 2009 | Acer Aspire 3680 Laptop
I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
GE Range Model GRCR3825ZWW-1 DOOR error code on range display
The door latched Micro-switch is not working or is dirty.
Remove the back panel, in the middle of the back there will be a metal arm that moves in and out when self cleaning latch is closed and opened. This arm pushes two or more Micro-Switches in the back, they are dirty or not working and need replacing.
Nov 05, 2008 | Kitchen Ranges
Saeco Odea Go Logo
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
