Question about RCA Scenium D34W20 34" TV
RCA Scenium D34W1350 with built in DVD player cannot reconize a DVD after it is inserted into place. Help me with this.
  • 668 Answers
The DVD unit probably needs to be replaced. I am not sure you will be able to obtain one or if you will have to go through a RCA Auth. Repair Facility. The DVD units are not difficult to replace if you can get one.
Sorry I am not able to help more.
Skyassoc
Posted on Jun 22, 2009
My GE universal remote for RCA Scenium tv doesn't work the DVD part
If this is a combo unit (TV with DVD built in) you need the original remote---Universals almost always are missing key features the original remote had as most companies have someone else make the unit and put their name on it.
Mar 21, 2012 | RCA Scenium D40W20 40" Rear Projection...
Won't reconize disk in player
Well here is your resolution for your problem.
As you saying that when you insert any CD or DVD in Player its shows NO DISK.
Well Sometime what happen is if a CD contains are not compatible with Player than it wont work with it.
Or if you had burn that CD or DVD from your personal computer or laptop but it is not burn in proper format than also it wont work in PLAYER.
Well even if CD or DVD is having any scratches on it or it is Used uncounted enumerable times than also sometimes this things happen and it wont work in PLAYER.
Well before Inserting any CD or DVD in Player Just check the above mentioned points.
If everything is ok with the CD or DVD but than also its shows the same problem than get the CD or DVD cleaner liquid spray or even you can use Spirit to clean the CD or DVD and than Insert it.
After doing all this but if its shows no result in it than go to the company dealer and ask him to change the head of the player and you wont face this problem afterward for sure.
if you still have nay quarries regarding the same or any other you may reply me.
Naiven
May 23, 2010 | RCA DRC233N DVD Player
When I put a disc in my dvd player it just continues to spin. It's like, it's not reconizing that a disc has been inserted, it just keeps spinning and spinning.
Try a lens cleaning disk. They can be purchased at pretty much any place that sells dvds or cds. If that does not work than it is the motor in your dvd player most likely.
May 14, 2010 | FEC RKMV5 Custom Rackmount Kit for JVC...
I have an RCA D40W20 tv. I have the vcr/dvd connected to the video 1 jacks. picture will not format to screen. everyones heads are cut off. picture is too tall. any fix?
Ty using the zoom settings on the TV or the dvd player, also check the inputs by testing the tv with free to air or another input to determine if its the tv or the dvd player. Good Luck.
Nov 27, 2009 | RCA Scenium D40W20 40" Rear Projection...
I have no audio on my RCA Scenium rear projection
Replace Audio output ic. Make sure you do not have sound turned off.
Sep 28, 2009 | RCA Televison & Video
Have sound no pic. on 52 inch.
if you have some thin lines on the top of the picture probably you have a problem on the power supply for the convergence
Sep 29, 2008 | RCA Scenium D40W20 40" Rear Projection...
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Integrated DVD player
If your handy, then try to disassemble the DVD .player from the unit and manualy clean the lens assy,but please be aware of the HI Voltage dangers inside of a tV set. if your not then Please call a pro top assist you with this repair. If the units not worth fixing then simply buy and inexpensive DVD player/recorder and hook it up via the external inputs. Good Luck
Jul 24, 2006 | RCA Scenium D40W20 40" Rear Projection...
RCA Scenium D34W20 34" TV Logo
113 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
